Question about Sony DCR-VX2000 Mini DV Digital Camcorder
First clue was the output sound and then the video went
This all seems to be centered around the output. It began when I was using the camera as a deck and I began to hear sound that was corrupted next the picture began to lose quality and the both failed altogether. At this point when putting in a tape with material on it - nothing is hear and the screen is blue. This cannot be good.
Jon
    Problem Solver:
  • 4 Answers
Bring a head cleaner tape and run it some time than check
the play of any good recorded tape if some noise appear
clean the head again with cleaner tape, i hope your camera get
well.
sanjy
Posted on Jul 15, 2008
I have an old Sony CCD TR55E Handycam, I bought from new. Now I want to transfer my tapes to DVD, and seem to have lost sound output playing tapes to TV/Recorder. Tried running tape cleaner, no succes
What is your signal path? The question you need to answer is, "Where are you losing the audio?" Are you losing it between the tape and the playback head, or are you losing it in the cable, or are you losing it at the TV/Recorder?
Does the camera have an audio out into which you can plug ear buds to test the audio from the camera playback?
Nov 28, 2014 | Sony Cameras
Yamaha RX-V365 Receiver when I hook up my center channel it is not audible at all. The R and L speakers work fine when they were located in the FRONT A and FRONT B terminals, but when I moved everything to...
With what signal did you try? Maybe your signal source (DVD/TV or radio) didn't contain any sounds for the center channel.
Go to the Setup menu, Speaker setup / Manual setup and find there item called "Test tone". It will output a test tone to each speaker individually (you will see on LCD which speaker is being tested at each moment). If you will hear a sound from the center now, there is no issue and center is working fine, just your source didn't contain any sound for the center.
If it doesn't work, then either you have faulty cable, faulty speaker or faulty center output of the receiver.
- Try connecting the center speaker to different output of receiver (this will test if speaker is OK).
- Try connecting working LEFT speaker to left output with CENTER cable (this will test if cable is OK).
- Try connecting working LEFT speaker with working cable to the CENTER output (this will test the output of receiver if OK - but use the Test Tone from Setup).
May 18, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
My laptop speaker won't stop buzzing. It began
A buzzing/humm sound could be a earth loop problem. This is caused by connecting amp equipment into different mains power outlets.
Use a power board and connect all your amps and laptop to the one power board.
Nov 08, 2009 | HP Pavilion dv9000z Notebook
Why aren't my games playing on the nintendo fc twin?
The FC Twin connects through an RCA connector, and can be hooked into a surround sound system. When using stereo and surround output from these systems, NES sounds and music may seem very different from their typical mono output. Using output modes that properly generate mono sound, either through a single center speaker or cloned to multiple speakers, the sound output sounds mostly identical to the original NES. The FC Twin does not produce some sounds faithfully, even with mono output; sound effects in the Super Mario Bros. series games will for example immediately seem different. Nevertheless, some later models of the console produce NES sound much more faithfully than units made closer to launch. Recent models produce sound with complete fidelity.
all this can be found here
http://en.wikipedia.org/wiki/FC_Twin_Video_Game_System
Jan 18, 2009 | Nintendo FC TWIN Console
My 04 pontiac g p systems light said charging system failure.
IT COULD BE THE BATTERY BUT I WOULD LOOK TO THE ALTERNATOR TO MAY HAVE WARN BRUSHES
Jan 06, 2009 | 2004 Pontiac Grand Prix
Display of my Cannon Power Shot SD 630 Digital ELPH: NO IMAGE
i think you camera,s software is corrupted
go your canon customer center for repair it
Dec 14, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Sony CyberShot DSC-N2 - Unable to read memory card
Before anything else.... you must examine first if your card is not damage, How? Try to test it in the memory card readers or other camera that fit the same memory cards.
Some other cards do have lock option in the jacket of the card. Try to unlock it. After doing so reformat the memory card in to your cam.
Other option...... Some other cam do have internal memory, if you have the same, configured it out.
Oct 29, 2008 | Sony Cyber-shot DSC-N2 Digital Camera
Black screen
The Black Screen of Death is a common problem with Sony cameras from around 2004-2006. If you have a Sony, it's very likely that the CCD chip in your camera is toast. Good clue to this is if you can play tapes in the camera, which means the tape heads, screen, and much of the electronics are working fine.
You can try calling Sony at 1-866-703-7669, Custormer Information Services Center. They were sending shipping labels to customers with dead CCDs, so the cameras could be sent in for free repairs. This was a year ago - I'm not sure the program is still in effect. If not, they should still be able to tell you what it will take to repair the camera, since they know exactly what the problem is. (You might end up with a refurbished unit, but that's what your camera would become anyhow.)
Apr 19, 2008 | Sony Handycam DCR-TRV350 Digital Camcorder
Stopped working and squealing sound
Your set is shorted circuit condition. The power supply is making the noise. Unfortunately almost any of the hi current circuits will do this. If picture went out 1st look for video or hi voltage problems.
Jan 11, 2008 | RCA 32F531T 32" TV
Sony DCR-VX2000 Mini DV Digital Camcorder Logo
327 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
