Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
The water and ice dispenser is not working, the light goes on and off to normal and dim. There is a low tone bonging sound. Fridge and freezer work, but lights and ice and water dispenser don't.
  • 2 more comments
  • TJBeau Aug 06, 2008
    ice maker works. Nor more buzz from the water pump sound.
  • yachtjohn Aug 09, 2008
    same problem with my icemaker Any advise?
  • hbutler97 Aug 09, 2008
    I just changed the filter and the water dispenser stopped working.
  • mikeymo88 Jan 19, 2009
    We had power outage. When power came back on ice maker never made anymore ice. There is no ice in the bin nor the icemaker. Water doesn't come on to fill ice maker.
    Problem Solver:
  • 14 Answers
Undo the front bottom vent cover and there is a wire harness the wires maybe unpluged or just come loose so just make sure they are connected good.
Posted on Feb 21, 2009
Have you checked the wiring harness on the door? Mine quiet working and the wiring harness was broken.
Posted on Feb 13, 2009
  • 4 Answers
Water dispenser not working ice maker works
Posted on Jul 06, 2008
2 Suggested Answers
  • 19 Answers
SOURCE: The water and ice dispenser is not working
if your refrigerator is only a year old. it should still be covered by your warranty, if any one works on the refrigerator while still under warranty, your warranty is expired. So check before you put your hands on it. sounds like a power problem, maybe an open fuse etc....
Have a GE Profile PFCS1RKZA - with many random issues...
The dimming light indicates a power loss in the system.
Jul 10, 2015 | GE Refrigerators
Water dispenser is not working no water dispenser
If the light is dimming when you try to get ice (dimming then getting bright in cycles) then thisis a common problem and GE will fix it. The Main circuit board on the back goes bad causing the ice\water dispenser to quit working then eventually the fridge quits cooling. Call 800-386-1215 and tell them the problem. There is a recall for the board
Oct 13, 2009 | Hotpoint HSS25GFP Side by Side...
The water and ice dispenser is not working, the light goes on and off to normal and dim. There is a low tone bonging sound. Fridge and freezer work, but lights and ice and water dispenser don't. the...
Feb 21, 2009 | GE Adora (DSF25KGTBG) Side by Side...
Does not dispense water or ice.
Replaced the main electronic board at the back of the fridge. Works fine now.
Jan 16, 2009 | Refrigerators
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
My GE PSS26SGRSS is not working. The panel lights are blinking.
Problem is the circut board in the back, you can go to ge appliances.com go to service and support type in model# go to unit and main board parts to order.
Nov 14, 2008 | GE PSS26SGRSS Stainless Steel Side by Side...
Ice and Water not dispensing. Light button not working
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Apr 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Hotpoint side by side Model HSS25GFPJWW
Your problems are the power board for sure. I have the same refrigerator and have read dozens of forums and advise pages looking for answers. If you let the problem countinue your fridge will completely stop cooling and all your food will be trash as has happened to me.
Symptoms: Fan in the back starts to make click or flopping sound as it tries to start up. Ice despenser doesent despense ice. water works sometimes. Eventually you notice your food defrosting partially and then refreezing as the defrost timer stops working which is controlled by the power board. Light dims and pulses when you hold the Ice despencer in. If you remove the light for the dispencer your water will work fine as long as the fan isnt making the clicking noise. Fan will eventually start up and run.
FYI GE customer Care is useless
Jan 03, 2008 | Refrigerators
Start with the easy stuff. Is there water at the refer? Remove the line from the back and check for water flow. If equipped, is the filter plugged (water flows without filter in sort of thing)? Is there debris in the line to the refer blocking the valve? Does the water valve solenoid "click" and flow water if you remove the internal water line that goes to the frige interior? Is the water line frozen in the door (turn off frige for a day and check water flow).
Sep 27, 2006 | GE GSH25JSRSS Stainless Steel Side by Side...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
225 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
