Ruud heat pump capacitor size
Hi, I am currently working on a five ton Ruud heat pump. The run capacitor for the compressor is bad and all the information is rubbed off of the capacitor. Can you tell me how to get the correct size capacitor. everyone i talk to at the parts stores just tell me to use a hard start or the turbo 2000 but can not tell me the correct size. The condensor model number is upca-048jas and the compressor model number is elcrml 0400
  • jun_garcia Aug 17, 2008
    How do I size a 2 HP 125V pool pump start capacitor? The capacitor label is no longer readable.
    Scholar:
  • 104 Answers
A hard start or turbo 2000 will not work if the run capacitor is bad. You will need to contact a ruud supply house or dealer with model and serial to find out the exact match. I have checked my sources and came up empty handed. You could try getting a 35/5 MFD at 440V or a 45/5 MFD at 440V as these are the most common capacitors used in Rheem and Ruud equipment. The key is that you will need to check your amp draws on both motors against the nameplate rating to make sure that you are not over-amping the motor. Also check the nameplates on both of the motors. Most condenser fan motors and some compressors list the capacitor size they require in a somewhat less than conspicious location on the label.
Posted on Jun 27, 2008
Rpnl-030jaz condenser fan not turning
if the fan does not run then it could be a bad motor or just the capacitor is bad. usually I check the capacitor first. it usually goes bad before the motor
Apr 14, 2014 | Rheem 2.5 Ton 13 Seer / Ruud Heat Pump...
Ruud 5 Ton UAKA Condensor fan running but compressor won't start. Internal thermal overload cycle.
Have you checked the wiring going to the compressor to make
sure it is not melted? Next, are you
able to put your hand on the top of the compressor? Check to see if it is hot or cold. You might have a bad run capacitor so let the
unit turn on, wait about 5 minutes, turn the unit off, and then tell me if the compressor
is hot or cold to the touch. Next, are
you comfortable with a meter?
Oct 17, 2013 | Ruud Matching Split Air Conditioner
What type of run capacitor do I need for a Ruud AC model UPNJ-031JAZ (outside unit)
Looks like it should be a 35/3 370VAC. If it is not legible on the old capacitor read the data plate on the fan motor and compressor. These should say "uf" or "mfd" rating. Good Luck!!
Apr 17, 2017 | Heating & Cooling
My 4 year old Ruud home a/c compressor stopped working. inside fan blows but compressor won't turn on...what can I do prior to calling the gas company who installed the unit...
Ruud parts warranty from factory is 5 years, the capacitor has possible gone out, it will be in the contol compartment on the out side unit and is a dual run capacitor that controls the compressor and fan motor. Recommend if capacitor is bad to replace entire capacitor. As Stated above the parts are under warranty if under five years old. To verify age the date code is in the serial number after the "F" **** week/year of manufacture. Also outside unit has independent power supply so check fuses if any and circuit breaker.
Aug 21, 2011 | Ruud UBHC Air Conditioner
I have a 25 year old Ruud A/C. The outdoor fan isn't turning and I can hear the condensor humming. There are 2 capacitors in the the electronics box that the schematic says are running capacitors. ...
The 3 microferad capacitor goes to the fan motor. The bigger one goes to the compressor. If the capacitor is swollen or pregnant looking it is shorted and needs to be changed. If it has discharged oil it has shorted out. If you can't read the mfd (microferad) you can go by the rated tonnage of the air cond for rule of thumb.
2 ton condenser = 25mfd capacitor
3 ton condenser= 35 mfd capacitor
4 ton condenser= 45 mfd
5 ton = 55 mfd
again, this is rule of thumb but should get your unit running again.
Jul 28, 2011 | Ruud Heating & Cooling
Condensor fan went out on 1999 ruud heat pump.
Did you try pushing in the contactor to see if the unit will even run?
Jul 18, 2010 | Ruud UBHC Air Conditioner
I have a Ruud Model # UACC-036JAS. Any idea on
Hi, yes the number you are showing me 036 indicates its a 3 ton unit. For every ton of cooling, you will have 12,000 btu's of cooling. 36 divided by 12=3 ton unit. Its showing me also its a Ruud Handler 2.0 ton which would be a Model# UACC-024JAS? If your mobel number is the one you gave me, UACC-036JAS, this is a 3 ton unit, absolutely no questions. I hope I have been of help to you. I am a licensed air conditioning / Refrigeration /Heating Contractor. Let me know if I have been of help.
Sincerely,
Shastalaker7
PS If this is a split system with the indoor air handler and condenser outdoors, both coils must be the same tonnage for it to work for you properly. You can't have a 2 ton indoor evaporator coil with a 3 ton condensing unit.
Jun 28, 2010 | Ruud Handler Air Conditioner
We have a fairlynew 5 ton Central Ruud or Rudd unit that it is so noisy in the yard that we can not stay out there. We thinkit is the compressor. Help
I have a new 13 seer rheem or ruud same thing. I can not here it run. Uou must have a bad compressor. Ruud put schroll compressor in and when they start to go out they will drive you nuts they are so loud. Get it changed before your warranty runs out. Ruud will change your compressor if it to noisy. No problem. Russ
Jul 20, 2009 | Ruud Central System Air Conditioner
Ruud 5-ton 10 SEER heat pump compressor turns off after 20 minut
First turn it to cool and see how cold the big cooper line is if it is not real cold you could be low on freon but if it is cold your compressor is bad
Nov 12, 2008 | Heating & Cooling
Heating & Cooling Logo
1,079 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
