Dryers usually have 2 thermal sensors a low temperature sensor and a high temperature sensor. The parts are inexpensive and if one or both are bad, they will keep the dryer from heating.
The way to check them is to use an OHM meter to see if they are OPEN. If you are using a Digital ohm meter, the setting will most likely read OL for overload.
It is most likely the low temperature sensor, but could be either. Replace both. Again, they are inexpensive and easily replaced.
To access them, you have to get to the back of the dryer and remove the panel. UNPLUG POWER before taking the back panel off. You will see 2 small rount (quarter sized) pods attached by sheet metal screws to a vent stack. One at the top and one close to the bottom. The wires should have push on connectors.
Remove the wires and check each with an ohm meter to be sure.
On your dryer the common problems found is either you lost some of your electrical power (check your fuse box) or you need a new heater #131475300 about $100 for the part.
