Question about Motorola Mobility RAZR V3
White screen on razr
I took my phone out and set it on a glass table. a little later it turned itself off, and when i turned it back on, the inside screen was white, and the outsine screen was blue. both were blank. i can still use my phone for the things that i know where they are...... i tried taking out the battery and the sim card. but that didn't work. every now and then, the screen will work but tehn not too long after, it will freeze. please help me. e-mail me @ randancerman@aol.com if you can help. thanks.
  • randeezy Jun 30, 2008
    Where would I take it?
    Brigadier General:
  • 7,752 Answers
Take the phone and have the flexcable and LCD replaced
Posted on Jun 28, 2008
Something under screen looks like lint or something . took it to at&t where i bought it . they said they couldn't fix it. the little specs make the screen look dirty
THE INSIDE SCREEN ON THE V3 IS ACTUALLY MADE OF A SOFT FLEXIBLE PLASTIC. YOU CAN REMOVE THE GLASS WITH SOMETHING AS SMALL AS A FINGERNAIL. BLOW IT OUT AND STICK IT BACK ON.
Dec 05, 2009 | Motorola Mobility RAZR V3
Razr V3 water damage
Sounds dire. If you look inside the back of the phone, there should be a small spot that turns from white to pink when the phone gets wet. If that spot is bright pink, most repairers won't even bother trying to fix it. Best off buying another phone!
Apr 07, 2009 | Motorola Mobility RAZR V3
White/ Blank Screen
You need to replaced the LCD and flexcable on the phone.
Jun 27, 2008 | Motorola Mobility RAZR V3
Screen on razor v3c
you have to change the screen (LCD)
Dec 24, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Razor screen went blank
i tried some electrical contact cleaner (brake cleaner WAL-MART .89 cents) on the hinges. Open ti back and forth several times. NOTE: do not spray alot, just a little at a time. Then it got squeaky and started working. Then I sprayed a little WD-40 on the hinges and it works fine.
Nov 16, 2007 | Motorola Mobility RAZR V3
Motorola razr v3 (black) screen has white blank
Well i suggest that you take the case of your phone and have a look at your screen maybe some of the screws have gone missing or the screen has just worn itself out? . Note youll need a t6 or t7 torx screwdriver to do this , hope i helped
Oct 17, 2007 | Motorola Mobility RAZR V3
White screen`
the white and black screen issue on the Razr V3xx can be a bad LCD. If the LCD is good then the issue is on the main board. The most common failure is broken contacts on FL6505 and FL6504. resoldering might hold up for a while but replacement is the best option.
the side view clearly shows the damage to the filter. this is only visible after the solder is removed.
hope this helps.
Oct 07, 2007 | Motorola Mobility RAZR V3
White screen on Motorola RAZR
I use to work for Cingular Wireless and this happened often. Try opening and closing the handset a little forcefully. It should re-seat the screen onto the contacts. If that doesnt help, have it replaced since its new. Best of Luck.
Sep 05, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Phone won't turn on/charge
Kikimenor: Advise. If this is your 3rd RAZR V3, you must encourage Cingular (Now is the new AT&T) to replace your whole unit with another model. A friend of mine exchange his phone 4 times, until Cingular replace it. Motorola had too many problems with RAZR phones and that's why they launch quickly the SLVR L7. They still producing the RAZR, because users love the style and shape of the phone, but reality is that Motorola had several heavy issues with RAZR (Bluetooth, batt, microphone, etc.) If you're paying for an insurance on your unit, encourage them to replace it. SithPitt
Jul 04, 2007 | Motorola Mobility RAZR V3
Cant recieve voice messages screen turns white
let we try this,,back your phone up 1st, , then we do this...go to menu ,settings, initial set up, master clear ,, code (000000)...let me know if it works... tnx...
Jan 27, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
44 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
