Question about Weather King 10AJA2501AH Air Conditioner
AC fan not blowing/ Honeywell T87F thermastat
I have a Honeywell T87F thermastat that is turning the air conditioner on (you can hear it) but not the house fan. I can turn the fan on via a button in the basement but auto does not work. This just started acting up last night.
  • idoji Jun 27, 2008
    Okay, I have tried the test and the fan does not turn on still, so I must have something defective in the control board.
If you have a voltmeter that checks capacitance, check the capacitor ( silver looking battery) that is mounted on the side of the blower housing in the furnace. You need to take the wires off!! A bad Cap will slow down the fan and if its blown/dead the fan will not run.
If youre more than 1 MFD off the rating stamped on the capacitor, Replace it.
Posted on Jul 08, 2008
  • 149 Answers
Ok heres a test i want you to do carefully remove the thermostat cover and you will see the 3 wires one is red the other one is yellow and a green one turn off the thermostat and remove the wire from thermostat labeled G and carefully touch it on the R terminal if fan turns on, thermostat is defective if it dosen't turn on there should be a fan section on control board that's defective
Posted on Jun 26, 2008
In Fan mode, fan works; but in AC mode, I can hear the normal AC sounds, except the fan never turns on. This is the fan in the lower half of the unit in the inside of the house, which blows the air...
on a call for air conditioning your therrmastat brings the indoor fan on and the out door unit at the same time. Since your fan comes on in "fan" mode, it sounds like you need a thermastat. For temp. cooling just turn your fan switch to "on" and turn system switch to cool and set desired temp. System will cycle off and on but fan will not shut off until fan control is set back to "auto". I suggest replaceing thermastat
Aug 16, 2011 | Heating & Cooling
My Trailer AC doesnt cool below 75 degrees. I feel no differnce between the coldest setting on AC than on the Fan cycle. I cannot hear the cooling system kick on at all.
If you don't here the compressor kick in after about 3 min then the thermastat is not telling the compressor to com on, or the control board is not telling the compressor to come on. The power can be traced from thermastat to the control board and will have a 12volt feed on the yellow wire at the control board with compressor mode on. From there it is 120volts the control board has a relay that turns on the compressor. the compressor capasiter can cause the compressor not to come on, normally it will have burnt wiring.
Aug 02, 2010 | Dometic 57915531 Air Conditioner
Ac turns on and the fan blows air but not cold air. When switching from fan to ac mode i hear a buzz sound like it had switch to ac but still its not blowing out cold air. Any suggestions?
mcdevito75, Needs service either a chrge of freon or the need for a new thermostat and That is what it sounds like to me, (the compressor could be bad also, the buzzing sound) hope not expensive repair.
Jun 23, 2010 | Amana PBC101A00A Air Conditioner
My AC quit blowing cold air all of a sudden while I was out of town - my wife turned off the compressor and turned the fan to on, thinking it may be froze up - 2 hours later still no cold air - service...
Depending on how it's wired, she might have turned it off and on again and popped a breaker. It could be wired with a breaker for the fan motor and a breaker for the compressor.
Oct 07, 2009 | Honeywell Heating & Cooling
Honeywell manual thermostat t87F, how to take off dial
ring around clear number section pulls off then there are three small flat head screws undo those aand the outer face with the dial comes off. if you are just trying to clean out the clear dial from bugs or small debris simply lift with small screwdriver and blow into it.
Nov 22, 2008 | Honeywell Heating & Cooling
AC Problem
possibly faulty fan or fan relay also check that 24 v are coming out of the transformer
Sep 03, 2008 | Carrier 38CKC036 Air Conditioner
My Honeywell T87F Thermostat doesn't shut the A/C off when the temp in the room gets down to the Thermostat setting. I have it set on COOL and AUTO. I have to shut the A/C off; then later turn it back on...
Remove the thermostat and disconnect the r and y connection. If the A/C continues to run ya got a short in the wiring somewhere. If it shuts down then your tstat is hooped.
Jun 09, 2008 | Honeywell Heating & Cooling
My air conditioner keeps blowing warm
Help us by giving us more info. Is it a window air conditioner? Make and Model number? Have yu checked the air filter?
Aug 27, 2007 | Honeywell Programmable Thermostat Heater
Weather King 10AJA2501AH Air Conditioner Logo
334 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
