Dvd rom not reading any disc
I just bought this computer yesterday and it is not reading any disc but I can hear it spinning and trying to read the disc. If I have to I will just buy new dvd rom since their cheap.
  • rocky1979 Jul 24, 2008
    I Have same problem with my laptop dell vostro 1700, i can also hear spinning sound, and also can see CD drive icon. when i click on CD drive says please insert CD or DVD. This CD/DVD burner brand new and not reading disc.
    Please help.
    Sergeant:
  • 390 Answers
No need to be hasty. Need to eliminate issues one by one. Is the pc brand new or pre-loved new to you. This is a big point, as you may not have the drivers on disc, and have to download some. Usually the most common error is that in transport with older pcs the dvd drive can become unnatched inside the tower, but if you can hear it spinning, some power must be getting through. Is the icon for the drive appearing in my computer? Check for yellow exclamation mark under driver list in control panel and post any error codes you see, this can help find a solution. (this is all located under hardware, under control panel) post back after you have tried this.
Posted on Jun 29, 2008
DVD/CD ROM is not working
When you place a disc in the drive can you hear the disc spin up, if not then the DVD drive maybe faulty.
Try re-seating the DVD drive and if it still does not work then it is faulty and needs replacing.
Jan 29, 2013 | Computers & Internet
JLMS DVD-ROM XJ-HD166 DVD/CD ROM Drive does not acknowledge disc in drive after having the computer set back to factory
Does it not acknowledge dvd disc only or cd or dvd both. If it doesn't read the dvd disc, or able to play dvd disc, but able to exlpore regular cd's, then you have a codec error, and you need to download a dvd codec like powerdvd for it for your system to play dvd disc. Check to see if your dvd-rom drive appears in the "my computer" window, if it is there, but wouldn't be able to play anything, then it could be a driver issue. so make sure in the hardware , the drivers is installed and working properly. If it is working properly and driver is installed, then you got a bad drive, the optical laser lenses isnt reading or the spindle ain't working anymore if you don't hear disc being loaded when inserting the disc.
Jan 30, 2011 | Lite On XJ-HD166S Internal DVD Drive
Wont read disc
Hello there... Sony seems a choosy brand so it looks like your disc is not recognized by it. Check also your disc for scratches or you just need to clean your disc first before you can use it. Try it. If this doesn't help, try inserting your disc to other CD-ROM. See if your disc is okay. Hope this helps...
Ai-ai :)
Dec 03, 2009 | Sony Computers & Internet
HP 530 laptop. Vista Home Basic OS. 18 months old.
the motor went bad in the drive if its not even trying to spin the disc. The only option at this point is to get the drive replaced.
Sep 04, 2009 | HP Pavilion dv6000z Notebook
I am having a cd rom i cannot read dvd discs. please help me to make my cd rom writable and read dvd discs
how can a CD ROM read DVDs?
you need to buy one, go for external DVD ROM/writer. Should not be very expensive.
Rate me Rate me
Mar 24, 2009 | Computers & Internet
No disc present
Try running a cleaner disc in the unit if that doesnt work try the following.
Starting at my computer... Right click on my computer icon.
Go to properties.
Then Hardware tab then go device manager. Right click on cdrom in device list. Select uninstall then reboot the computer. If this doesn't help replacing the unit will be necessary.
Jan 19, 2009 | LG GCC 4480B CD-RW/DVD-ROM Burner
Lite-on Combo SOHC-5236v
You may be using the wrong type of DVD format. Some DVD-ROMs and players will only read certain discs. i.e. DVD+R, DVD-R, DVD-RAM. If you are trying to read a DVD-R disc that was bought blank, and then had things burned to it, it may be that the disc wasn't finalised after burning. You could always try updating the Firmware version by downloading it from the website.
Nov 08, 2008 | Lite On (SOHC5236V) CD-RW/DVD-ROM Combo...
My Computer Wont Read DvD's or CDs!
Is the CD drive display in my computer? yes
then clean up your CD/DVD rom for there is dust in it, specially on the lazer lens that let the rom read the CD/DVD.
If no, then; Fix some cable connection towards your CD/DVD rom for it was lessen.
If not fix the problem verify the disc if it is readble by your Rom. Please try another disc in your Rom.
if same happen, then maybe its time for a new CD/DVD ROM.
one last try:
try your new purcahse disc in another computer that is compatible with your disc.
hope this help, melnavz
Feb 05, 2008 | Dell Dimension 3100 PC Desktop
DVD ROM
Have you tried using a lense cleaner disk?
Can you hear the disk spinning at all?
Is the problem with both cd and dvds?
What kid of disk are you trying to play? Some dvd roms will not read dvdrw disks.
Dec 28, 2007 | Dell Inspiron 2200 PC Notebook
R40 DVD Read Problem
Unable to read a CD-R or other recordable disc. DVD recordable discs - If you have a DVD recordable disc and are unable to get it to read verify that the DVD drive is not a Gen 1 DVD drive and/or that it .
Computer DVD Support The DVD technology is very different from the technology used in standard CD-ROM drives. DVD uses shorter wavelength lasers to read smaller pits and lands.
Computer CD-ROM drive help and technical information. However, DVD-RAM discs cannot be read by standard DVD-ROM drives because of the differences in both reflectivity of the medium and the data format.
Read & follow instructions/Please dont for get to Vote/Thank You.
Dec 23, 2007 | IBM ThinkPad R40 2722 Notebook
Computers & Internet Logo
521 people viewed this question
David Payne
David Payne
