Question about Canon PIXMA MP780 All-In-One InkJet Printer
Faxing when we fax, we have a dial tone, hear the recipient fax response yet after 30 seconds of transmitting it will not go thru and the error is ERROR TX REPORT at top of page. TX FUNCTION IS NOT COMPLETED tx/rx no 0293 result nh 005
  • kssoccermom Jun 26, 2008
    what is a hard reset and how do I do that? I have rebooted numerous times.
    thanks
  • kssoccermom Jun 27, 2008
    That did not fix it, but thanks anyway.
    Guru:
  • 1,894 Answers
Did u try to do a hard reset to clear this error?
if nt try it please
Posted on Jun 26, 2008
  • dewan nafees ahmed Jun 26, 2008
    you must leave the unit unplugged from the power for few hours.
    and then start the machine again.
    this is called hard reset.
  • dewan nafees ahmed Jun 27, 2008
    hope it helps.
    thank you
    dont forget to accept MY solution if u go by it.
    feel free for asking any doubts u have.
    thank u for ur cooperation.
    good luck for getting fixed soon
HOW TO SEND A FAX
You can send a fax in a variety of ways. Using the control panel, you can send a black and white or color fax. You can also send a fax manually from an attached phone. This allows you to speak with the recipient before sending the fax.
To send a basic fax (single- or multiple-page black-and-white fax) by using the control panel.These features allow you to control the pace of your dialing. They are also useful when you want to use a calling card to charge the call and you have to respond to tone prompts while dialing. NOTE: If you need printed confirmation that your faxes were successfully sent, enable fax confirmation before sending any faxes. TIP: You can also send a fax manually from a phone or by using monitor dialing.
1. Load your originals. NOTE: If you are sending a multiple-page fax, you must load the originals in the document feeder tray. You cannot fax a multiple-page document from the glass. 2. Enter the fax number by using the keypad, press Speed Dial or a one-touch speed dial button to select a speed dial, or press Redial/Pause to redial the last number dialed.TIP: To add a pause in the fax number you are entering, press Redial/Pause, or press the Symbols (*) button repeatedly, until a dash (-) appears on the display. 3. Press START FAX Black or START FAX Color. • If the device detects an original loaded in the automatic document feeder, it sends the document to the number you entered. • If the device does not detect an original loaded in the automatic document feeder, the Fax from glass? prompt appears. Make sure your original is loaded print-side down on the glass, and then select Yes.TIP: If the recipient reports issues with the quality of the fax you sent, you can try changing the resolution or contrast of your fax.
Send a fax manually from a phone You can send a fax from a telephone on the same phone line if you prefer to use the keypad on your phone, instead of the keypad on the control panel of the device. You can do this by plugging in a phone into the 2-EXT port on the back of the device. When you send a fax manually, you can hear the dial tones, telephone prompts, or other sounds through the handset on your telephone. This makes it easy for you to use a calling card to send your fax. Depending on how the recipient has their fax machine set up, the recipient might answer the phone, or the fax machine might take the call. If a person answers the phone, you can speak with the recipient before sending the fax. If a fax machine answers the call, you can send the fax directly to the fax machine when you hear the fax tones from the receiving fax machine.
1. Load your originals. NOTE: This feature is not supported if you load your originals on the glass. You must load your originals in the document feeder tray. 2. Dial the number by using the keypad on the phone that is connected to the device. NOTE: Do not use the keypad on the control panel of the device when manually sending a fax. You must use the keypad on your phone to dial the recipient's number. 3. If the recipient answers the telephone, you can engage in a conversation before sending your fax. NOTE: If a fax machine answers the call, you will hear fax tones from the receiving fax machine. Proceed to the next step to transmit the fax. 4. When you are ready to send the fax, press START FAX Black or START FAX Color. NOTE: If prompted, select Send Fax, and then press START FAX Black or START FAX Color again. If you were speaking with the recipient before sending the fax, inform the recipient that they should press Start on their fax machine after they hear fax tones.
The telephone line is silent while the fax is transmitting. At this point, you can hang up the telephone. If you want to continue speaking with the recipient, remain on the line until the fax transmission is complete.
Send a fax using monitor dialing Monitor dialing allows you to dial a number from the control panel as you would dial a regular telephone. When you send a fax using monitor dialing, you can hear the dial tones, telephone prompts, or other sounds through the speakers on the device. This enables you to respond to prompts while dialing, as well as control the pace of your dialing. TIP: If you do not enter your calling card PIN fast enough, the device might start sending fax tones too soon and cause your PIN not to be recognized by the calling card service. If this is the case, you can create a speed dial entry to store the PIN for your calling card. NOTE: Make sure the volume is turned on, or you will not hear a dial tone. To send a fax using monitor dialing from the control panel
1. Load your originals. NOTE: If you are sending a multiple-page fax, you must load the originals print-side up in the document feeder tray. You cannot fax a multiple-page document from the glass. 2. Press START FAX Black or START FAX Color. • If the device detects an original loaded in the automatic document feeder, you will hear a dial tone. • If the device does not detect an original loaded in the automatic document feeder, the Fax from glass? prompt appears. Make sure that your original is loaded on the glass, and then select Yes. 3. When you hear the dial tone, enter the number by using the keypad on the control panel. 4. Follow any prompts that might occur. TIP: If you are using a calling card to send a fax and you have your calling card PIN stored as a speed dial, when prompted to enter your PIN, press Speed Dial or a one-touch speed dial button to select the speed dial entry where you have your PIN stored. Your fax is sent when the receiving fax machine answers.
Apr 01, 2011 | HP Officejet Pro L7680 All-In-One Printer
I have a Brother mfc 290c. My problem is it won't send faxes, it keeps saying "no response, busy" I have a duet line. I have tried every combination in the book but still can't seem to find the solutions...
If you get the "busy/no response" message it is because the fax machine does not get a response when it tries to dial out.
Make sure you have a dial tone by pressing the "hook" button. If you do not have a dial tone, make sure the phone line is connected to LINE on the machine.
If you have a dial tone, try dialing the fax number. If you hear a recording, there is a problem with the line.
One of these two possibilities is causing the problem.
Thanks,
Pat
May 12, 2010 | Brother Office Equipment & Supplies
Winfax Basic
If you have the fax # correct, than it is the responsibility of the fax recipient to correct the situation. You cannot make a parametrical changes to someone elses fax machine. Thank you, Dana
Jan 18, 2010 | Symantec WinFax Pro for PC
None of our faxes are going out and we receive error number 87
set the fax so you can hear dial tone... if no dial tone then check the fax line.... if fax line plugged in... plug it out of the fax and plug into a phone... if still no dial tone then change fax cable... if dial tone... then call your cell... if static... fax wont work call phone company... if you get a funny signal call phone company...
Dec 10, 2009 | Office Equipment & Supplies
Problem: Busy/No Response on all outgoing faxes
Put the document you want to send into the transmit tray, pick up the handset, listen for a dial tone, and then dial the # on the keypad..
It should ring just like any other phone. When the machine on the other end picks up and you hear the tones, press the start button.
Anything other than fax tones on the other end, it is not your faxes fault.
Nov 05, 2009 | Brother IntelliFAX 2800 Laser Fax
Cant send a fax
Confirm dialing the correct fax number?
Any 0s to get an outside line, any special area codes?
What happens when you try to send a fax, can you hear a dial tone? can you hear the fax ringing? can you hear a response from the recipiant?
Jul 17, 2009 | Lexmark F4270 Plain Paper Inkjet Fax
Sending Faxes
there is no need to change the setting.just feed the document to be sent and dial the number of the recipient.after hearing the fax tone press enter key
May 29, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
HP officejet 7210 fax error
HP Officejet 7210 All-In-One InkJet Printer
Error code: 405
When I send a fax I have a dial tone and the fax feeds through, I hear the other end answer it says it is sending and then I get the printed page that says: "A communication error occurred during the fax transmission."
Oct 29, 2007 | HP Officejet 7210 All-In-One InkJet...
I can't fax! BUSY/NO RESPONSE
go into menu
go to fax settings
find send
click auto not manual, please make sure that when you push the hook key you hear a dial tone. always reminder that every fax machine has the capablitiy of either dial or tone. now if everything is set up properly  the problem will be in the tx portion of the board. if you can link up with somebody close to you and try to transmit back and fourth that will let you know if it is their problem or your. it may not be your problem.
Oct 21, 2007 | Brother IntelliFAX 1840C Plain Paper...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
581 people viewed this question
old marine
old marine
