I plug the mybook in, it spins for about 5 seconds and blinks blue and then powers off.I plug the mybook in, it spins for about 5 seconds and blinks blue and then powers off.
I have this same HD, but the 750GB model. The other day I unhooked it to pack it up, and ended up not having room in my backpack and left it behind. I came home last night and plugged it back into my laptop, and it will not turn on, despite the green light on the power adapter being on and everything being plugged in correctly. I've had it for about 9 months, I'm not sure if it is still under warranty. I'll try the advice given here, but I wanted to post this as it appears to be a running issue with this model of external hard drive.
You can't post conmments that contain an email address.
I can recommend one of two things here. One is to contact Western Digital and see what they can do about repairing the hard drive (within warrenty) and any possibility to get your data off the hard drive. Make sure you pay them NOTHING. Now, the other option may void the warrenty, so I'd recommend contacting them first. Basically what you need to do though is to open up the case to the hard drive, and you will most likely find a cable that was pulled out of a metal ring which was inside a plastic plug connector. From what I gather, it doesn't have a stable power connection, so that seems most logical. Now, if you droped it, knocked it over or something, then you might be screwed. But most likely, even if it was knocked over, the data is still easily recoverable.
TRY TO LISTEN.IF THERE IS SOME THNG RUNNING.IF NOT >SWITH OFF >CHANGE THE CABLE >TRY AGAIN >IF YOU DONT HAVE NEW FIT THE CABLE TIGHTLY.ANY HOW YOU SHOULD RECOCKNISE TO THE MOTHER BOARD.IF *********** BOARD RECOCKNSE DOWNLOAD STELLER PHONIX.JUST PASTE YOU CAN RECOVER EVERY DATA.
check your external drive is set to slave and not master. some have a switch to change or dip pin to set. if not problem unplug external drive turn on computer and boot up, than hook up the external drive the computer will see it and set it to slave in bio s.
If you're connecting a known-good power supply to the MyBook, and it's not turning on... I suspect that the MyBook has died. You should replace it or have it serviced. If the data on it is very important, it might be worth taking the drive apart and removing the hard drive inside and trying to recover data. If the data isn't important, I would say the MyBook is dead. Sorry.
The essential edition is a single drive unit. if you have another computer you could pull the drive out of the enclosure and connect it directly to the computer to retrieve your data. I use an external usb 2.0 to IDE/Sata adapter that connects to the drive and the PC. These can be found online for $10.00-$15.00. This adapter has saved me many times in the past. The other option is to connect the MyBook to another computer (Mac or PC) and see if that computer will read the drive correctly or not.
Try using the western digital knowledge base info to help you resolve the problem...click here.
Otherwise, we need the full model # and the OS you're using to give better solutions....
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
I plug it in and it flashes a blue light, the drives spins for about 5 seconds, and shuts off.
