Question about Sony Cyber-Shot DSC-M1 Digital Camera
Swing out arm on camera
Help! The swing out arm on my camera is sooo loose and it looks like it hanging by a wire or two. Oh, and naturally the camera is not working.
I just fixed mine, it turns out to be pretty easy!
1) Remove 5 case screws: two on either side of the strap, two on either side of the "CAUTION" sticker, and one near the serial number.
2) There's one last screw on the bottom near the mounting/tripod hole. To remove it I had to pry the casing SLIGHTLY away first.
3) Remove the casing.
4) The shutter, flash, and large capacitor are free-floating and can be CAREFULLY pulled back, so you can get to where the swivel mechanism is. You'll see a bundle of wires going through a hole.
5) Surround the hole are 3 screws which are loose. Tighten them up.
6) Put it back together -- done!
Posted on Aug 08, 2008
WHAT IS THE PRICE OF IT AND WHERE CAN I BUY IT AT
Posted on Jul 13, 2008
WIRING FOR CID brush swing boom
    Wiring Harness for swing boom - Skid Steer Genius
    www.skidsteergenius.com/blogs/news/.../wiring-harness-for-swing-boom
    Aug 21, 2015 - Posted by Robert Leib in bobcat 7 pin cable for swing boom, CID ... The CID Swing Boom, Prowler Swing Arm & Spartan Articulating Brush ...
    WIRING FOR CID brush swing boom - Fixya
    www.fixya.com/cars/t26003553-wiring_cid_brush_swing_boom
    4 hours ago - WIRING FOR CID brush swing boom - Cars & Trucks question. images for WIRING FOR CID brush swing boom
Dec 11, 2015 | Cars & Trucks
Attach bagger to john deere d140
While standing at back of mower with the bagger hood in your hands. The black support arm is hanging down, positioned at the back of the mower. At the bottom of the black support arm are two tangs with a gap between them (gap is 2"-3"). The tangs will be inserted into two slots on the towing frame. That is the black panel of the back of the mower. They will not be centered; rather they will be offset to the right side of the tow frame, about mid way up the back.
Lower the hood support so the tangs are horizontal, or parallel to the ground. Once parallel to the ground they will slide into the slots. After they are in the slots, while holding the black support arm steady, raise the two swing arms up to the seat. After raising the swing arms (light brassy color, V shaped connecting rods) then raise the black support arm with the tangs held in the slots. As you raise the black support arm vertically the swing rods will move forward, over the top of the fender, and align with two retaining holes.When the hood is level with the top of the seat you will be able to insert the ends of the swing arms into the holes in the fenders. This will complete installation of the support for the bagging hood. Now follow the locking instructions below.
Note: prior to starting this procedure you may have to remove a spring clip and locking pin (about 6" long and 1/4" round) that runs through the black support arm. It runs right to left through two holes in the support arm, the spring clip locks it in. This pin may be supplied uninstalled. The function of the 6" locking pin is to keep the swing arm in the fender holes after you have everything in place. It must be removed to perform the above installation. After the installation is complete insert the lock pin, right to left, pointy end goes in first, above the swing arms where they meet the black support arm, then insert the locking spring clip in the tiny hole of the locking pin. This locks the swing arms in place.
Oct 12, 2014 | John Deere Garden
Natures purest swing won't swing
I have the same problem. Works fine then next time I go to use it it won't work.
Feb 21, 2013 | Summer Infant 66010 Nature s Purest...
I have aligned the chain (every couple of months I have to tighten the chain , does it stretch that much!) and when I'm driving the chain noise is louder than the engine . Is this normal??
Raise the rear wheel off of the ground. Spin the rear wheel by hand while running the chain over your hand (wear a surgical glove or use a rag). If the chain gets tight and then loose it has stretched and needs to be replaced. If it is an older Honda (70's), unbolt the rear shocks and see if the swing arm moves from side to side. If this is the case you also need new swing arm bushings. Another sign that the swing arm bushings are bad is if the chain is banging against the swing arm while you are driving down the road.
Jul 10, 2011 | Honda CB 350 F1 Motorcycles
My Hp colorlaserjet 37ooDN is showing the error : 59.C0 Pl. HELP
59.C0 Error Displayed on Control Panel Remove all the print cartridges from the printer so the right swing guide will be visible and check for the parts described in the photos below.
If the right side swing guide does not go all the way back, the 59.C0 alienation error will be displayed on the control panel. A plastic part on the swing guide could be missing.
See photo below where the three circles are on the right side of the printer.
Figure 1: Right swing arm assembly
37001See photo for details of the part. Call-out 1 in the photo below shows the parts in place, while Call-out 2 shows the missing part. (The part looks like an upside-down t.)
Figure 2: Missing part causing 59.C0 error
370021 - Part in place
2 - Part missing
Another cause for a 59.C0 error can be the black sliding lock is broken, out of place, or missing the spring. (See figure below) This can cause 59.C0 errors or 10.92.XX errors.
Figure 3: Right swing frame assembly
37003Replace the swing guide. Please look for the missing part in the printer so it will not cause other issues from movement to other parts of the printer.
If the part in the call-out is present, close the door slowly and observe the right side swing arm. It should close uniformally with the left side swing arm. If not, arrange for service on the printer and replace the right swing arm.
Jun 20, 2011 | HP LaserJet 3700dn Printer
I have the Eddie Bauer Classic Wood Swing that wont swing. The music still plays but the swing function will not turn on. I replaced the batteries just in case and that still did not help. What could be...
take apart the side with the on and off switches take apart the swing arm, remove the plastic cover over the motor look at the
blue wire from motor thru the plastic all the way to the contrl board prob broken where it goes thru plastic from motor looks like it happens alot
Sep 07, 2010 | Eddie Bauer Baby Gear
Laserjet 3700 got 59.C0 error
Figure 1: Right swing arm assemblye755e62.png
6349049.gif 1 - Part in place
2 - Part missing
i think it solves your problem
if you have any problem regarding this issue leave a feed back,we will glad to assist you
good luck
Sep 10, 2009 | HP LaserJet 3700dn Printer
Swing arm too loose
What I have doen in the past is to take the compression nut off. Wrap teflon plumbing thread tape around and between the two o rings and tinghened the compression nut back down,tightening the worn swing arm joint.
Mar 11, 2009 | Delta 16955-SSSD Stainless Steel Victorian...
Drive chain adjustment
To adjust the chain you need to make sure you make the adjustment with the swing arm parallel to the ground, (this is the tightest point in the arc of the swing arm moving rotation), at that point you want to be able to put two finger between the chain and the swing arm at the swing arm pivot bolt. This will insure proper adjustment every time. The best thing to do is have somebody sti on the bike off the stand to make sure the swing arm is at its MAXIMUM arc, otherwise you stand a significant chance of over tightening it and this can and WILL cause SERIOUS damage to your engine. You will rip the output shaft bearings out of the center cases.
You also want too make sure you have proper wheel alignment as well. There are marks on the rear of the swing arm for adjusting the chain, make sure you have the marks on the adjusters in the same location on BOTH sides of the swing arm.
Please let me know if you need further assistance.
Regards,
RSelvy
Dec 17, 2008 | 2005 Suzuki RM-Z 250
Fisher Price Nature's Touch Cradle Swing - Not Swinging
Parts for your model can be found on amazon, here:
Amazon com fisher price swing replacement parts. I hope this helped you. Best of luck
Oct 03, 2008 | Baby Gear
Sony Cyber-Shot DSC-M1 Digital Camera Logo
224 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
