Question about Pentax Optio 30 Digital Camera
Optio V10 Won't stay on.
When I turn my camera on, it momentarily comes on. The display says "Green Mode" and "auto Picture". After about 3 seconds it automatically shuts down.
I changed batteries to check, but that is not the problem. The battery is good.
Help, please!!
Bill
    Genius:
  • 1,447 Answers
Try to hook up the camera to a power surge if you have an adapter so that when you turn it on you can navigate on the settings and camera wont shut off, check on the settings if there are other mode aside from Green mode and select it, chances if there is no other setting, you are having an issue with your camera, hardware issue. call manufacturer's support line for warranty verification. best i got. thanks for using fixya!
Posted on Jun 26, 2008
    Genius:
  • 3,422 Answers
I suggest you to replace it with new batteries.
  • 1 more comment
  • Priya darshan Jun 26, 2008
    You can try switching over to 2500 mAh Nickel Metal Hydride rechargeable batteries and you will see a difference.
    Digital cameras with zoom lens need more power than what can be supplied by ordinary batteries.
    Few troubleshooting steps you can try before replacing the new batteries:
    1)The battery cover or CF card (SD card) slot cover is not securely closed
    Most
    cameras have a lock mechanism on the battery cover. The camera will not
    turn on if the battery cover is not locked or securely closed, or if
    the CF card (SD card) slot cover is not securely closed. Make sure
    these covers are securely closed.
    2)Try removing the batteries and the mem card for few min. and then insert only the batteries and see if it turns on.
    3)When
    camera does not operate with a brand-new alkaline battery (for cameras
    that use AA-size batteries) or with a fully charged rechargeable
    battery, the terminals may be dirty.
    Polish
    the terminals with a dry cloth and make sure the terminals are clean.
    If the terminals are covered with oil from your skin or similar matter,
    this may cause poor contact and power may not be fully supplied to the
    camera.
    Also, polish the battery charger terminals with a dry cloth before
    charging the battery. If the terminals are covered with oil from your
    skin or similar matter, this may cause poor contact and the battery may
    not be fully charged.
    If you still face the problem then switch to new batteries.
I'm trying to set th time and date on my camera but when I hit the menu button the yellow lock appears how can I get rid of this so I can set time and date correctly please
Hi Keith, The link below is the user manual for the Pentax Optio E30 Digital Camera, On page 56 it says
• In Green Mode, you cannot change the information displayed on the LCD monitor by pressing the 4/W button.
• You cannot use the [A Rec. Mode] menu or Capture Mode Palette in Green Mode. If you try to display the [A Rec. Mode] menu or Capture Mode Palette, - (key lock icon) appears.
• If you switched to Q mode from Green Mode, you cannot display the [H Setting] menu by pressing the 3 button. If you try to display the [H Setting] menu, - (key lock icon) appears.
• When the camera is turned off in the Green Mode, it turns on in the Green Mode next time the power switch is pressed.
THIS IS YOUR CAMERAS USER MANUAL.....CHEERS..
http://www.camera-usermanual.com/manuals/pentax/Pentax_Optio_E30.pdf
Mar 27, 2016 | Pentax Optio E30 Digital Camera
How do i remove green mode on a camera pentax RS1000
Pentax Optio RS1000 Digital Camera Green - Questions ...
www.fixya.com > ... > Optio > Pentax Optio RS1000 Digital Camera
turn green mode off my camera how to turn offf green mode just hit the green button, its the delete pic button as well, but it can be used to turn green mode on ...
Oct 27, 2015 | Pentax Cameras
Pentax Optio M20 in Green Mode switches off after turning on
Try to press & hold down the Green button (the trash can button on the bottom right corner) & see if it gets u out of green mode.
Jul 27, 2009 | Pentax Optio M20 Digital Camera
Pentax Z10 won't turn on.
Press and hold the playback button for 2 seconds. The camera should turn on and be in playback mode. Switch to Camera Mode by opening the from slider cover. Hope that fixes it. See Pentax Z10 Manual Page 34.
http://www.pentaximaging.com/files/manual/OptioZ10.pdf
Cheers Jon. Sydney Australia.
Jun 10, 2009 | Pentax Optio Z10 Digital Camera
View looks normal then image comes out very bright
Your point n shoot camera has an ISO adjustment in the menu. Be sure that is set to no more than 400 indoors and no more than 100 outdoors.
If it has something called exposure Value or Ev, set that to zero.
Or, if you really want to see if the camera is not working properly, set it to the green auto mode and take a picture. If in auto mode, it still comes out over-exposed there is probably a problem with the camera.
May 08, 2009 | Pentax Optio S50 Digital Camera
Pentax Optio M20
Found the following on a website about these cameras...
http://www.digitalcamerainfo.com/content/Pentax-Optio-M20-Digital-Camera-Review/Modes.htm
"The second, and previously mentioned automatic mode, is the Green mode that restricts the camera controls to two flash settings, three AF options, zoom, and a self-timer setting. This mode locks out the menu systems, manual focus, mode menus and other options. It’s definitely easy to use, as all one can really do is point and shoot."
This may be a internal software confusion problem. If it is, the following may help.
Make sure your buttons or dials are not on AUTOMATIC, that appears to set the green mode.
I think I would remove the batteries. Next, if the camera has a small battery (similar to the bios battery in computers) remove that as well. Let the camera sit over night. You will need enough time for the capacitors to discharge. Then put the batteries in again, and try.
Jun 30, 2008 | Pentax Optio M20 Digital Camera
Optio M20 Camera: Press on/off button to power up camera, the camera opens the lens cover, turns on a red led inside the lens, cycles the lens out and back in,then makes about 5 little popping noises. The...
i got it!!! on my cam i hold down the menu button at the same time power on, it will showup a " ver 1.00" and lens move a little maybe u have to do it 2 times but second time it should work
Mar 29, 2008 | Pentax Optio M20 Digital Camera
Pentax optio m20 .. on-off immdly
Mar 25, 2008 | Pentax Optio M20 Digital Camera
Pentax M20 Green Mode Stuck
i just had the same problem....
here's how i fixed it...
turn it on... then as it's loading up... hold the "menu" button
i think this forces it to stay on...
i changed the green button to be something else... not green mode
then i just turned it off and on again
Aug 20, 2007 | Pentax Optio M20 Digital Camera
Pentax Optio 30 Digital Camera Logo
91 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
