Question about AT&T BlackBerry Curve 8310 Cell Phone - Red
KEYBOARD PROBLEM MY KEYBOARD IS NOT WORKING PROPERLY IF I PRESS CERTAIN BUTTONS I GET OTHER LETTERS THAN THE ACTUAL BUTTON AND THE BACK BUTTON SHOWS H'S
  • prabhatkyada Jul 11, 2008
    My Blackberry 8310 curve key board is not working properly. When I press 6 the letter J appears on the screen, when Delete / Enter / A / S are pressed letter JK appears on the screen.
    Can anyone help me out or I have to throw this piece of scrap into the waste basket not for recycling!!
  • sexcseka Mar 25, 2009
    I have the exact same problem... the only thing I can connect the problem to is that I went jogging this morning and it started raining while I had my phone in my pocket. It felt a little moist on the backside but didn't appear to have a problem until it started giving me "JK" for every a and enter and delete I pressed. Someone please post a solution, thank you!
My Blackberry 8310 curve key board is not working properly. When I press 5 nothing happens on the screen, when i press 4,7,and some of the letters dont work at all till i move them arround .
Posted on Jul 22, 2008
Emachines n450
I bought a used laptop with some missing letters on it as well. What I did, was simply use my Brother P-touch labeler and printer out capitalized letters. Then peel off back and stick right on keys. A simple answer.
Feb 13, 2014 | Computers & Internet
Keys not working
Either the keyboard or the ribbon cable connecting the keyboard to the mainboard is damaged or not fully connected.
The most likely problem is the keyboard is defective. They are not very hard to replace. In most cases you have to remove the button cover above the keyboard and then the screws for the keyboard will be accessible. You can get a new keyboard off the Internet (EBAY or such) or direct from HP.
Aug 22, 2012 | Compaq Presario CQ62-112TU
Letters on keyboard are producing numbers instead of letters, letter k gives 2, letters u gives 4 etc
that is the keypad for a keyboard to get back those letter you will need to press the Fn button and on the top of the keyboard where there is a list of F button press the one that looks like a keyboard. if that doesnt work try Fn and num lock
Jul 07, 2011 | Computers & Internet
Keyoboard when pressed shows numbers not letters
this is happening because the keyboard number lock is turned on. To fix this problem, simply press and hold "Fn" button on your keyboard, then press "Num lock" (FN + NUM LOCK).
This will certainly solve the problem.
Good luck.
Dec 23, 2010 | Acer NSK8458AN Keyboard
Letter appeared automaticcally
This sounds like a stuck key. Make sure there is nothing which may cause this specific letter to be stuck on your keyboard. I would actually try to press on it several times pretty hard as it may release the button.
Also, if this doesn't help, try to unplug the keyboard and plug in a different one, to see if this is a problem with this specific keyboard. If the keyboard is plugged to your computer by USB, try to uninstall and then reinstall the driver.
Jan 12, 2010 | Dell Inspiron E1505 Notebook
I lost the owners manual for how to set up the dell wireless keyboard and mouse. I believe that there is a certain order i must have them found by the computer and the buttons on the back of both items...
first press the sensor button and then press your keyboard button present at the back side then press any key on keyboard you will see the word that you have typed .then again press the sensor button and then press your mouse button that is at bottom of mouse then move it you will see that the mouse will move.
Oct 08, 2009 | Dell Wireless Keyboard Optical Mouse w0147
I have a wireless Rosewill keyboard.changed the batteries now letters are repeating & some not working or working slow.Should I unplug the control box to reset?Wireless mouse not working...
You should try just re-syncing the devices. Press the sync button on the USB receiver itself (the part the plugs into the computer) and then press the corresponding sync buttons on the keyboard and mouse. It will usually be a small button underneath the device.
May 10, 2009 | Computers & Internet
Letter and number keys not working.
go to my computer>computer hardware>keyboard
click driver, then check if your device is working properly, if it is, click update driver.
Apr 20, 2009 | Microsoft Wireless Desktop 3000 Keyboard
Keyboard connectivity
Normal 0 Assuming that you have good batteries installed, turn the Keyboard over and locate the small reset/connect button on the back of the keyboard and press it. Then try to see if it is working. If not try pressing the button on the receiver and then on the keyboard. Try typing, should work okay.
Also to Rest/Connect the mouse, turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps. Bud
Nov 30, 2008 | Computers & Internet
Sony PCV-V210P PC with PCVA-KB6/U computer and wireless keyboard
Press the CONNECT buttons located on the left panel of the computer and then press the connect button on the bottom of the keyboard, to establish communication.
Aug 05, 2008 | Sony VAIO PCV-V210P PC Desktop
AT&T BlackBerry Curve 8310 Cell Phone - Red Logo
3,120 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
