Question about Dell Latitude D800 Notebook
Powers On, the middle Led flashes approx 5 times, powers off
Does this continously after swapping out system boards, the only time the leds dont flash is when the everything is disconnected off the system board, including the CPU, any suggestions?
  • 2,028 Answers
Here's a link to Dell's diagnostics, it lists light and sound errors.
The other thing you might try, is putting things back on the board one at a time. When it starts blinking you might have found it. I've had a few machines that when, going one at a time to find the issue, the problem starts, I think I've found it only to pull that part and see that it's still there, and start all over.
Posted on Jun 26, 2008
My HP D530C does not power on. The power LED flashes 4 times. What is the fault? Pls let me know asap. Thanks.
HP xw6200 Workstation - Diagnostic LED Code: Four Flashes ISSUE: When the workstation is powered on, the front LED might flash red four times, once per second, followed by a two second pause. SOLUTION: The front LED flashing four times is a sign of a power failure. To fix this issue, complete the following steps:
  1. Open the access panel, and check to see if the four-wire power supply cable is properly connected to the system board.
  2. There may be a faulty device. Locate it by removing all devices and then reinstalling them one at a time until the workstation fails. Replace the device causing the failure. Continue adding devices to ensure all are functioning properly.
  3. Verify the power supply functionality, as follows:
    1. Disconnect AC power.
    2. Remove all internal power supply cables from the system board.
    3. Plug in AC power.
      • If the power supply fan spins, and the BIST LED illuminates, then the power supply is good. Replace the system board.
      • If the power supply fan does not spin, or the BIST LED does not illuminate, replace the power supply.
Dec 13, 2011 | HP Compaq d530c PC Desktop
My tv doesnt show any images and the panel has the light of fopc on
Common problems on Sharp LCD tvs as tv it is agings,tv Power LED and OPC LED,LEDS lights flashes happen to mine Sharp tv many times and i had it two years,do this many times,tries to turn on the tv.By trying pushes the power button the remote again if OPC LED and power LED,LEDS lights flashes together.Everytimes the OPC LED and power LED lights flashes,just push the power switch on the tv remote and wait for the tv main Tuner signal board to kick in the backlight to light up tv to work.Have to do this like three or four times before the power supply board to kick it in to make Tuner signal to work.If u require to this more than 5 or 6 times the main tv Tuner signal board it is shorting out and beyond trying to kick in by the power supply board.Tries websites like, to buy a refurbish tv Tuner signal board for the replacement.
May 31, 2011 | Sharp LC-32SB24U 32 in. LCD TV
Hi, the lights on my circiut board are flashing the one on the left is on all the time and the one to the right of it flashes two times and then waits and then flashes two times again
Error Codes
A green LED indicates system faults
Steady On: System OK
Steady OFF: Board control fault or no power applied
1 Flash: Ignition failure (control in one-hour lockout)
2 Flashes: Pressure switch fault, fails open (switch is
stuck open)
3 Flashes: Limit switch open (main or auxiliary)
4 Flashes: Pressure switch fault, fails closed (switch is
stuck closed)
A yellow LED indicates flame status
Steady on: Normal flame is sensed
Flashes: As flame weakens, frequency of LED flashes
hope this is helpful.
Dec 21, 2010 | Ruud Central System Air Conditioner
Tv power led flashing 2 times and opc led flashing 1 time over and over thats it thats all i get
U can tries push the power button again to recycles each times the POWER AND OPC flashes.Do it at lest 4 or 5 times to recycles each time the POWER AND OPC flashes,might have the backlight on and the tv work again.U have to do this all the times now.Do this and don't work.Ur tv the Tuner board is dead.This board,is the board that take the incomming broscast signal cable connected to this board.Tries Websites like, to buy a refurbish Tuner board for the replacement.
Jun 12, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
This problems very common on Sharp Tv.Do ur tv LED power light turn on solid first.Few mins,than LED,OPC flahes.Power LED,OPC flashes,push power button again,do this at leat 5 or 6 times somtimes the backlight will come back on and work.The power LED,OPC light flashes,turn off/on more than 5 or 6 times don't work.Ur Tuner signal board is dead,must replaced.
Mar 30, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No picture, when powering up the light will turn yellow, them the t.v powers up and can hear sound but no picture, and then hear a click and light flashes green.
First turn on,do the power LED light stable?Few sec.Power LED and LED OPC flashes?This very common on Sharp tv,tries power off/on at 4 or 5 each time it flashes,well power up have backlight on and it work.After this doesn't work than ur Tuner Signal board it dead.
Feb 03, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sanyo DP42746 42 in. Plasma No Video
to test all y sub boards remove the main power connection to the y main and turn the tv on if it powers on one of those boards are bad.. remove both sub boards. and plug in the y main. if it powers on then that board is good either, put your multimeter on 2k omh and test the upper ysub boards black connector, the top 2 pins with negative to the 5th pin positive. you should read 500-1k ohm if its way under 100 there is a short.
the bottom ysub board place the multimeters black probe on the bottom 2 pins of the black power conection and the red on the 4th pin.. results are the same.
low resistance means theres a short in the board.
Apr 12, 2008 | Sanyo DP42746 42 in. Plasma Television
We are neophytes, not experts; were able to find a manual for the PT47. It says this is an autodiagnosis feature; LED will flash when SOS is detectedby the circuits located in specific areas. Number of times the LED flashes tells you what circuit should be checked. NUMBER OF FLASHES POSSIBLE CIRCUIT
1 +140
2 LOW D.C.
5 IC4511
6 IC4518
Mar 15, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Powers down after start up
over load on the power supply/poss. power/convergence or shorted video ic on the crt neck board.
Oct 03, 2007 | Panasonic PT-53TW53 53" Rear Projection...
I dont think Sony has a "12" blink code, the highest (being in a newer set) is a "10", might try rechecking that, as for the code 2 that is an OCP, usually a shorted horizontal output transistor/Convergence IC's/High Voltage distribution block. My bet is the Block as HV tends to break down parts like that over time You must be careful when removing the anode leads as you can break the tip off or burn something up if not done right.
May 27, 2007 | Sony KP-41T65 41" Rear Projection...
Dell Latitude D800 Notebook Logo
69 people viewed this question
Alun Cox
