Question about Garmin nuvi 350 GPS Receiver
Garmin Nuvi 350 Touch Screen unresponsive
I have had the Nuvi for 2 years. The touch screen does not work all of a sudden. Tried resetting the device, but I cannot get beyond the password ( cannot enter as the touch screen is not working ). Tried holding the power button to reset. It ran through pre-boot, then software load, but it just ended up coming to the password screen.
  • 1 more comment
  • Anonymous Jul 31, 2008
    I have the same problem with my Nuvi 350. This issue only started within the last 2 months. I have updated to the latest firmware, but the problem persists.
  • mikepilot Sep 03, 2008
    i have the same problem - help!
  • pietd Sep 05, 2008
    Same problem. But sometimes it's working again, most times is dead.
  • Garmin Master
  • 2,130 Answers
The touch screen lays on top of the LCD display. It has its own flex cable that plugs into the main board. It is possible for the LCD display to work fine while the touch screen does not. They are two separate parts and work independently!
If your touch screen all of a sudden quit working, I would ask did you ever drop it?
I have repaired many Nuvi's with a non-functioning touch screen. I can't speak for every instance but the ones i took apart, the flex screen cable was loose from the main board.
Don't attempt to fix this yourself unless you know what your doing. Email me at ks3r at sharc dot net if your interested in me repairing your Nuvi at a reasonable price. I have references.
- Jim
Posted on Sep 08, 2008
  • SHARCNET-USA
    SHARCNET-USA Nov 30, 2009
    I would NEVER, EVER suggest smacking your GPS!!!! People have sent me units with cracked touchscreens just from pressing too hard on the screen.... you're asking for trouble smacking the GPS. The touchscreen has either come unplugged from the main board or it has failed and needs to be replaced. I've repaired hundreds of units with this problem.
    - Jim
    -SHARCNET-USA
    Scholar:
  • 174 Answers
Try updating the firmware...
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
I don't think you need a password for that...
Posted on Jul 23, 2008
I had the same issue as yours, the cable gets loose inside so just smack it around and then it will work. the other guy said u can fix it, but just trying smacking it around and it might work
Posted on Feb 03, 2009
Device: Garmin Nuvi 660 NA. After power on, nuvi boots thru to the "Where to" page. On the prior page, the touchscreen will not click "Enter" but after a time delay, nuvi proceeds to...
*Master reset your Garmin Device:
1.Start with the unit OFF and unplugged from power;
2.Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
3.Continue touching and holding the lower right hand corner of the screen then power the unit ON
4.Release the power button when the device powers ON
5.You will see a new message: Do you really want to erase all user data?
6.Remove your finger from the touchscreen when this message displays - Touch Yes
7.The device will automatically reset. Please follow the on screen prompts on the nuvi .
*If the touchscreen is incorrectly detecting where your finger touches the screen, the screen may need to be calibrated.
1.Power the unit On.From the Where to? and View map screen, touch Settings . Touch Display>Touch Re-calibrate
2.A new screen will display that says Press Dot,Touch the Center of the Dot.
>Keep touching the center of the dot as it moves around the screen.
3.When Calibration Complete appears on the screen, please touch OK.
The screen will now be Re-calibrated.
*If the screen is not responding to touch, the device may not have enough power to function properly. Recharge the battery completely and try again. If the battery does not charge, it may need to be replaced.
If the screen is still not responding to touch commands or displaying properly, the display may need to be replaced. If sound comes from the device, it is likely the motherboard is working, and only the display needs to be replaced.
Refer to:Garmin Nuvi 660 Screen Replacement Guide
Before replacing the display, check that the ribbon cables connecting the display to the motherboard are connected securely.
Oct 04, 2011 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 205 screen freezes
When a Garmin Nuvi 205 stops working or behaves strangely, there are two steps you can take yourself to try and get it going again:
  1. Perform a Hard Reset,
  2. Run WebUpdater to reinstall that firmware.
I hope that helps.
Feb 16, 2010 | Garmin nuvi 205 GPS Receiver
Nuvi touchscreen dead
settings.
1. Turn the device OFF.
2. Place your fingertip or the eraser end of a pencil in the top right corner of the touchscreen.
3. Apply pressure in the top right corner of the screen.
4. While pressing down on the screen, power ON the unit and continue pressing on the screen. A message displays
to confirm if you really want to delete all user data?
5. Touch Yes.
6. The unit will now restart.
7. Follow the onscreen prompts to set up the nuvi.
Jul 31, 2009 | Garmin Nuvi 350 Car GPS Receiver
Garmin Nuvi 660 touch screen freezes up. Soft
I sat on the phone for 30 minutes waiting for Garmin support when my Nuvi suddenly had no touch screen response. They had me delete a file on the device (with it hooked to my computer) then reboot and it went thru a touch screen alignment and it worked.
Sadly, it has frozen again and I don't recall the file (it had been a GCD file in all caps, that is all I know and I don't see a file in all caps any more). I will be calling support tomorrow.
My take is that it *is* a firmware thing *and* there is some way to reset the firmware.
May 01, 2009 | Garmin Nuvi 660 GPS Receiver
My garmin nuvi 670 touch screen is not calibrated
Have you tried using the screen calibration command? Press the Wrench symbol, then the Display symbol and then Calibrate screen. Press the dots as it tells you to and you should now have a calibrated touchscreen.
- Jim
SHARCNET- USA
Dec 09, 2008 | Garmin Nuvi 660 GPS Receiver
Problem with the touch screen on my Garmin Nuvi 350
Have you tried the "recalibrate" touchscreen command?
Press the "wrench" symbol at the main menu, then the "display" icon, and then "recalibrate".
Go through pressing the dots as requested and see if that cures your problem.
- Jim
Oct 27, 2008 | Garmin nuvi 350 GPS Receiver
Touch Screen
Did you press the reset button locate under the antenna?
Aug 01, 2008 | Garmin Nuvi 350 Car GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
9,541 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
