VCR eats my tapes
Machine grabs tapes and have to break the tape to remove it.
  • bushing clot Jun 26, 2008
    Is there a fairly easy solution or do I junk it.
  • bushing clot Jun 27, 2008
    When I get a chance I'll give it a try if I can get the cover off.
    Many thanks.
  • 8,617 Answers
You may just need to clean the pinch roller assembly, or it may need replacing. depending on the model number there are repalcement pinch rollers and other parts available.
Posted on Jun 27, 2008
My VCR eats tapes after a few minutes.. does it just need to be cleaned?
Sorry,no the VCR mechanical systems pully is out wax.Not worth fixing because the VCR technology it in the past or probabally have no more parts for analonge tv or produced by the tv manufacture anymore.If u vaule ur VHS tapes,just don't used the VHS tapes in this machine.
May 13, 2011 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
I dont know where the record safety tab is
It's on the back edge of any VHS video tape, it looks like a square piece of plastic which is only attached at one side. Break it off and the VCR can't record on the tape. Cover the hole with sticky tape to record again. If your looking for the tab inside the machine just see where the loaded video lands. Most video tapes with it removed will go into automatic play when there's no tab. Also the VCR will eject the tape if any attemp is made to record on a protected tape.
Feb 23, 2011 | Sanyo VWM-800 VHS VCR
VCR is eating tapes
There are different reasons that a VCR could start eating tapes. It could that it just needs a good cleaning or it could have a mechanical problem you will really need to have it checked out by a service center to determine why. If you have small children I would check it for signs of “peanut butter sandwiches. J
Nov 29, 2009 | Philips Magnavox DVD/VCR Dual Player
Mini-DV tape deck eats tapes
internal misalignment causes the tape to mount incorrectly, grabbing and eating the tape. must find a repair facility to realign. do not attempt yourself as the internal mechanisms are so delicate it is easy to cause another problem
Oct 05, 2009 | JVC SR-VS20 Mini DV/S-VHS VCR
Emerson EWD2004 vcr eating vcr tapes
This is caused by mechanical problems in the VCR. Depending on the age and maker of the VCR, the take-up reel in the cassette is driven by a gear, a belt or a rubber wheel. This isn't happening properly in your VCR, so the tape is piling up inside. Given the low cost of replacement combo players (I don't think you can find just a VCR these days), it's not worth having repaired. You can expect to spend $60 to $100 on a repair for this kind of trouble, assuming there are even shops still willing to take the machine in.
May 13, 2009 | Emerson Televison & Video
Vcr player eats tapes and will not eject casset tape
It sounds like either the take up spool isn`t turning because the motor has failed or there`s something inside stopping the spool from turning or there may be something sticky around the skirt of the video head assembly. All I can suggest is remove the top casing and place a tape in the machine and watch what`s happening, Hopefully, you may find a child's toy or something similar under the cassette or the deck. Those labels that you place on tapes were notorious for coming off and finding it`s way into the mechanism. Ian
Mar 22, 2009 | Symphonic WV806 DVD Player/VCR
Tape Problem
When a VCR eats a tape, it can be cause by a couple things.
1. There is a rubber wheel called a "pincher wheel" that compresses the tape against the "capstan". The capstan is a shiny metal spindle connected to a motor. The pincher wheel can become worn and/or dirty (slick) from the oxide coating off of the tape. You can try cleaning the pincher wheel and capstan with alcohol or try using a re-grip solution on the pincher wheel. Last thing to do is replace the pincher wheel. Look to see that the pincher wheel is doing its job by pulling the tape through. The pincher wheel & capstan are not used during a fast forward or fast rewind, so if your tape is getting caught during the FF or RW and not Play, it's probably not related to capstan & pincher wheel.
2. There is a small tire wheel called an idler tire. This tire pivots between the sending and pickup reels of the player. Its also used during fast forward & rewind as well as play. If the tire is worn, the tape won't be wound up as fast on the take-up reel as the sending reel during play. This means more tape is coming out of the cassette than can be wound up on the takeup reel. You can try using a re-grip solution on the idler tire or replace it.
3. There's also a brake pad that is designed to grab and stop the tape wheels from spinning when you hit stop. If those pads are worn, the wheels will not stop fast enough and the tape will continue to feed (spool) out of the cassette and not be taken up by the other wheel.
So when when you hit eject, the excess tape that should have been wound up tight in the cassette before the eject sequence, is getting caught inside the player.
Let me know if I can be of further assistance to you.
- Jim
Jun 27, 2008 | Mitsubishi HS-U776 VCR
Vcr eating tapes
Let me know if you need more information as to where to purchase these parts.
- Jim
Feb 12, 2008 | Philips Magnavox 20MC4304 20 in....
Eats tapes
3. You didn't say if the unit played ok. There's also a brake pad that is designed to grab and stop the tape wheels from spinning when you hit stop. If those pads are worn, the wheels will not stop fast enough and the tape will continue to feed (spool) out of the cassette and not be taken up by the other wheel.
- Jim
Feb 20, 2007 | Symphonic WF803 DVD Player/VCR
Televison & Video Logo
290 people viewed this question
Top Televison & Video Experts
Electro Med Services...
