Question about Apple iPod mini M9160LL/A MP3 Player
My ipod mini needs a new hardrive, can i do this myself?
When you turn it on, it just clicks
  • tobi1kenobe Jun 26, 2008
    i know it needs a new hard drive, can i install it myself. i'm not a techie
    President:
  • 1,285 Answers
Yes you can its real easy follow this link for hard drives
http://www.rapidrepair.com/shop/ipod-mini-hard-drives.html
and this link on how to open the mini and replace,,,,note one thing be extra careful when pulling apart the wires are thin http://www.modmyi.com/forums/ipod-mini/342431-how-replace-ipod-mini-hard-drive.html
Posted on Jul 10, 2009
Apple mini mac 1.8, won't allow access to "system preferences"
in the dock /grey square with cog icon is system prefs, rhs of line 2 is sound
Jan 31, 2009 | Apple Mini IPod
My ipod 5.5 gen video wont sync with itunes on my laptop and only sometimes charges. can anybody help please. its be a present for my ma (mother) for christmas
To reset an iPod with a Click Wheel, including: ipodnano3.jpg ipodclassic.jpg icon_ipod_5g.gif ipodnano2.jpg ipodnano.jpg ipodphoto.gif ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Dec 07, 2007 | Apple iPod MA446LL/A MP3 Player
Sad face icon
  • iPod classic
  • iPod nano
  • iPod mini
Dec 06, 2007 | Apple iPod MA446LL/A MP3 Player
I pod freezes after initial start up
  • iPod classic
  • iPod nano
  • iPod mini
Dec 05, 2007 | Apple iPod MA446LL/A MP3 Player
Problem unlocking
need help lock 8gb ipod need big help now
When turning on my iPod keeps saying to go to the Apple web site for support
  • iPod classic
  • iPod nano
  • iPod mini
Nov 26, 2007 | Apple iPod MA446LL/A MP3 Player
IPOD shows no file found
  • iPod classic
  • iPod nano
  • iPod mini
Oct 10, 2007 | Apple iPod MP3 Player
My mini ipod freezing, showing charger sign i could not turn it to menu
Try resetting the ipod, this usually works. As follows: How to reset iPod To reset an iPod with a Click Wheel, including: iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation) iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button. When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on. Good luck, and I hope this helps.
Sep 14, 2007 | Apple iPod mini M9160LL/A MP3 Player
Ipod not charging
Try opening iTunes to see if it recognizes anything first. More importantly set it to disk mode on the main iPod options screen. Remove any songs from the iPod through disk mode into a new folder, (you wont be able to tell as Apple renames and rearranges everything, but you id3 tags should still be recognized when you import after your iPod is fized)Restore your iPod with iTunes. Those are the steps I'd take first. If that works, just re-import those songs into the iTunes library then over to you iPod
Jul 24, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iPod mini M9160LL/A MP3 Player Logo
53 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
