Auto image adjust
How do I remove from the screen
  • gilhelyon Apr 15, 2009
    i have the same problem its getting preety anoying please someone help
This problem has existed for 4 or 5 years, and I've seen various solutions posted with inconsistent results. Did the problem begin
after a power failure or surge, by any chance? In my experience, this can be related to a setting in the BIOS (Basic Input/Output System) of your motherboard, which can sometimes be affected by power glitches. Try this:
Access the Setup menu of your BIOS. This can only be done during the first few seconds after starting or re-starting your PC. Usually there will be an instruction on the logo screen telling you what key(s) to press to get into Setup (usually F2, F12, or a key-combination, depending on the manufacturer). This screen goes by pretty quickly, so you have to be fast. Once you're in the BIOS setup menu, use the arrow keys to navigate to a category called "Video" or "Display" or "Graphics", etc. (again, depending on the brand). Press "Enter" to view the screen adjustsments for that category. If the graphics controller is set to "Auto", change it to "Onboard/PEG" or some similar term. (If you don't have an alternate graphics controller, you're out of luck.) Follow on-screen instructions for changing and saving settings. When you exit the BIOS, be sure to select "Exit and Save", not simply "Exit." See if that works.
Posted on Jul 23, 2010
Image auto adjust
it seems the LCD panels is defective.
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Feb 05, 2014 | NEC Office Equipment & Supplies
The image become light
Bring up image,at top left of screen click on Fix , at top right click
on Auto Adjust, then go down to Colour adjust move Saturation
slider up or down to get desired image colour, works for me good luck
Mar 31, 2013 | Gestetner C7417 Laser Printer
What do I need to connect my laptop/wii/dvd player to my Sharp Quattron Aquos Led TV? Please need an urgent answer please?
1 Press MENU to display the MENU screen, and then
press [=> or <=] to select "System Options".
2 Press [Up or Down] to select "Input Terminal Setting", and
then press ENTER.
3 Press [Up or Down] to select "PC input", and then press
4 Press [Up or Down] to select a specifi c adjustment item,
and then press ENTER to set each item.
5 Press [Up or Down] or [=> or <=] to select or adjust the desired
setting, and then press ENTER.
Adjusting the PC Image
Auto Sync. (for Analog PC Input Mode Only)
For automatically adjusting the PC image.
Yes: Auto Sync. starts and "Now adjusting the image."
No: This function does not work.
When "Auto Sync." is successful, "Completed" displays. If
not, "Auto Sync." failed.
"Auto Sync." may fail even if "Completed" displays.
"Auto Sync." may fail if the computer image has low
resolution, has unclear (black) edges, or is moved while
executing "Auto Sync.".
Be sure to connect the PC to the TV and switch it on before
starting "Auto Sync.".
Mar 14, 2011 | Sharp Televison & Video
The image on my screen moves around. the colors are fine but the image shifts from left to right then up and down how can i fix this problem
do you see a message 'Auto adjust' from time to time? this is only if you have a 'auto adjust' function, maybe a problem with the functionality. Try doing auto adjust else you need a repair!
Dec 15, 2010 | Televison & Video
Pl. solve my problem "PROCESSING AUTO IMAGE ADJUSTMENT" message display continusly
I've tried all ideas by removing this ,,processing auto image adjustment'", but all of them was not working. So, i found truly and simple solution: The problem is made of constant autoself incorrect working button ,,Auto/set". This button is near ,Turn off/on monitor". Eventually you need to turn off this button, but there is no solution to do it, but i found one - i used hair clipper to press this button PERMANENTLY. And it WORKED, and also no screen buttons are working
Oct 02, 2010 | LG Flatron L1515S 15" LCD Monitor
Images on screen are doubled. Everything
u have bad convergence ic stk392-110 or stk392-150
Apr 13, 2010 | Hitachi 53UWX10B 53" Rear Projection...
I have a ViewSonic Monitor, model number Vs11307. The screen is all blurred and the screen isn't adjusting properly. The screen is shifted to the right and I have a blank rectangle at the left side. I...
I had the same problem same model. The image was off center to the right and it couldn't be fixed by the auto-image adjust or the manual adjust.
My solution was really simple, I moved a video player (RealPlayer) onto the monitor and maximized the screen, then pressed auto-adjust once. It worked.
Jul 14, 2008 | ViewSonic Computers & Internet
Print Qualityfor DC12
I am not 100 percent what you are asking but I will answer the best I can with your question.
  1. Press the [Administration] button located above the numeric keypad on the Control Panel. The Administration button has a wrench symbol located above it. The Access screen will be displayed.
  2. Select [Tools] on the Touch Screen. The Tools Access Number screen will be displayed.
  3. Enter your numeric password using the keypad.
    NOTE: If you do not know the password, contact your administrator. The initial password at machine install is 11111.
    If the administrator encounters a problem with changing or forgetting the machine password, a service call must be placed:
  4. Select [Enter] on the Touch Screen. The Tools screen will be displayed.
  5. Select [System Image Quality]. The System Image Quality screen will be displayed.
  6. Select [Image Recognition]. The Image Recognition screen will be displayed.
  7. Select 'Screening Adjustment' by selecting the [Up] or [Down] arrow buttons.
  8. Select [Change Settings]. The Screening Adjustment screen will be displayed.
  9. Select [Apply to Copies Only] then select [Save]. The Screening Adjustment screen will be displayed.
  10. Select [Close]. The System Image Quality screen will be displayed.
  11. Select [Auto Screening Adjust]. The Auto Screening Adjust screen will be displayed.
  12. Select [Halftone Screen]. The Halftone Screen will be displayed.
  13. Select either [Halftone 200 line screen] or [Photograph 200 dpi].
    NOTE: Do not select 'Printer use' as this will effect print calibration; which will be handled directly by the color server set up to print to the copier / printer.
  14. Select [Save]. The Auto Screening Adjust screen will be displayed.
  15. Insert at least 2 sheets of white, 216 mm x 279 mm (Letter, 8.5 x 11 inch) paper in Paper Tray 5 (Bypass Tray).
  16. Select [Print Test Original] to print a sample of the settings. The message 'Please wait…Printing test original' will be displayed and the test original will print.
    NOTE: If selecting [Print Test Original] displays the message ‘System Disabled' then Screening Adjustment is disabled. Select [Close] and repeat steps 5 to 16.
  17. Open the Document Glass Cover.
  18. Place the test original face-down on the Document Glass with the two magenta squares against the left edge of the glass.
  19. Place 5 sheets of blank white paper directly on top of the test original.
  20. Close the Document Glass Cover.
  21. Select [Start Adjustment] from the Touch Screen. The message 'Please wait….Adjustment in progress' will be displayed, then the Auto Screening Adjust screen will be displayed.
  22. Select [Adjustment Complete]. The message 'Please wait…Printing current settings' will be displayed and the adjusted original will be printed.
  23. Examine the adjusted original to make sure the image quality is satisfactory and continue to the next step. If the image quality is not satisfactory repeat steps 12 through 22.
  24. Select [Close]. The System Image Quality screen will be displayed.
  25. Select [Close]. The Tools screen will be displayed.
  26. Select [Close]. The default copy screen will be displayed
Dec 27, 2007 | Xerox DocuColor 12 Printer
Always says: Auto Image Adjust
These are the allowable resolutions and refresh frequencies for your monitor. 1280 x 1024 @ 60, 75 Hz 1024 x 768 @ 60, 70, 72, 75 Hz 800 x 600 @ 56, 60, 72, 75 Hz 640 x 480 @ 60, 75 Hz 720 x 400 @ 70 Hz 1280x720 is invalid but I see that you were having problems at 1024x768 which might mean the refresh timing was wrong. Make sure the monitor tab in the display properties (advanced) is correctly set with 'hide modes that this monitor cannot display' so that the display is locked to the valid frequencies and resolutions. If all else fails look at the game .ini configuration settings. You might be able to set a compatible mode there. Or run the game in a window.
Sep 24, 2007 | ViewSonic VA703B LCD Monitor
Computers & Internet Logo
864 people viewed this question
David Payne
David Payne
