Sharper Image Ionic Breeze 3.0 Air Purifier
Problem for Sharper Image Ionic Breeze 3.0 Air Purifier
Ionice breeze quadra Model # S1637
By bullcity on Jun 26, 2008
My unit will not work. No power. Need help or advice. thanks
Same Problem
Jan 18, 2009
-   i have the same problem. But I don't seem to find a solution posted here or anywhere else.
erica-   Guest
Jan 18, 2009
-   I have a S1871 model it doesn't say 3.0 anywhere it. i when plug in and turned on none of the idicator lights come on and it acts like it isn't getting power. I love this thing and want to know if there is anyone out there who can service it. Thanks -   amyrobison
Dec 06, 2008
-   my Quadra Ionic breeze stopped working. The lights come on but nothing else. I have followed directions on cleaning the internal portion with a pressurized can of forced air but that doesn't work. Is there a reset switch that I am missing? Any ideas. -   Guest
Dec 03, 2008
-   My Ionic Breeze Model S1637 just stopped working and I don't know what to do. Is there a solution for this. It appears as if the unit is not getting any power?-   Guest
Dec 02, 2008
-   My unit just stopped after cleaning it. I have taken the grids off several times to make sure they are connected. That is not the problem. It seems to be getting no power for anything.-   rmjordon
Best Solution
posted on Oct 29, 2008
Very Helpful)
jpc59
Rank: Apprentice
Rating: 100%, 2 votes
Hello to all, there is a small micro switch that is actuated by the grid. This is mounted on the side of the top control piece. There are two wires attached to the little circuit board, usually one is corroded so you need to cut it back and soder it to the center pin of the switch, thanks jim.
Was this helpful?
Yes
No
Solution #2
posted on Jul 12, 2008
Helpful)
Bubbabear64
Rank: Wiz
Rating: 85%, 2152 votes
All Sharper Image Ionic Breeze Ionizer have been recalled and are no longer supported
See the Chapter 11 link
See the EPA link as well
Was this helpful?
Yes
No
Solution #3
posted on Oct 30, 2008
Helpful)
l_c2000
Rank: Apprentice
Rating: 85%, 2 votes
Samething happen to me but it turn out that I didn't put one cover back completely after cleaning it. From the outside it looks like it is closed but I have to completely remove it and put it back to fix the problem. It looks like there is a safty switch somewhere that will not power on if any of the cover is not put in correctly.
Was this helpful?
Yes
No
Solution #4
posted on Dec 05, 2008
Not Rated)
abarber1912
Rank: Apprentice
Rating: 0%, 0 votes
I also had the same problem as the previous guest. It is important that you put the grills on first,then the top control piece. I agree, there must be a safety switch in the grid, because after several attempts my Quadra started working correctly when the connection was made. I recalled that when I purchase the purifier I didn't remove the grills when I cleaned the filters, only when I removed them did the problem start. Adriane
Was this helpful?
Yes
No
Popular Solutions for Sharper Image Ionic Breeze 3.0
Questions and Unsolved Problems for Sharper Image Ionic Breeze 3.0
Do you recommend Sharper Image Ionic Breeze 3.0 Air Purifier?
Answer
Answer
Unit does not operate. Middle light would come on and then shut off. Cleaning did not help. No... (More)
Answer
We have an Ionic Breeze Quadra, Model S1637. One of the little flaps on the bottom of the blade... (More)
Answer
I have an ionic breeze quadra and the over due cleaning light is on. I have cleaned the unit, turned... (More)
9 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Nov 12, 2008
I have the same problem too. No power at all no matter what I tried.
Comment by Guest, posted on Oct 27, 2008
Same here---------does absolutely nothing........
Comment by MDTUBrenda, posted on Oct 07, 2008
Yep, I have the same problem. Tried taking it apart since they are no longer serviced. Cleaned everything. No change. Acts as though it's not getting power, no lights nothing. Beside saying it's no longer supported does anyone know how to fix it?
Comment by lotofdoghair, posted on Jun 29, 2008
tired every step to get my quadra fixed even purchased new uv tubes seems it is not getting power
Describe your Air Purifiers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Purifier Experts
Top Air Conditioner Repairmen
in , IL
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
