Question about Refrigerators
CONDENSATION FORMS ON THE INSIDE OF THE REFRIG ON THE BACK OF THE UNIT AND THEN IT FREEZES. THE DOOR SEALS ARE GOOD AND WE RARELY OPEN THE DOOR FOR MORE THAN A FEW SECONDS. WE HAVE ADJUSTED THE COLD TEMP SETTING FROM 3 TO 6, BUT THE PROBLEM REMAINS. THE UNIT MODEL NUMBER IS 532. PLEASE HELP----THIS IS THE SECOND SUB ZERO UNIT WE'VE HAD IN HOMES, AND WE LOVE ITS PERFORMANCE UNTIL NOW.
  • bendescoteau Mar 25, 2009
    I have the same problem however I have noticed that the fan at the top of the fridge doesn't work. so it may not be getting proper circulation.... any thoughts anyone?
Love this machine. Mine is 22 years old and has had minimal problems. Just had this same problem on my frig, including the ice buildup on the back panel.
The Schrader valve that controls the freon is defective (think valve stem on your tires), The old Freon was evacuated, new valves (2) put in and the Freon was refilled and pressurized. Everything is back to normal -- even better than before.
Total cost, including some heavy cleaning of greasy dirt on the condensor coils came to around $300 in the Chicago area. I usually clean the coils monthly, but noticed that there was a buildup of oily gunk on the coils. The repairman used a food-safe chemical cleaner for this.
Posted on Aug 06, 2009
    Scholar:
  • 135 Answers
Check and see it there is a power saver/ moisture control switch.
If there is... Switch it back to normal/or what ever the other setting is. (they all have different names for this feature). This will cause the frig to go into de-humidify-ing mode. In the winter you should not have to use this feature, winter has dryer air than summer.
let me know what happens
Posted on Jun 26, 2008
Samsung refrigerator is freezing up on back panel of refrigerator . Will defrosting the whole unit do any good? The unit is 2 years old
well yes and no , defrosting it will temporally make it work , but main problem is there isn't proper air flow over evaporator coils id clean them with soap and water while defrosting out unit , if low airflow is allowed to continue then refrigerant gas will build to high press and escape and render unit a total replacement
Sep 29, 2016 | Samsung RB215ACBP 20.0 cu. ft. Bottom...
Refrigerator runs continuously
How well are the door seals and the door to the ice dispenser is it closing all the way. Condenser clean?
APPLIANCE 911
Apr 14, 2016 | Frigidaire Refrigerators
Brand new upright Freezer forming Ice above top shelf and now drops of moisture inside door model WFM1800 door seems to be shut tight
Is the unit level to the ground or platform it sits on? The reason I ask is that many cases after closing the door a vacuum occurs, after this vacuum settles the door can allow gap in which will cause this issue. So with out opening the door or 10 mins after, check the door seal to assure a good seal. Some door can be modified to seal by heat (blow dryer or steam). BUT, inspect unit before assuming this is the issue! I can further assist you in how to apply heat to reform gasket on door or even reshaping door to seal better if needed.
Get back to me on model you have and the results of your findings about this seal issue.
Basically, you have an air leak and this is the cause of a seal issue. Results in a condensing warm air mixing with cold air and causes ice cycle to form. Usually around the top because heat rises and cold air drops. With this information you can adjust the door to meet the cabinet and seal you years to come.
Good luck and feel free to send me information if needed.
Oct 23, 2013 | Westinghouse Refrigerators
How do you clean sealed condenser coils
hi.ummmm.sealed condenser unit.(new one).well condenser units have to be open somewhere to cool it.1- by air 2- by fan 3-by the refrigerator cooling.(condenser inside insulation,not accessible)i suppose if access is difficult then a blast of compressed air,blast with refrigerant gas,or try for a quick fix computer cleaner comp/air.good luck.Ali
Jun 25, 2012 | Jenn-Air Refrigerators
Older model fridge freezes on the refrig. side
check the damper door and see if its iced up this is between the refrige and freezer compartments and lets cold into refrige from freezer,if it ices up in the open condition the refrige control cant change the temp,defrost the door and then see if the control moves the door,if so also check the door seals to make sure they are sealing good so as not to let warm air in that can condense and freeze things like the damper door
Jan 16, 2010 | Refrigerators
Samsung refirgerator freezing food.
your damper door is freezing fully open between the freezer and refrige compartment defrost it,then adjust the cold control to make sure its controlling the door position,itsound as if your door seals may be letting in warm air that condenses and freezes on things check this too
My Whirlpool side by side keeps freezing on the regular side.
your damper door is most likely frozen in the fully open position,thaw it out if iced up,then adjust cold control to see if it closes,the door is inside between the refrige and freezer compartments,also if this happens again check the door seals to make sure they are sealing good and not letting in warm air that can condense and refreeze this door
Jan 16, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I get a puddle of water inside of the the refrig every a couple days, I have turn off the refrig, and blow with the fan for over 5 hours, hoping that will solve the issue, however that didn't work.
check the seals for leaks. condensation from warm air leaking into the fridge through bad seals collects on the inside. also, if condensation collects on the evaporator coils, it'll freeze. then when it goes into defrost mode, all of the frost and ice melts into a condensate pan under the fridge. if the tube to the pan is blocked, the condensate stays in the fridge. so, check the seals and check the condensate tube.
Nov 09, 2009 | Samsung RS2630SH Side by Side Refrigerator
Stopping condensation inside refrig.
Condensation occurs when air is entering the refrigerator. There is moisture in air and the when the air gets in the cool refrigerator temp condenses the moisture in the air into water. So basically you have a gasket that is not sealing or one of the doors is not completely closing, or possibly it could be from constant opening and closing in a large family or kids getting stuff in and out all the time.
Sep 10, 2009 | Kenmore Refrigerators
Frigidaire side/side refri section warm
Oceanrunner, it looks like a couple of things might be going on: One is how much defrosting did you do. If it was a full defrost, you might have too many door openings going on. This causes condensation. Do a full defrost and then be sure the door is closed when not actually getting things in/out. Don't forget to check to see if your condenser coils are clean. If not, clean 'em! That may fix it.
It is possible that your defrost timer is defective but I think not based on your defrost cycle starting. It is possible that the defrost coil is bad. This means that you'll have to access the coil and check if for continuity. Typically, this is located with the coils and below them in the back of the freezer. One wire on each side. Unplug the box...Wiggle 'em to clear any corrosion... Unplug..If you've got a multimeter, check for about 100 ohms between the terminals...You can then turn the unit on and wait. See what happens. If frosting begins, actuate the defrost cycle. (Frosting should be even after about 5 minutes or so across they pipes. If the gas level is low, the frosting will not be even.)
Some cold water units run through the coils. If they get too cold...they freeze. This is caused by low gas or by frosting from other sources. Don't panic: this unit has an extended warranty on the sealed unit...the compressor and all that...for 5 years. That means the gas, too. Call your manufacturer for service.
Nov 28, 2007 | Refrigerators
Refrigerators Logo
286 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
