Question about Dell UltraSharp 2405FPW 24" Flat Panel LCD Monitor
Broken plastic function button replacement?
The PIP button on my 2405 has, through constant usage, become defunct as in I can't feel the micro switch behind it anymore when I pres it, actually the button is lopsided so I'm going to guess that the plastic post that normally connects with the micro switch behind is history. What are my options at this point?
If it's simply a plastic post problem then, is this a part that can be ordered up online? I'm not averse to running riot with a screwdriver, though some pointers on how to disassemble the frame to get at it wouldn't go amiss. I'm fairly sure the micro switch is ok and that it's simply the actuall plastic button thats at fault.
BTW for future products, it would have been nice if those buttons were available off an IR remote control 8/
  • 88 Answers
Looks more like the tact switches inside the unit are history and have to be replaced. The switches are relatively cheap $2-$3 each, but replacing them inside the monitor needs some skills...;)
Posted on Jan 12, 2009
How to replace ice dispenser lever on lg
face plate removal should have some small pry points to remove the face plate, then there will be some screws, then you can see the microswitch, it should have a plastic leg that is from the dispenser to the switch, it will be broken off, or the mounting pegs for the switch(plastic dowels are broken) they become brittle after some time, remove the pin, drill a small hole and secure the microswitch to the spot where the peg broke off using a screw and nut .
Aug 01, 2014 | LG LMX25985ST Bottom Freezer French Door...
Start button wont work
did you feel the clicking sound when button is press ? if no clicking sound , then it's the switch broken/wire loosen, if you cann't feel the clicking, then the plastic behind the button broken
Apr 21, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
How to repair kitchen aid door springs
proceed according and fix it. God bless you
  1. Open leverCheck your microwave lever to determine if it is damaged. If it is broken, simply replace the lever to get your microwave door fully functional again.
  2. Door springResponsible for keeping downward pressure on the door hook, the microwave door spring can begin to malfunction. If this part is broken and prevents you from opening your microwave door, replacement is necessary.
  3. Door latchOne reason your microwave door may not open properly is a broken door latch. Located inside the microwave, the door latch manipulates the door hook to keep the door closed for safety and top performance. If broken, the door could become stuck in the locked position.
  4. Door hookIf your microwave door will not release properly, the door hook could be damaged. Located inside the door, the door hook is made of plastic and prone to breakage with extended use or age. As this part is unable to be repaired, the only option is to replace it.
  5. Button or button springIf the microwave door will not open, it could be an internal failure of the button or button spring. If it is determined that either of these parts is the source, both are replaceable and it is recommended that they be installed at the same time.
  6. Handle actuatorIf the microwave door will not open the plastic handle actuator could be broken. Connected between the door button and the door latch assembly, this plastic part could become damaged and brittle over time, which makes breaking inevitable. If this occurs, replace the handle actuator to get your microwave fully functional again.
Nov 01, 2013 | KitchenAid Microwave Ovens
H5460NO/01 door lock is not working
test this steps and fix it. God bless you
Oct 27, 2013 | Microwave Ovens
I'm unable to open the microwave door on model Sanyo EM-S8586W as it appears the spring is broken. How do I remove the cover so I can replace the spring please?
make this steps and fix it. God bless you
Oct 26, 2013 | Sanyo Microwave Ovens
Door wont open
follow this steps and fix it. God bless you
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#11#ixzz2aSkJuabC
Jul 29, 2013 | Haier Microwave Ovens
The door doesn't open
please follow the instruction and fix it. God bless you
May 28, 2013 | Cuisinart Microwave Ovens
Ibm 9513-ag1 flat monitor broken switch
I have the same monitor. I had the same problem you have. I couldn't find the correct replacement part so I improvised. The plastic part you refered to just activates a micro switch on the circuit board. In my case the micro switch worked just fine so I used 5 plastic buttons off of some ball point pens as a replacement. I took the monitor out of its plastic case and drilled holes in the front bezel directly over each of the 5 micro switches. I then put the buttons from the ball point pens in holes. So now the push buttons from the ball point pens act as a substitute for the broken part. I hope this helps.
Apr 20, 2009 | ViewSonic VA721 17" LCD Monitor
Microwave shuts off by itself
The microwave has a safety door switches (2-3 micro switches)
The door mechanism should hit these micro switches. If you can open the machine, you can see that these micro switch has a holder that you can adjust and tighten to make sure that the hook of the door should activate them.
Mar 30, 2017 | Whirlpool GH8155XJ Microwave Oven
Dell UltraSharp 2405FPW 24" Flat Panel LCD Monitor Logo
251 people viewed this question
Alun Cox
