Question about Emerson EWC1303 13 in. TV/VCR Combo
What is the comcast cable code for this tv for the digital box
    Top Expert:
  • Emerson Master
  • 76,016 Answers
Hello
Comcast remote codes for Emerson TV are:-
10154, 10451, 10236, 10463, 10180, 10178, 10171, 11963, 11928, 11913, 11911, 11909, 11905, 11665, 10282, 10280 10270, 10183, 10181, 10179 10177, 10038, 10019
You have to check with each code, until you find which code sets for your TV
programming TVcontrol
The Comcast Digital Adapter remote control is pre-programmed at the factory to operate the Digital Adapter. The Comcast Digital Adapter remote also contains a universal TV library to allow you to control the Power and Volume of your TV.
1. Turn on the TV
NOTE: Please read steps 2 to 4 completely before proceeding. Highlight or write down the codes and device you wish to program before moving on to step 2.
2. Press and hold SETuntil the Red Light blinks twice, then release SET.
3. Locate the code for your device in Manufacturer's Codes on the back of this user guide. Brands are listed in alphabetical order with the most popular codes listed first.
4. Enter the first five-digit code for your TV. If you perform this procedure correctly, the Red Light will blink twice
NOTE: If you enter an invalid code, the red light will display one long blink and exit the programming mode. Repeat steps 2 to 5 with a valid code.
5. Aim the remote control at your TV and press Power once. The device should turn off. If it does not respond, repeat steps 2 to 4, trying each code listed for your brand until you find one that works. If it still does not work, try Searching For Your Code.
If your brand of TV does not respond to the remote control after trying all of the codes listed, or if your brand is not listed at all, try searching for your code.
1. Turn on your TV.
3. Enter in 9 - 9 - 1. The Red Light will blink twice.
4. While pointing the remote control at the TV and press and release the CH + key until the TV turns off. (Note: You may need to press [CH+] numerous times).
NOTE: In the search mode, the remote control will send IR codes from its library to the TV.
5. Press SETonce to lock in the code. The Red Light will blink twice.
OK.
Posted on Dec 03, 2010
I need a remote code for my RCA TV . Comcast Cable provided a remote for their digital adapter and was told to enter one of the RCA codes. None would work. Comcast and RCA told me to use both remotes which...
your rca does it have a button for cable. then you can program your tv remote to work with the cable box. go to the manual and try all the codes for rca tv. if this does not work then you have to try it manually. have them give you a different adapter. it might be in the box or remote.
Feb 09, 2010 | Televison & Video
Looking for the codes to set remote for Comcast cable
comcast remote will not turn on or off my RCA LCD Flat Panel HDTV L42FHD37R
Dec 07, 2009 | Televison & Video
Can't get my hannspree remote to work with comcast
10030 for the comcast dvr remote. Code is from NEC
Oct 02, 2009 | Hannspree HT09 28 in. LCD TV
RCA STB7766G1 Converter Box not working with Comcast cables
The RCA STB7766G1 does not support any cable or satellite connections.
Jul 22, 2009 | RCA Analog (RCA) to Digital (USB)...
What is this tv's setup code? Needed for Comcast cable box opera
are you sure that your comcast remote requires xxxxx 5 digits for the TV code ?
10054 ?
most remotes use 4 digit codes and in my book, the philips codes are:
0054
1454
0690
1154
try these
and if you are sure that the comcast remote uses 5 digit codes then try these
10054
11454
10690
11154
make sure you get the Red LED code entered Confirmation Blink after entering the code digits.
its either a double blink or a Long Solid blink
if you have 4 digit codes it will blink before can enter the 5th, so you will know
Ed
Jun 16, 2009 | Philips 13PT30L 13" TV
Sharp TV (LC52D64U) remote control Comcast cable (DVR) box ?
I had the same problem with my remote. I would enter the code and there would be no response from the remote. I looked up the manual for the other comcast remote and the codes are 5 digits instead of 4. Try codes 10093 or 11602. The reason why there is no response from your remote is because it is waiting for you to enter the last digit of the code. Hope this helps.
Dec 01, 2008 | Sharp Remote Control
New digital box from comcast, codes listed not work for their remote, search mode turns no code either. TV model #CM19022S, Serial #3CDT703826H assembled July 2002...don't if it comcast box or tv....this...
Hello!
I'd be happy to get you in touch with the right team to assist you with your remote. Please email our team at We_Can_Help@cable.comcast.com.
Regards,
Melissa Mendoza
Comcast Customer Connect
National Customer Operations
Oct 09, 2008 | Televison & Video
Program Comcast remote to operate Samsung 46"LCD
Not sure which remote you're using. We have comcast Motorolla box and Samsung LN-T4671F. the code I used was 10812 and it works perfectly.
Go here for more and check the comcast section:
http://www.remotecodelist.com/remotes/
May 18, 2008 | Samsung TV Remote Control
Emerson EWC1303 13 in. TV/VCR Combo Logo
15,710 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
