Question about U-Line Icemaker
Replace the thermostat or temp control
How do you remove the temperture sensor tube from the ice maker? Does it just pull out or is it fastened somehow? It seems to be stuck. I did not want to just **** it out if it has something holding it in. This is on a WCM48 model U-Line.
  • kralla Jun 26, 2008
    I figured it out. You just pull it out. Thanks anyway.
I just installed a wcm 48,, and the water to the tray will not shut off???? is it a relay somewhere??
Posted on Jun 28, 2008
I found out that it just pulls out. It was a little corroded, which was why it was hard to come out. Also, when it was installed it was not very straight, which made it bind. Thank you.
Posted on Jun 27, 2008
Not making ice.
ICE MAKER not making ice
Inspect Water fill tube, Inspect the ice maker mold to see if there are ice cubes present. If there are no cubes or very small cubes, then you should look for issues with the water fill system. Inspect the fill tube and the fill cup area at the back of the ice maker to make sure that they are not frozen. If there is an ice buildup in that area, confirm no foreign objects have disrupted the flow of water into the fill cup. If nothing obvious has caused the ice buildup then suspect the inlet valve, tubing or low water pressure. Inspect the outlet tubing from the fill valve to the ice maker fill tube for any signs of restrictions and replace if necessary.
WATER INLET VALVE:
Check the water inlet valve for any restrictions. You will need to shut off the valve from the household water supply before you disconnect the inlet tubing. Some water inlet valves may have a screen to filter debris before it can enter the valve. If the screen is plugged, water flow will be restricted and the result will be small or layered ice cubes. Remove and clean the screen or replace the valve. If dirt has gotten into the valve it may not shut off completely and will continuously drip water into the ice maker fill tube and will eventually freeze up. Low household water pressure or a restriction at the manual shut off valve will also cause the water inlet valve to not shut off completely and create this same condition. Self piercing saddle valves are the most common shut off valve to cause this problem as the hole that is pierced in the water line is often too small and will more easily become restricted.
The water inlet valve is operated by line voltage supplied through the ice maker control. Power is applied for approximately 7-9 seconds during the harvest cycle and energizes the solenoid on the valve to allow water to flow.
You can check the solenoid for continuity with a multi-meter. On models with multiple solenoid inlet valves, you will need to determine which portion or portions of the valve are used for the ice maker. You can normally follow the inlet tubing from the ice maker back to the valve. Unplug the refrigerator and turn off the water supply to the valve before working with this part.
(HOW TO TEST INLET VALVE: Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush or warm running water. If you cannot clear theclog, it will be necessary to replace the valve (the filter is not removable on most inlet valves). Test thewaterinletvalve for continuity using a multImeter. First, inspect the coil for an indication of it's ohm rating. If no information is printed on the coil, then use the range of 170 to 500 ohms. Set the multitester to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multitester should display a reading that matches the coil's rating or if you don't know the rating then it should fall into the range of 170 to 500 ohms. If the water inlet valve does not pass this test, it should be replaced. If the inlet valve has two coils, test the second coil in the same way (note that they may not have the same ohm rating). The valve can also fail mechanically. So even if it passes the electrical test, it may still require replacement. If you have ruled out all other possibilities, go ahead and replace the valve.
Check the tap valve.A bad tap valve-the little device that connects the ice maker's water supply tube to the water pipe-may cause the problem where the ice maker's supply tube connects to the water pipe. If necessary, replace the inlet valve and the tap valve. For the tap valve, use the type that requires you to drill a 1/4-inch hole (as opposed to the "self-piercing" type). You can buy anice maker connection kitand do this yourself, or call a repair person or plumber to install an inline water filter when replacing the valve.
Lastly the ICE MAKER ASSEMBLY:
If there are no ice buildup issues or suspected problems with the water supply, then you may have a problem with the ice maker control. The most common type of ice maker used in modern refrigerators is the heat release ice maker. The ice maker uses heat to release the ice cubes.
If the water's route is blocked or the solenoid doesn't work-or if the bail wire is lifted-the ice maker won't make ice. (Also note that your home's water pressure may not be strong enough to serve an ice maker.)
If you have a heat release or modular ice maker it will have a removable cover at the front. Behind the cover is a series of electrical test points that can be used to diagnose the ice maker. The unit can be manually operated by inserting an insulated jumper wire into test points "T" and "H" to initiate a "test harvest". On other ice makers jumper at points N & M (neutral to Motor) The jumper should be insulated 14 gauge solid wire that has the insulation stripped back about 3/4 of an inch on both ends, and bent into a "U" shape. When inserted into the test points for 5 to 10 seconds, the motor should start and the cycle will continue on its own. You may have to manually close the freezer door switch for this to operate.
This test will simulate a real harvest cycle and will operate the ejector blades, shut off arm and the fill valve in the proper sequence, and will allow you to do a proper diagnosis. This is a live voltage test and should only be performed by a qualified person. If the motor does not start, you can verify that you have power to the ice maker at test points "L" and "N". If the ice maker is getting power and does not perform a cycle, then the module will need to be replaced
On component mode ice makers the testing is done differently.
Testing a thermostat in a component ice maker:
The thermostat is located near the bottom ofthe support box. The thermostat is connected by two or three wires.Label the wire placement before disconnecting them. Remove thethermostat by loosening the clamp, by pushing back the retainerclips, or by removing the retaining screws.
Test the thermostat forcontinuityusing amultitesterset to the ohms setting X1. Start by testing the thermostat whenit has come up to room temperature (about 20 minutes after removing it from the freezer).
If the thermostat has two wires touch one probe to each wire. You should get a reading of infinity.Chill the thermostat in the freezer for about twenty minutes andretest. This time you should get a reading of zero (continuity).
If the thermostat has three wires, number them 1, 2 and 3. Test combinations 1 & 2, 1 & 3and 2 & 3 and write down the results. Two of the combinations should yield a reading of infinity and one should yield a readingof zero. Now chill the thermostat in the freezer for about twenty minutes and retest. The combination that had a zero reading before, should now have a reading of infinity. One of the two other combinations should now yield a zero reading.If the thermostat fails this test, it should be replaced.
Testing a modular ice maker 'sthermostatcan be tested and replaced individually.
Test the thermostat forcontinuityusing amultitesterset to the ohms setting X1. Start by testing the thermostat when it is cold (10 degrees). Insert one probe into the hole labeled "T" and the other probe into the hole labeled "H". The meter should indicate zero resistance (continuity). After the ice maker has warmed up, repeat the test and this time the meter should indicate infiinity (no continuity).If the thermostat does not pass both tests, it should be replaced.
God is the reason I give you free advice so God is good!
Jun 13, 2015 | Samsung RS267TDWP Side by Side...
Excuse my english i ask about the icemaker hoshizaky modelKM450MAB i turned off and then turned on and did not work any more even de control board lights it is powered by electricity
ICE MAKER not making ice:
WATER INLET VALVE:
Ice Maker Doesn't Turn Off If your ice maker keeps making ice, even when it is full:
1Lift the bail wireto shut off the ice maker, and remove the ice bin. Then, using a screwdriver if necessary, remove the ice maker, clean it thoroughly, and then reinstall it.
2If the problem persists,consider removing and replace the entire ice maker and valve. With this type of problem, you can have it repaired, but it's often wiser and less expensive in the long run to replace the unit entirely.
Apr 14, 2015 | Refrigerators
I have a GE Profile refrige model PSS26PSTASS. The ice maker has been making ice okay, it's after it is in the bin it melts and then subsequently refreezes into large solid chunks of ice. I've changed the...
Ice Maker Is Frozen Up This ice maker repair is even easier. If your ice maker has frozen up, take the following steps to thaw it out:
1Unplug the refrigerator.Remove the ice bin from the refrigerator and remove any loose ice from the ice maker.
2Find the fill tube.This is awhite rubber-like hose that delivers water to the ice maker. Pull down the small metal clip off the housing that holds the fill tube (though not all ice makers have this clip).
3Warm the hoseand surrounding mechanism. To do this, you can train a hair dryer on the ice maker to melt any ice blocking the mechanism. But be very careful (sop up any dripping water with a rag) as electricity and water can present a serious risk of electrical shock. Also, be careful not to melt the plastic parts.
4If you don't want to use a hair dryer,you can soak the supply tubing with hot water, using a turkey baster and catching the overflow in the empty ice maker bin. In some cases, it may be easier to remove the ice maker than to thaw out the fill tube.
On heat release ice makers You will want to check the heating element within the ice maker for continuity and a visual inspection of the board and conductors for burns and seizing, chared marks.
How to Test the Ice Mold Heater There are two types of ice makers, those in which all of the parts can be individually replaced and those in which some of the parts are clustered together into a control module. To determine which model you have remove the outer face plate. If there is knob, pull it off first, then pry off the face plate with a small screwdriver. Modular units have holes in the module's face plate for test probes. If you see several holes, each marked with a letter, it is a modular unit. It is easier to work on this type of unit by first removing the entireicemakerfrom the freezer compartment. The unit is usually mounted to the freezer case by two or more screws. Remove the bottom screws first. While supporting the ice maker, remove the remaining top screws. Unplug the ice maker from the freezer cabinet if you have not already done so. Along the edge nearest the shutoff arm, a pin protrudes through the mounting plate . The arm pin has a spring under the mounting plate. Reduce the tension on the spring by moving the shutoff arm into the "on" position, down, against the ice maker.
Test the heater for resistance using amultitester. Set the multitester to the ohms setting X1. Touch one probe to each of the two terminals (or wires). The reading should be in the range of 60 to 90 ohms. If you get a significantly different reading, such as zero or infinity, then the mold heater is bad and needs to be replaced. Conduct this test with the refrigerator unplugged. Test the moldheaterfor resistance using amultitester. Set the multitester to the ohms setting X1. Place one probe into the hole labeled "H" and the other probe into the hole labeled "L". The multitester should read in the range of 60 to 90 ohms.
Also be sure to check and test water valve with a meter for continuity and voltage..( a full 120 and nothing less) And a visual inspection for any ice build up or blockage in tubing and flow line. Remember u may get a close circuit reading of continuity however it may still be bad in that it may remain constantly closed and water keeps flowing more than suppose to. Hence chunks of ice build up.
Feb 24, 2015 | GE Refrigerators
Ice maker not making ice
WATER INLET VALVE:
Jul 13, 2014 | Samsung RF265AA Bottom Freezer French Door...
Model C0330SA-1A sump temp sensor failure
Sump temp sensor is not reading water temperature of water running over evaporator plate.This sensor is located in the water supply tube that runs up to the top of the evaporator plate. just pull the sensor out of the tube and replace it.
Jul 10, 2014 | Scotsman C0330SA-1A 350 Lb Half Size Cube...
Samsung RF26XAERS Refrigerator/Icemaker
WATER INLET VALVE:
Apr 24, 2014 | Samsung Refrigerators
I recently replaced the evaporator fan motor. Now I have two problems: 1) Ice maker does not dump ice automatically. The water line is clear and fills up the tray. The ice freezes but will not dump the...
Hi and welcome to FixYa, I am Kelly.
You made this statement:
I have to manually make the ice dump. 2) I now have a slight build up of ice under the ice maker where it appears the water from the ice tray is leaking and the inside of the freezer also has a slight build up of frost on the walls.
From my 40 years of experience that statement is telling me that the freezers' evaporator coils are blocked with ice. (i.e frost on the walls) When the coils become blocked or built up with ice everything APPEARS to be working fine but the actual freezer temp is above 17 deg F. An ice maker will not initiate an ice-harvest cycle until the temps are between 14 - 16 Deg F. I.e it is not cold enough to automatically make ice because the ice maker thermostat is not closing at 14 - 16 deg F to start the ice harvest.
So I will pose these questions for you and answer them:
Q? What causes the ice on the walls
A: The unit is not defrosting properly.
Q? What causes a refrigerator to not defrost properly?
A: There are several; reasons that a refrigerator will not automatically defrost
1. The defrost control has failed (Most common failure)
2. The defrost heating element has failed
3. The defrost thermostat has failed
4. A wiring problem in the defrost circuit
Now.... you also made this statement:
You may have a leaking ice tray but it is quite rare. What usually causes an ice build up directly under and ice maker is the inlet water valve leaking / bypassing water when it is supposed to be shut off. An inlet water valve will bypass water when the internal diaphragm fails or debris is blocking the needle seat of the diaphragm. Either way the only remedy is to replace the inlet water valve because the valves are NOT repairable.
Reach inside your freezer and squeeze the rubber tube that fills the ice maker with water. If there is a problem with the inlet water valve the rubber tube starts freezing up with ice. Eventually when the rubber tube is totally frozen the plastic tube on the back of the refrigerator that connects to the rubber tube either leaks or separates from the rubber tube and ports water onto the floor.
If you really want to prove that there is a problem with the inlet water valve turn the ice maker OFF. Remove the plastic tube from the rubber ice maker fill tube (Just pulls out) and place it in a bucket overnight. IF you note water in the bucket the next day then the inlet water valve has for sure failed. Sometimes they LEAK intermittently when the failure first begins so the bucket test may not reveal a leaking inlet water valve. The key here is you said you have water UNDER the ice maker and you suspect a tray leak.
Here is what I recommend you do after the overnight plastic tube in a bucket leakage / bypassing test:
1. Reinstall the plastic tube on to the rubber fill tube.
2. Turn the ice maker ON
3. UNPLUG the refrigerator and so a manual defrost by removing the freezer contents then directing a fan into the freezer compartment for just over 2 hours. (Makes a water mess)
4. Return the unit to normal service
5. Check for ice production 6 - 8 hours after you performed the manual defrost.
If you have automatic ice production you most likely have and automatic defrosting problem... BUT.... there can be a problem with the freezer door / light switch. The door light switch is a 3 contact switch. One contact is a common power wire and the other 2 contacts turn on the light and provide power to the ice maker (and some times the evaporator fan also depending on unit design)
Test the door light switch amd make sure the light will go off when the door is closed. (depress the plunger) If the light stays on the door switch is bad.
Hopefully you have enough information to understand what is happening with your refrigerator and what the causes of the symptoms you have are.
I think in the end you will have to repair the automatic defrost problem and replace the inlet water valve. Do not forget about testing the door light switch.
Thanks for choosing FixYa,
Kelly
Apr 14, 2011 | GE Refrigerators
Ice maker will not dump
Good day,
It has to be the ice maker itself, as long as the temp in the freezer is at or below 14 degrees, and the lever is in the down position.
2 items internally can cause the problem. One is the front module which is a quasi-solid state component and the control thermostat which is behind it and requires a complete dissasembly of the ice maker to access it.
Most will simply replace the ice maker.
If you feel you want to try a repair, remove the ice maker, and let it sit on the counter for 24 hours to dry out.
Pull the front of the wire lever out of the body of the ice maker. Pry the front cover off the ice maker. You will see 3 screws holding the module in place. Remove them, and pry the module off.
Re-install. The point is the electrical contacts are press to fit and one or more might have failed to make a good electrical contact. Reassemble and reinstall the ice maker.
Rarely works but your option. Replacing the module and thermostat are not cost effective.
May 06, 2010 | Whirlpool GS6NBEXR Side by Side...
Ice cube maker
IF NO WATER IN ICE MAKER, CHECK FOR RESTRICTION IN FILL TUBE SUCH AS FROZEN OFF WITH ICE. REMOVE FILL TUBE AND RUN HOT WATER OVER IT TO MELT ICE IN TUBE.
WATCH FOR WATER COMING SLOWLY OUT PLASTIC FILL LINE ATTACHED TO TUBE ON BACK OF REFRIGERATOR.
IF WATER SLOWLY DRIPS OUT OF FILL LINE, REPLACE FILL VALVE( LOCATED WHERE HOUSE WATER LINE ATTACHES TO REFRIGERATOR.
IF ICE MAKER HAS WATER/ICE IN IT, PULL FRONT COVER OFF ICE MAKER TO ACCESS CONTROL HEAD. INSPECT LARGE WHITE GEAR ON FRONT OF CONTROL. IF THE RETAINING TAB IN THE CENTER IS BROKEN, REPLACE MODULE OR ENTIRE ICE MAKER. THERE SHOULD BE TWO
RETAINING TABS HOLDING THE GEAR IN PLACE.
THE FREEZER TEMP NEEDS TO BE A MINIMUM OF 10 DEGREES FOR THE ICE MAKER TO CYCLE. IF THE FREEZER TEMP IS NOT COLD ENOUGH WE WILL NEED TO FIND OUT WHY.
Mar 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
ICE MAKER NOT WORKING Kenmore cold Spot model# 106.55536400
Most common problem is a broken ice maker module.  Should also replace ice maker thermostat when changing the module.  Make sure fill tube isn't frozen first. If you take the ice maker out pull off the plastic cover and in the center of the wheel that kind of looks like a gear there are two little plastic studs.  If one is broke or they are pressed together then the module is bad. Make sure to replace the thermostat along with some silicone grease because a bad thermostat is what causes the module to break.
Oct 19, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
U-Line Icemaker Logo
156 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
