FixYa.com
Tags:
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Kitchen aid superba fridge - ice maker not working... (by 3 users)
posted by nytrogyrll29 on Jun 26, 2008
i have a kitchenaid superba side by side. the ice maker is not sucking the water up in it to make ice. the water dispencer is working fine. repair man came, and replaced a switch when the fridge stopped cooling. it fixed that problem, but now the ice maker wont get water to make ice. the arms move around to crack the ice out like normal, but no water is being used to make ice. i used to be able to hear it pull the water up the tube. it no longer does it. please help!!! its hot in texas :)
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by aeisner007, posted on Jul 11, 2008
my kitchen aid does not dispense water using the water lever, but does dispense water when the ice lever is depressed; i removed the water filter and tried again....also unplugged...no result
Comment by Guest, posted on Jul 10, 2008
Same problem. no water getting to the ice cube tray.
Best Solution
posted on Jul 06, 2008
FixYa! (100)
mikedurland
Rank:Guru Guru
Rating: 89%, 247 votes
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Refrigerators problems?
KitchenAid Superba Architect KSCS25INSS Side...
overactive ice maker
the wire that triggers the ice... Answer This...
WATER FILTER LEAKS
water leaks from the water... Answer This...
Ice dispenser and water filter
Ice dispenser stopped working... Answer This...
water filter location
where is the water filter... Answer This...
ice maker kitchenaid
ice maker stopped working.... Answer This...
Repair Service
Find Refrigerator Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
