Question about HP Photosmart 3310 Printer
Door is open and wont close
3310 photoprinter aALL IN ONE
  • 4 more comments
  • Anonymous Jun 30, 2008
    when i opened the door to change my ink in the printer now it won"t close
    it feels like if i force it it will crack the plastic dont know why this happend any help would be greatly apriciated
  • Anonymous Jul 16, 2008
    I do have exactly the same problem with this HP 3310 all in one printer. This printer was working fine for 2½ years without any problem until now.
    I have tried to close the door without power and with power on, no result.
    Please advice……………
  • twosunaz Aug 12, 2008
    I opened the access lid on my hp3310 all-in-one printer and now it seems jammed. Made sure that all ink was installed properly. I don't want to force the lid closed as it seems that something will break.
  • info729 Nov 03, 2008
    The access door does not close after inserting the cartridges.
  • jsteph5009 Dec 31, 2008
    I have the same problem. Changed the ink and also cleared a paper jam and then lid would not close. Had a chat with HP support and they were of no help at all. Thier solution was to buy a new machine!
  • Anonymous Jan 09, 2009
    its the actual door an not the clips to the cartridges
Hi HP-Friends! I had the same problem and read through the post.
I decided to take the whole thing apart and removed the hinge (w/ some difficulty) I inspected the hing and took it apart. Realizing that the spring got too much pressure. I cut it down about a 1/4 of an inch and so far so good. I then broke one hinge when I put this thing together but it work fine at the end. You just have to be carefull opening the door. The hinge has no mechanical value other than it makes it easier to open the door. I am o.k with that as I only open that from time to time to change the printer. -- I tested it all afterwards and its just fine.
Frank
Austin, Texas
Posted on Feb 11, 2009
    Problem Solver:
  • 4 Answers
I have the same printer.
check the clips , when you put cartridge in as the clips sometimes get stuck.
Make sure you hear that click sound, on all the six colors.
Try it and see , if it works.
RD
Posted on Jul 17, 2008
Why does my 973LM liftmaster remote will only open door bur wont close it?
Most garage door operators (openers) have infrared safety "beams". The door won't close, even with a wired push button, if something is in the way.
May 10, 2014 | liftmaster Chamberlain Garage Door Opener...
Vw 2.0tdi the passenger door wont open from outside and wont always close??
Take off the door panel and check to see if the linkakge from the outer handle to the latch has become disconnected and for the closing problem lube the latch well more than likely its not opening fully when you pull the door open so when you go to close it it pushes the latch closed before the actual bar its suppose to latch to enters the latch
Dec 31, 2011 | Cars & Trucks
Error 0xc05d2281 what is this, please HP photosmart 3310
These error codes indicate that the product has an internal error condition.
  • Without turning off the product, disconnect the USB cable from the rear of the product.
  • Remove the cartridges from the product.
  • Wait for the 'Insert Cartridges' message to display on the control panel.
  • Disconnect the power cord from the back of the product.Wait 60 seconds.
  • Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  • Reinsert the cartridges, and then close any open doors on the product.
  • If you receive a prompt to print a calibration page, do so.
  • Reconnect the USB cable to the rear of the product, and then try printing again.
Reply back; If the issue still exist.
Regards,
Riztech
May 02, 2010 | HP Photosmart 3310 Printer
Printer lid wont shut
Make sure you have successfully seated the cartridges you replaced. They may be preventing the lid from closing.
Dec 19, 2009 | HP Photosmart 3310 Printer
I cant close the lid of my
Same thing happened to my printer last night (never happened before) and I too am looking for some release latch....so frustrating and I don't want to force it closed...
Nov 10, 2009 | HP Photosmart 3310 Printer
HP 3310 lid wont close after ink install
Hi!
You need to make sure that the cartridge is inserted correctly on the right slot.
Please see the steps and diagram from the user manual for the proper installation of the inks. (Page 148 to 150)
http://h10032.www1.hp.com/ctg/Manual/c00486336.pdf
Nov 08, 2009 | HP Photosmart 3310 Printer
Ricoh ft5733 keeps on restarting
If I were you, I would call the service company back and have them come back and fix it for free... It would be a what is called a "RECALL" unless they informed you of another problem that may show up
Mar 13, 2009 | Ricoh 3310LE Copier
Access door will not closwe.
I have the same problem and found it's a broken right back hinge. The plastic that holds the pin in place is broken and the spring underneath is preventing the access door from closing properly. Unfortunately, I had to take it apart to see it. If hp (or any other computer company) stocked these cheap parts, they couldn't make money selling disposable computer products...sad but true. I'll be looking for a cheap 3310 for replacement parts for mine...
Jul 24, 2008 | HP Photosmart 3310 Printer
HP Photosmart 3310 Printer Logo
244 people viewed this question
Seeker5211
Seeker5211
