Question about Sharp LC26DV20U 26 in. LCD HDTV/DVD Combo
PLEASE WAIT message on screen
Can anyone tell me why this message is displayed when i turn the set on, and why it won't accept any commands.
  • frank z Jun 27, 2008
    dan
    i got this unit second hand and it has displayed the same message every time it's turned on
    frank z
    message stays on for about 10 minutes,then tv will turn itself off.
    Sergeant:
  • 260 Answers
Sorry to hear about your problem.
The problem you have described is going to require a costly repair. You are having problems with the "brains" of the television. I recommend replacing this television fixing this television will be cost-prohibitive.
Ken
Posted on Jul 10, 2008
  • 405 Answers
Also be sure that you have a signal going to the set either cable or ant or whatever, when it's turned on it should scan for inputs and if nothing is plugged in it obviously won't find anything and shut itself down.
Hope this helps
Posted on Jun 27, 2008
    Master:
  • 638 Answers
Does the message go away after particular time or it stays on.clarify the problem details plse.
  • hemant somaiya
    hemant somaiya Jun 27, 2008
    its not able to auto program.hence it shuts off.check out the antenna or signal reciever.
  • 4,234 Answers
The only time I have seen this is when the set is in the "auto program" mode. Once completed, this should not show up again unless the set has been unplugged for a long period of time. Does this show up each time you turn on the set?
Dan
  • ABRsvcs Jun 27, 2008
    Frankz,
    This could be a logic problem or even a power supply problem. Does this set remain in this condition, never coming out? The autoprogram can take up to 5 minutes these days. I'll research this a bit and see if I can give you some additional things to check for.
    Dan
    Thanks for the update. Since the set is shutting itself down, the self tests are finding a fault. The unit is not searching for channels, it is attempting to startup. It doesn't matter whether or not a cable is connected. Not finding a channel or signal will not shutdown the set. I'll look up this model tonite and get more info.
    Stay tuned...
    Dan
How Can I Obtain the Serial Number of a Modular Switch?
Obtaining the Chassis Serial Number · On a standalone switch:
Log in to the switch through Telnet or the console interface, and then run the display elabel backplane command in the user view to view electronic label information. In the command output, the BarCode field indicates the chassis serial number.
<Quidway> display elabel backplane
Info: It is executing, please wait...
[BackPlane_1]
/$[ArchivesInfo Version]
/$ArchivesInfoVersion=3.0
[Board Properties]
BoardType=EH02BAKKBarCode=2102113089P0BB000881
Item=02113089
· In a CSS:
Log in to the master switch through Telnet or the console interface, and then run the display elabel backplane chassischassis-id command (chassis-id specifies the CSS ID of a member chassis) in the user view to view electronic label information. In the command output, the BarCode field indicates the serial number of the specified chassis.
<Quidway> display elabel backplane chassis ?
INTEGER<1-2> Chassis ID
<Quidway> display elabel backplane chassis 2
[BackPlane_2]
[Board Properties]
Item=02113549
NOTE:
The command syntax may differ in different software versions. You can enter a question mark (?) to obtain help information about the command and set the chassis ID according to the help information.
Obtaining the Serial Number of a Card Log in to the master switch through Telnet or the console interface, and then run the display elabel command in the user view and specify a slot ID according to help information to view the electronic label of a card. In the command output, the BarCode field indicates the serial number of the card.
<Quidway> display elabel ?
<1-1> The present chassis
backplane Backplane
brief Display information briefly
<Quidway> display elabel 1/?
<4,6-8> <CMU1>
<FAN1-FAN2> <PWR1-PWR2>
<Quidway> display elabel 1/6 brief
[Slot_6]
/$[Board Integration Version]
/$BoardIntegrationVersion=3.0
[Main_Board]
[Board Properties]
BoardType=ET1D2S08SX1EBarCode=020LVF6TBB000043
Item=03020LVF
NOTE:
The command syntax may differ in different software versions. You can enter a question mark (?) to obtain help information about the command and set the slot ID according to the help information.
Obtaining the Serial Number of a Power Module Log in to the master switch through Telnet or the console interface, and then run the display elabel command in the user view and specify a slot ID according to help information to view the electronic label of a power module. In the command output, the SN field indicates the serial number of the power module.
backplane Backplane
<5,8,13,16> <CMU1>
<FAN1-FAN5> <PWR1-PWR4>
<Quidway> display elabel 1/PWR1
[Slot_21]
[Main_Board]
DATE=13_02_08 SN=A664A0212080086V0.9A
NOTE:
Obtaining the Serial Number of a Fan Module Log in to the master switch through Telnet or the console interface, and then run the display elabel command in the user view and specify a slot ID according to help information to view the electronic label of a fan module. In the command output, the BarCode field indicates the serial number of the fan module.
backplane Backplane
<5,8,13,16> <CMU1>
<Quidway> display elabel 1/FAN2
[Slot_18]
[Main_Board]
[Board Properties]
BoardType=LE02FCMC BarCode=2103010JTF0123456789
Item=02120995
NOTE:
Jul 22, 2016 | Computers & Internet
How do I turn the voice command off on text messages
To turn of this setting:
1. From the home screen, press the Voice Commands key on the right side of the phone. The Voice Commands screen appears in the display. 2. Press the right soft key Settings.The following options appear in the display:
• TXT Msg Readout: Reads out the text in a TXT message. (Turn this off)
Jan 04, 2015 | Samsung SCH-U450 Cell Phone
System can't fix restart problem itself
Found this on the GT website:
  1. When Gran Turismo 6 is launched while connected to PSN, a message will appear on screen informing the users that "the latest update data for this software has been found (Version 1.03)".
  2. Once accepted (by pressing the X button while selecting [OK]), a "Please wait..." message will be displayed. After a few seconds, the PlayStation 3 system will emit 3 acoustic signals and restarts automatically.
  3. At this point, some users may receive a message stating that the system was not shut down correctly last time. The system will ask then to perform a system file check and then the reboot is completed.
  4. Users will be prompted again to download Update 1.03, whether they received the message in step 3 or not.
To avoid this issue:
  1. To avoid this issue, please accept to download the Update by selecting [OK] within 2 seconds of its appearance on screen when prompted. This will update the game properly.
  2. If you wait longer than 2 seconds, please decline the Update by pressing the Circle button when the message in step 1 is displayed, then select [Back] in the subsequent "Sign-In to PSN" screen. The game will start, quit the game using the PS button while in the [My Home] screen and follow the procedure described above.
This requires fast fingers and is a "work around" solution only but should fix your issue!
Jan 19, 2014 | Sony Playstation 3 (PS3) Console
Oce Varioprint 6250 is telling me I have paper in the Preheat Unit and TTF. Everything is cleared but it won't reset.
To reset turn OFF tghe copier press and hold the Utility key and turn ON the copier and wait then the display scree trouble reset.Touch the screen and turn OFF the copier,wait 1 minute and turn ON.
Feb 20, 2013 | OCE Office Equipment & Supplies
I hooked my PS3 to my HDMI cable to get a better visual screen display for my HD movies and games, but display screen went blank and I cant get the commands menu screen, how can I get the menu commands...
You must reset your PS3 in order to accept the new TV configuration.
  • If the video output settings on the PLAYSTATION3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system.
  • Then, with only the PLAYSTATION3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution.
  • Hope this helps please remember to rate my response, thanks!
    OpenSource13
    Jun 16, 2012 | Video Game Consoles & Games
    Displays green color image/screen
    When did you get this message? It seems like you have set the White Balance of the camera wrong. Set it to Auto White Balance to eliminate this problem. Use Daylight White Balance when shooting in bright daylight so as to eliminate any color cast in the image.
    Feb 04, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
    How to use cmd ?
    to use the command prompt, press the "start" and "R" keys on the keyboard.
    On the small, "Run" screen, type cmd.
    click ok.
    type help in the command prompt. This should print a list of commands that you can use with it.
    This is what it puts on-screen:
    For more information on a specific command, type HELP command-name
    ASSOC Displays or modifies file extension associations.
    AT Schedules commands and programs to run on a computer.
    ATTRIB Displays or changes file attributes.
    BREAK Sets or clears extended CTRL+C checking.
    CACLS Displays or modifies access control lists (ACLs) of files.
    CALL Calls one batch program from another.
    CD Displays the name of or changes the current directory.
    CHCP Displays or sets the active code page number.
    CHDIR Displays the name of or changes the current directory.
    CHKDSK Checks a disk and displays a status report.
    CHKNTFS Displays or modifies the checking of disk at boot time.
    CLS Clears the screen.
    CMD Starts a new instance of the Windows command interpreter.
    COLOR Sets the default console foreground and background colors.
    COMP Compares the contents of two files or sets of files.
    COMPACT Displays or alters the compression of files on NTFS partitions.
    CONVERT Converts FAT volumes to NTFS. You cannot convert the
    current drive.
    COPY Copies one or more files to another location.
    DATE Displays or sets the date.
    DEL Deletes one or more files.
    DIR Displays a list of files and subdirectories in a directory.
    DISKCOMP Compares the contents of two floppy disks.
    DISKCOPY Copies the contents of one floppy disk to another.
    DOSKEY Edits command lines, recalls Windows commands, and creates macros.
    ECHO Displays messages, or turns command echoing on or off.
    ENDLOCAL Ends localization of environment changes in a batch file.
    ERASE Deletes one or more files.
    EXIT Quits the CMD.EXE program (command interpreter).
    FC Compares two files or sets of files, and displays the differences
    between them.
    FIND Searches for a text string in a file or files.
    FINDSTR Searches for strings in files.
    FOR Runs a specified command for each file in a set of files.
    FORMAT Formats a disk for use with Windows.
    FTYPE Displays or modifies file types used in file extension associations.
    GOTO Directs the Windows command interpreter to a labeled line in a
    batch program.
    GRAFTABL Enables Windows to display an extended character set in graphics
    mode.
    HELP Provides Help information for Windows commands.
    IF Performs conditional processing in batch programs.
    LABEL Creates, changes, or deletes the volume label of a disk.
    MD Creates a directory.
    MKDIR Creates a directory.
    MODE Configures a system device.
    MORE Displays output one screen at a time.
    MOVE Moves one or more files from one directory to another directory.
    PATH Displays or sets a search path for executable files.
    PAUSE Suspends processing of a batch file and displays a message.
    POPD Restores the previous value of the current directory saved by PUSHD.
    PRINT Prints a text file.
    PROMPT Changes the Windows command prompt.
    PUSHD Saves the current directory then changes it.
    RD Removes a directory.
    RECOVER Recovers readable information from a bad or defective disk.
    REM Records comments (remarks) in batch files or CONFIG.SYS.
    REN Renames a file or files.
    RENAME Renames a file or files.
    REPLACE Replaces files.
    RMDIR Removes a directory.
    SET Displays, sets, or removes Windows environment variables.
    SETLOCAL Begins localization of environment changes in a batch file.
    SHIFT Shifts the position of replaceable parameters in batch files.
    SORT Sorts input.
    START Starts a separate window to run a specified program or command.
    SUBST Associates a path with a drive letter.
    TIME Displays or sets the system time.
    TITLE Sets the window title for a CMD.EXE session.
    TREE Graphically displays the directory structure of a drive or path.
    TYPE Displays the contents of a text file.
    VER Displays the Windows version.
    VERIFY Tells Windows whether to verify that your files are written
    correctly to a disk.
    VOL Displays a disk volume label and serial number.
    XCOPY Copies files and directory trees.
    this window is used only when the desktop cannot be accessed.
    For a user-friendly interface (easier to use), use My computer to do common tasks.
    Aug 25, 2008 | Microsoft Windows Vista Home Premium with...
    Aiwa cdc-r237 switch off demo mode and AIWA message
    1. Press and hold the SRC button until "ILL" appears on the display.
    2. Press either the up or down switch until "DE" appears on the display.
    3. Rotate the volume control until "DE 0" appears on the display. Don't touch the stereo for several seconds after that, so that it accepts the command and goes back to its normal display!
    Aug 24, 2008 | Car Audio & Video
    PLASMA DISPLAY STARTING UP. PLEASE WAIT
    Un plug the power to the Plasma Screen and also to the Media Receiver for ten minutes. Disconnect the off the air antennas both A and B. After ten minutes plug in the plasma screen then the media receiver and turn on wi the remote control. You should now be back in operation. I was.
    Also It may not be a bad digital tuner. The TV Guide feature is active even when the zip code is set to all 0s so if you have an over the air antenna attached the TV will look for the TV Guide info and if it can not find it because of a weak signal or the chanel it is tuned to does not carry that information the TV thinks that tuner does not work which triggers the 12 flashes. Also on power up the gray box with the waring message "Plasma Display Starting Up, Please Wait" appears and the screen is blank.
    Feb 10, 2008 | Pioneer PDP-5060HD 50 in. Plasma...
    Bang and olufsen BEOTALK 1200
    Make sure answer machine function is turned on. Bottom right button.
    Make sure an outgoing message is set. Should see a <-> arrow in the display screen. If not, press the <-> button. To record outgoing message... the press the middle button; record out going message; press middle button. Wait a few seconds and you should be set. Hope this helps
    Aug 28, 2007 | Bang and Olufsen Beotalk 1200 Digital...
    Sharp LC26DV20U 26 in. LCD HDTV/DVD Combo Logo
    94 people viewed this question
    Top Sharp Televison & Video Experts
    Jaime Hernandez
    Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
