Question about Whirlpool RBD305PD Electric Double Oven
Oven doesn't reach temperature
Oven is usually off by 25-30 degrees (too low)
Usually have to crank up the temp by 25-50 degrees to get the desired temperature reading
  • cudajax Nov 19, 2008
    I have the same problem only oven temperature is too high by about 25 degrees. Will check owners manuael and attempt to fix problem.
  • Anonymous Mar 31, 2014
    the temp in both is 25 degrees low. Have reset to original and no help. Can't depend on baking time. Model 790 48183000. Mfg 9-11
Page 6 of the owner's manual:
Adjust the temperature calibration.
Posted on Sep 05, 2008
When using the BAKE setting, the desired temperature is input and the oven begins a preheating phase. The temp will only rise to one degree less than the desired setting, and the oven never reaches the...
more than likely there is an issue with one of the temp sensors. you will need to press and hold clear then upper on off at the same time then release them then immed. press clear 3 times and hold on the 3rd till the service screen appears. on the right side you will see internal temp and catalyst temp they should be equal or very close. ill bet one of them is alot higher than the other if so the sensor will need replace but depends which one is bad as there are 2 of them. if the problem is on the lower just repeat above but use lower instead of upper
Dec 07, 2010 | Miele H398BP2 / H398B2 Electric Double...
When set to bake eg: 350 degrees the audio alarm will indicate it's reached temp but the oven is 50- 75 degrees lower. Must wait another 15 min for it to reach the proper temp. Have tried to adjust the off...
If you are monitoring the oven temperature with an analog style thermometer you may actually be ok, but seeing the thermometers slow reaction time.
Some newer ovens actually do pre-heat beep prior to reaching temp in an effort to conserve eelectricity.
A good home test is to try your oven at several different temps to see if there is any variation in internal temperature. Try it one day on 300, the next at 375 and another day at 450. Give your analog style thermometer time to catch up (usually just about 15 min) and leave it on for a half an hour to see if the temp maintains.
Also Beware of aluminum foil AND THE NEW OVEN LINER MATS as they can alter oven performance bay absorbing and blocking the ovens natural heat radiation and convection air flow currents that happen in all ovens, not just convection models.
Another interesting fact is that older ovens used a thermostat in them that operated much like your thermometer and was very slow to react making the oven typically about 100 degrees hotter than where the customer set it. This was just a fact of life before the advent of electronic temperature management and became noticeable when people began trying to bake older "hand me down" recipes in the newer ovens with less than stellar results.
You can mimic the older oven performance by preheating the oven about a hundred degrees higher than called for and after it reaches temp, re-set it to the correct temperature and put the items in right away.
If you find your temperatures fluctuating ask your servicer to replace first the temp sensor and as a last resort the control board as this part is usually pretty expensive.
Good Luck with this!
Jun 14, 2010 | Ovens
Oven sometimes doesn't heat up. Sometimes heats up to desired temp, then quits working. Sometimes doesn't even heat up at all. When preheated light comes on, thermometer in oven usually says about 100...
This sounds like a weak igniter, it would have to be a gas oven and the symtoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 14, 2010 | Amana Ovens
I think the oven needs calibrated, because the temperature isn't getting hot enough. It is a u nit it the wall seperate from the stove top
You can only calibrate the temps about 20 degrees. If it isn't getting close to the temp you set it for, you probably have a faulty oven sensor and need to replace it. They usually run around $50-$90, and are easy to replace.
Oct 04, 2009 | Ovens
Oven not achieving correct temperature, 50 degrees too low
Thermostat is not working properly and needs replacement.
Apr 14, 2017 | Ovens
NEFF Oven Model B1430NOGB/02 Oven Temp not heating above @50 degrees
probably the element. to save wasting money, check continuity with a multimeter
Jun 25, 2008 | GE Profile JT912 Electric Single Oven
Kenmore electric oven
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
Dec 02, 2007 | Ovens
Oven Temp
After it drops temperature, how do you get it back to the desired degrees? It sounds like the thermostat isn't keeping up.
Nov 15, 2007 | Whirlpool RBS245PDS Electric Single Oven
Whirlpool RBD305PD Electric Double Oven Logo
325 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
