Hey did you ever get Your printer to start working? I am currently having the same issue with the error message to push output tray all the way down. my email is stinkerbelle06 @ yahoo.com if you have any good news
Photo tray problem
' Lift the output
tray up and verify that the photo tray ' is pushed in until it stops, then lower
output all the ' way down. Press OK
button on the printer to 'continue printing
HP Photosmart C7280 All-in-One Printer
1. Turn off printer.
2. Pull out paper
tray and photo tray
3. Remove output
duplexer (on back of printer)
4. Open input sheet
feeder (on top of printer)
5. Open cartridge
access door. (Basically lift up control panel and scanner section of the
printer)
6. Turn on printer
(Power button on now raised control panel)
7. Printer may
display message "Performing printer alignment - Do not interrupt"
8. Wait for a few
minutes until printer stops making all setup noises.
9. Close cartridge
access door, close input sheet feeder, replace output duplexer, insert paper
trays
10. Do a test print. All should be fine.
Im sorry i didn't actually state what the printer was doing. When i start it up, it does it's printer preparations. When the printer finishes its business an error message appears and says to push the out put tray all the way down. Mine is as far down as it can go; this error message prevents almost all functions of the printer not to work. The only other message i have received is to change certain ink cartridges, which i have. I have already tried restoring it back to factory settings and the error message does not cease.
