Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washer - spin cycle
Clothes are somewhat wetter than normal after the final spin cycle
  • 413 Answers
Tilt the machine so you can look underneath. Inspect the bottom of the gearcase for oil. If oil is present, the oil may have migrated to the spin clutch causing it to slip during spin. The transmission and clutch will have to be replaced. Check your owners manual for limited warranty. The transmission may be warranted for 5yrs
Posted on Jun 26, 2008
Kenmore series 80 washer do not drain enough
It's normal to hear some water in tub, it isn't normal for the rubber wheel to be hard to turn, you need to replace the pump, they are much cheaper on ebay
Sep 27, 2017 | Kenmore Washing Machines
Ran diagnostics...no indication of problems. The drain pump runs in short intervals only at pump out cycles for wash and rinse.
if running in short intervals pump can be overheating and protection safety switch isturning off the pump until it cools,replace pump
Nov 15, 2015 | Fisher and Paykel GWL11 Top Load Washer
My washer is still spinning the cloths but the clothes are much wetter that they used to be after the spin cycle. Any ideas of how to trouble shoot?
Check your belts and also check the drain hose to be sure it is pumping the water out at a good pace. Hope this helped.
Jun 08, 2011 | Maytag Ensignia MAV4758AWW Top Load Washer
Kenmore washer top load all cycles normal but when in the rinse/spin cycle notice it does not seem to spin fast enough to remove water from clothes and the are wetter then normal
There could be a number of reasons My best guess is that it will reduce the spin speed if it thinks it can't drain properly. Check that all the pipes/ filters etc are clear and that it can drain all the water out. Also it wont spin fast if the load is unbalanced. Does the spin speed change according to loading or is it low all the time? It may have a motor control problem, but that seems unlikely if it's working normally other than the spin.
Jan 13, 2011 | Washing Machines
I have a whirlpool ultimate care 2 top load washer no spin
Sounds as if the drive hub which the tub is attached to maybe free spinning. Not an expensive part but does require a special tool called a spanner wrench to remove and replace.
Jan 31, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
My bosch front loading washer on the small cycles will not spin the water out of the clothes..why?
Does it sound like the machine is spinning as fast as on longer cycles?Some machines run a slower spin speed on small cycles which can leave clothes wetter than normal. I've got this on mine and all I do is when the wash has finished I change over to the fast spin only program which then takes it to it's highest spin speed.
Jan 25, 2010 | Bosch Washing Machines
Spin cycle not working like it should
If the washer doesn't reach it's proper spin speed, the clothes may be wet at the end of the cycle. Since you have replaced the belt, it could be that you have a worn motor pulley or tub bearing. Check for damage to the pulley and shaft and for free play. Also make sure that there are no clothes or foreign objects caught between the inner and outer tubs or something causing friction on the drive train. Hope this helped.
Jul 16, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Clothes still wet at end of spin cycle
i would check your belt.the added stress of a full tub longer with water may have done it in.part#wh1x2026 God bless,tom
Jan 10, 2009 | GE WBSR3140DW Top Load Washer
Kenmore washer spin cycle doesn't leave clothes dry
SOUNDS LIKE THE TRANSMISSION IS NOT ALWAYS SHIFTING INTO HIGH SPEED MODE,TRY A MED. SIZE LOAD AND SEE WHAT THAT DOES,TRANSMISSION MIGHT JUST BE GETTING OLD WHIH IS NORMAL-MIKE
Dec 06, 2008 | Roper RAB2121KW Top Load Washer
Clothes are still wet after spin cycle
possibly not a machine fault. if drain is connected to sink plumbing, remove the drain hose and see if it pumps out into a bucket.
Mar 25, 2007 | Maytag Ensignia 3.3 cu. ft. Top Load...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
90 people viewed this question
Dan Webster
Dan Webster
Sal De
