Question about Motorola Mobility RAZR V3m Cellular Phone
Razr my phone keeps dying within only 10 mintutes of use. and i'm pretty sure its not just the battery. any ideas?
  • 21 Answers
More than likely it needs a software update in which you have to take it to the service provider's corp store to have it done. If that doesnt take care of it then it just needs to be replaced.
Posted on Sep 27, 2008
Haii.v3 speaker problem,i try changes reben for speaker,reben keyboard still no sound,buzzer ok,pls tell me what can i do?
Posted on Oct 12, 2008
What causes the phone to beep every 10 mintutes
If it has batteries and they are getting weak the phones will do this to warn you of an impending shutdown.
Nov 24, 2015 | Lands Phones
I charged my droid razr maxx to 100% then battery keeps dying within 15 minutes pls help
Hello My Dear Friend:"::
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jan 19, 2013 | Motorola Mobility Motorla MOTXT912 DROID...
I put my Droid Razr on charger but battery symbol comes on with ? mark. Won't charge or turn on.
1. Turn off your phone when it's not in use. If you're not using your Verizon Wireless Razr, then shut it off. Your battery will last much longer if you regularly do this.
2. Charge your phone less. If you charge your Razr nightly, then your cell phone battery won't last long. Try to charge your phone only a few times a week to extend the battery life.
3. Keep your Bluetooth turned off when you're not using it. Applications, like Bluetooth, are notorious for sucking the power from a cell phone battery.
4. Protect your Razr from extreme temperatures. Your cell phone battery lasts longer if kept at room temperature.
5. Discharge the Razr fully. Before you charge your phone, let it completely die. You can extend the life of the battery by regularly discharging and then fully charging it.
6. Leave the battery in the phone. Keep the Razr battery dry and free of dirt to prolong its life.
Aug 20, 2012 | Motorola Mobility Motorla MOTXT912 DROID...
My Motorola V3i keeps turning off by itself especially on calls.
well unfortunatly its def a battery problem.ul hav to get it replaced..u cud check it out with another battery borrowed frm a friend who has the same mobile
Thanks for using Fixya
Apr 28, 2009 | Motorola Mobility RAZR V3i Cellular Phone
RAZR needs charging 2 times a day even with new battery.
Drain the battery completely 2 or 3 times, then fully charge it and see how long it lasts. If this doesn't help then you might want to take it back to the store. Your phone is obviously trying to figure something out which is sucking down the battery. Bluetooh will drain a ton of battery out for long periods, hence keeping it hooked up in the car. I have gone through multiple razr phones in the past and they all sucked down batteries pretty quick so in the case, blaming the phone is an option :) . You can also try taking the battery out to give the phone a good restart, perhaps leave out for 30 seconds or so. I wouldn't recommend sending it in to Motorola, they like to find ways to charge you to just have it looked at.
Hope this helps! Don't forget to rate :)
Apr 08, 2009 | Motorola Mobility RAZR V3
Motorola razr V3 turn on and off within 1 minute
Your phone is basically shot. Two past RAZRs that I've owned both died that way, and Cingular warrantied them and gave me new ones. When that happens, you're done for - there's no feasible fix that's worth the cost, considering you can get a new one relatively cheaply.
Jul 30, 2008 | Motorola Mobility RAZR V3
RAZR KEEPS DYING
Try a new battery,if that does not work the phone that have the phone reflash.
Jun 11, 2008 | Motorola Mobility RAZR V3
Battery
well...sir they do die quickly no matter the age of the battery......but you should buy a new one
Jan 26, 2008 | Motorola Mobility RAZR V3
Razor v3
I've fixed RAZRs with this problem in the past by removing the battery, cleaning the contacts with a pencil eraser, and very gently bending the spring contacts on the phone out a *little* more so that they make better contact with the battery.  It seems that sometime the battery isn't making good contact so the phone flakes out.
Oct 17, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Motorola Mobility RAZR V3m Cellular Phone Logo
56 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
