Re: I have a sky HD box how can I get my wii console and...
You can get your console to repair shop and get connect,
or you can use repair guide to connect your need and you must have some technical knowledge,,
click here to download repair guide...................
SCART from Sky box to SCART input on Pana. SCART out from Pana to TV to monitor results. The Pana SCARTs should be marked, one for external source such as Sky box, one for TV
i had the same problem. the AV cable needs replacing OR before you buy a replacement chekc the connections with other appliances such as freeview/sky box or DVD player etc. make sure they are connected properly.
if you connect the dvd to the tv using scart socket 2 (av2) it should send a signal to the dvd, depending on the make/model of tv, you also may have to set the av2 output in the menu. Alternativly, connect the sky to the dvd input and the dvd output to the tv, this should also work.May have to watch the tv with the dvd on set to av.
I have the same amplifier, a Sky + HD box, an LCD TV an surround speakers. We wont go into the Wii, PS3 and PC also hooked up. Essentially the best way to go (whatever you connect up) is to split the video and audio signals.
Sky: The Sky box has an audio outputs (left and right channel) found at the back of the box. You get some twin audio cables, plug into the back of the Sky box and the other end into the Kenwood Amp (for example we use Video 1). This means that the sound from Sky can be found on Video 1 on the Amp.
You take the video signal (picture) from Sky using a SCART cable and put into the back of your panasonic TV. This does mean that you can watch a picture without the sound and listen without a picture. The Amp remote controls the sound, the Sky / TV remote controls the picture.
You may need to tinker with some settings on the Amp, for example on the front of the Amp you will find a source button, toggle through the 3 or 4 options to give you the right sound. But essentially that should be it. The same process is used for any other things you want to add, like a DVD player, a games console and so on.
hello, if your dvd player is'nt a hd dvd player it'nt not able to be converted into a hd you'll have to buy a hd dvd player,and for your sky plus you'll have to call your program supplier for the hd box,and yes the 4500 is the same as the 4710 its the same t.v. all even newer t.v.'s still offer the "s" video option for people who still want to use a old vcr with there newer t.v. for example thay can still use "s" video.
I would use the Sky box manuals recommendations for connection as this usually gives the best performance especially if you wish to record from Sky to the DVD recorder.
