Question about HP LaserJet 4 plus Printer
LASER JET 4L PRINTER PROBLEM
I went out of town. Turned my PC off & also turned the power strip off. When I turned power strip on & PC on, my HP LaserJet 4L will on turn on & no lights. If their is a fuse I can't find it or understand where it is from a spec. I have also tryed to up plug it and plug back in after PC in already on.
As you see I have little PC tech talent.
Help please!! ;o) PJ
Thank you!
    New Friend:
  • 159 Answers
Dear pamswab.
there is an interrnal fuse in the printer you most open it and found the power bourd the fuse there
Posted on Jun 28, 2008
Thick strip on paper on 4L laser printer
Check the toner cartridge drum first. Move the flap away to expose the drum. It should be clean. If it is then you have a bad fuser.
Oct 14, 2014 | HP C2003A-RFB 4L LASER PRINTER Refurbished...
HP LaserJet 6p Printer Drivers Downloads for Windows 7
Go to hp.com. Select the support/driver link. Put in your model and hit enter. You will then see a menu with all of the operating systems. select the full download.
Jan 03, 2011 | HP LaserJet 6p Printer
The Out of paper light on my HP Laser Jet 4L is flashing even though the printer has paper. Can this be fixed?
The pickup roller most likely needs to cleaned. Normally paper dust causes this condition. Put the printer off and try again. If you still have the same problem then you probably have paper stuck in the printer somewhere, the paper sensor under the printer is broken. This is quite an old printer and spares might be a problem.
Good Luck
Apr 13, 2010 | HP LaserJet 4L Printer
I just bought a Compaq Presario computer and need an adapter cable for my HP Laser jet 4L. Where can I find one?
The HP Laserjet 4L uses a standard 25pin parallel printer cable.
These can be purchased at your friendly computer shop or on the Internet.
Mar 29, 2010 | HP LaserJet 4L Printer
HP Laser Jet 4L fuses
The fuses are located on the DC Controller (main bottom board). Getting to the DC Controller Board on a 4L printer is a very significant disassembly. Best left for a pro but if you really want to do it, I have attached below a link to a scanned copy of the service manual. Please keep in mind that the scanned copy is not a nice fresh PDF as most manuals as the 4L was made in 1994 and HP has physically scanned the printed manual for distribution. Just look up the removal and replacement of the DC Controller Board. Once removed, the fuses are glass buss style, readily available at any Radio Shack.
Gotta love that old technology.
Hope this helps you. :)
http://www.feedroller.com/Store/Service%20Manual/LASERJET%204L,%204ML,%204P,%204MP%20Service%20Manual.pdf
Aug 27, 2008 | HP LaserJet 4L Printer
HP 3030 Won't Scan
you may want to check that printer is plugged directly into the wall socket, NOT the power strip. this can cause some issues.
Aug 20, 2008 | HP LaserJet 3030 All-In-One Printer
Hp laser jet 4L problem
try holding the "online" button down when turning on the printer release when you get "cold reset" message
Jun 26, 2008 | HP LaserJet 4 plus Printer
On & off switch
I don't think there is one.
Jan 17, 2008 | HP LaserJet 4L Printer
HP Laser Jet 4L - No Power
it's possible that the power switch alone just needs cleaning. Take it apart down to seeing the copper contacts and then polish the copper contacts with emory cloth.
Sep 09, 2007 | HP LaserJet 4L Printer
HP LaserJet 4 plus Printer Logo
159 people viewed this question
Seeker5211
Seeker5211
