Question about Dryers
Very little cold water comes in th washer - Dryers
  • 413 Answers
Disconnect cold water hose from machine. Inspect the filter screen on the cold water connection. DO NOT REMOVE SCREEN. If full of debris, use a spray bottle with a hard spray to remove debris. If unable to remove or cold is still slow, replace valve.
Posted on Jun 26, 2008
Hot water does not come in, only cold water comes in, the water pump works on cold water does not start on hot water
There are no water inlet pumps on standard washers- the water, both for hot and cold, is fed in simply under 'mains' pressure.
(The following is pre-typed for hot and cold!)
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Oct 08, 2011 | Magic Chef CAV2000AWW Top Load Washer
Setting is on cold/cold, but only burning hot water is coming out. When I switched it to warm/cold, it got a little cooler but still not cold. The hot/cold setting is also just warm water, so the hottest...
This seems to me to be that the hoses are connected backwards. It matters very much which hose is connected to which inlet. Make sure that the hoses are on Hot to "H" and Cold to "C" on the machine.
Aug 29, 2011 | Admiral AW22 Top Load Washer
Hot water won't run into washer
G'day. The hoses from your laundry taps hook up to your machine onto what are called solenoids. These are like electrical taps. The machine decides when to turn these on and off and in what order via the timer and depending on what modes are selected. Generally there is a hot and cold solenoid. If you have both hot and cold hooked up to your machine, you can simply swap these hoses around (put the hot tape on the cold solenoid and vis-versa) Then when you select cold, you'll actually be getting hot. Some new machines heat water internally like dishwashers, and they only have one solenoid. Again if you put the hot tape only on, you will get hot water with cold selected. In both solutions you are losing the option for cold or hot cycles with a click of a button - now you must swop hoses...
Aug 17, 2011 | Maytag Legacy MAV208DAWW Top Load Washer
I have Kenmore washer. Anytime the selection is on cold, warm and cold, hot and cold the washer makes squicky noise and very little water come out even though both hot and cold water are open. the only...
from what you said it sounds like you have a problem with cold water coming into the machine,shut off the house water valve,remove the water lines off the back of the washer and mark them so you'll know where the connect when you put them back onto the washer,stick them in a backet or in the tub of the washer,turn the water on,if the water comes out strong then you have a problem with the water valve on the washer,see if you can pull out the screens out of the valve and clean them but most likely you'll need to replace the valve.if the water doesn't come out strong then you have a problem with the house water
Feb 22, 2011 | Kenmore Washing Machines
Cold Water coming out very slowly, warm and hot fine
take the cold water hose lose in the back of the washer and you should see a filter inside that little hole pull it out and clean it
Oct 17, 2010 | Fisher and Paykel GWL11 Top Load Washer
No water coming into washer
Behind the dishwasher there is normally a two little taps 1 for cold water and 1 for hot water, check that the taps are turned the right way and are letting the water into the mechine. post back what you find.
Apr 05, 2010 | GE Nautilus 24" Built-in Dishwasher
NO COLD BUT ONLY HOT WATER ENTERS WASHER
here's no cold water Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
If you're sure the machine is not working the way it used to--or should--check the following.
  • Is the cold water turned on? If not, turn it on.
  • Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct.
  • Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve.
Apr 01, 2009 | Maytag Washing Machines
Sealer that goes around the tub to keep th water
part is $115 list (cost is less for techs). I have posted instructions on other posts. install is fairly easy. little work involved
Mar 30, 2009 | GE WBVH6240F Front Load Washer
Kenmore Top Loading washer gets very little cold water
You could try reversing the water lines and see when you select hot if cold comes out strong. If it does not then it should be the valve. If it comes out good in reverse, it could be the tempature sensor. Here is the link to parts and diagrams.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=11023032100&productCategoryId=0153200&brandId=0582&modelName=WASHER&diagramPageId=00003&componentDescription=REAR%20PANEL&documentId=P0110152&backToLink=Return%20to%20Sub%20Components%20list
Mar 04, 2009 | Kenmore 24032\24036 Top Load Washer
Dryers Logo
32 people viewed this question
Top Dryers Experts
