Question about Amana NAV8800E Top Load Washer
Roaring sound when spinning, seems like it is going to fly out of pantry lol
My washer has never had a problem at all, and i love my amana, but lately i am getting a huge worry, it has started sounding like it is roaring during my spin cycle. it is loud and seems as if it is just going to fly off. i take such good care of my things, not a scratch on it, help me fix this so i do not have to buy a new washer, i do not like the new ones. model is dlw330ram, serial 10079170al, mfc date is e02af
motor 568pxmcm-1069 ty ty upset in kentucky sandeeadams
  • SAUNDRA ADAMS Jun 26, 2008
    ty for such a quick reply, i am sure you are correct. how long could i run it this way, until i can save some money to get it fixed, and what will happen if i do run it for a while. my sincerest thanks for you quick attention. sandeeadams
  • 413 Answers
Either the tub bearing or lower bearing has failed. Replacing either bearing can be expensive and time consuming. Sorry for the not so good news....
Regards,
reg501
Posted on Jun 26, 2008
  • Richard
    Richard Jun 26, 2008
    If the tub bearing is bad, it is a sign the seal has failed and could start leaking. You can run the machine until the bearings lock up but this may also damage the transmission. Check you owners manual for limited warranty. The transmission may be warranted for 10yrs. Just keep an eye on any water coming from under the machine.
  • Richard
    If you decide to repair it and is less than 10ys old, call Sears and ask to purchase a "Smart Agreement" (wait to see if they offer you one first, they should). The fixed price they offer you (around $200.00) will cover parts and labor plus provide you with 1yr unlimited warranty. In your case, a good bargain.
    Regards,
    reg501
LG Front loading washer is noisy in spin cycle.
K this is a very complex job because it sounds like you may have coins (money) that has fallen between the gap. If this is the case, then the only way is to open up the back panel and look for it. However, I would not recommend doing it as the warranty will be void if you do. Now the stupid thing about this is a service tech will charge if it is coins lol. If it\'s the machine itself then it will be free provided it is still under warranty. Good luck!
Sep 23, 2014 | LG WM2487H Front Load Washer
Top loading Kenmore h e washer roars while spinning
kind of hard to solve without more info.but it could be unlevel find a level or borrow one and place on top of washer.make sure it reads between bubble on level.check both sides on top of washer.if you hear kind of grinding noises and shifts hard it could be transmission..
May 26, 2014 | Kenmore 24032\24036 Top Load Washer
I have an Amama NAV5800AW washer machine and about a month ago every time the washer is on spin cycle it makes a VERY loud sound, and lately has been leaking water during the spin. Any thoughts.
The noise you are hearing is the main tub bearing. Water has been leaking past the seal and into the bearing causing it to rust.There is no lubrication on the bearing anymore and you are hearing the metal on metal grinding. You are looking at a costly repair of about $350. I hope this helps you out.
Feb 28, 2011 | Amana NAV5800AW Top Load Washer
Spin cycle at high rpms is an extremely loud roar. This has changed considerably since purchased 2 years ago
This sounds like main tub transmission bearings.
Not economical to fix
30 years Experience in Home Refrigerator,Washer,Dryer, Repair
I would love to help you find a solution.
Leo Ponder
imufo2
Aug 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Roars when spin cycle
You are right it is the bearing also called a tripple lip seal and there are special tool to do that job if it has a metal outer tub I would not repair it. If it has a plastic outer tub the repair will fix it
Mar 29, 2009 | Maytag HAV4657 Top Load Washer
ROARING SOUND IN SPINN CYCLE
your bearings are shot your washer needs to be rebuilt it would be cheaper to go buy a new machine
Dec 23, 2008 | Maytag Legacy Top Load Washer
Hi, I have a 5yr old Amana Distinctions Super Capacity Plus top load washer, 2spd motor, 3.3 cu ft. I have taken off the front cover to expose the wash tub, because recently when the washer is in a spin...
sounds like a drain pump issue, not able to remove water quick enough before the centrifical force of tub spinning throws it over the top, remove the pump hoses and look for blockages
Nov 07, 2008 | Amana Washing Machines
Washer
Brake assembly is failing.If the noise is like a loud roar sound,than its not a good idea to fix this.The labor is going to be high.
Apr 29, 2008 | Maytag Performa PAV2200
Spin cycle
  Did it make this noise just when it stopped spinning.  Just for a couple seconds?  If so,  it's only brake noise and not a concern.  If it does this all during spin you probably have a bad tub bearing.  Is it a roaring noise?  This is what the bearing will sound like.
Oct 28, 2007 | Maytag PAV2300 Top Load Washer
Amana NAV8800E Top Load Washer Logo
259 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
