Question about Acer Aspire 5100 Notebook
My Acer Aspire 5100 is messed up ?
When I turn it on, it works but most of the time, it shows the acer writing then says " realtek boot agent " or something and I cant boot Windows...
Its running Windows XP MCE.
Also, when I turn the laptop on IF I get to the windows boot screen and then get to the desktop ( a big achievement ) if I move the laptop, the screen goes blue and then it reboots with " Realtek boot agent " why is it doing this? please help me.
Thanks in advance
  • Anonymous Apr 14, 2009
    I have a acer Aspire 5100 and the dog Knock it off the counter now as soon as i turn it on it reads realtek pxe - e61 media test failure Check cable what do I do
    Genius:
  • 2,028 Answers
I had a laptop in my shop recently with the same problem. If you moved the machine at all it would blue screen. The problem was a connector on the motherboard that had came loose and was shorting the system out. I had to tear the machine completely down, and it took me hours to find it. With that said, you have a short somewhere on the board, whether it be a loose connection or bare wire, and it would be in your best interest to take it to a professional to find the problem.
Posted on Jun 26, 2008
My Acer Aspire 5100 keeps rebooting. This is what the screen says: INTEL UMDI PXE2 REALTEK RTL8139 PCI FAST ETHERNET CONTROLLER PXE-E61: MEDIA TEST FAILURE CHECK CABLE PXE-M0F: EXITING PXE ROM That is all...
The error message means that your system is trying to boot from LAN ie... Network boot enabled in your BIOS.
Since the system can't find any where to boot from. It is restarting.
Also probably your bootloader on the harddrive is corrupt. Please reinstall the operating system using a CD/DVD.
Jul 11, 2010 | Acer Aspire 5100 Notebook
My ACER Aspire 5100 does not start and show a message For Realtek RTL8139(X)/ 8130/ 810X PCI Fast Ethernet Controller V2.13 (020326) PXE-E6111: Media Test Failure, Check Cable. PXE MOF: Exiting PXE ROM....
Open the Device Manager, uninstall the Realtek from there. Restart the laptop and see if its automatically loads itself on Device Manager well good enough. If it doesn't then you would need to get the motherboard CD of the Acer Laptop and install the Realtek Driver.
May 31, 2010 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Laptop Screen Works Intermittently
Since you have video with an external monitor your lcd panel is going out.This is not hard to repair only costlyhttp://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Apr 06, 2010 | Acer Aspire 5100 Notebook
Acer Orbicam Colour Problem!
The display is gone. Replace it.
Nov 29, 2009 | Acer Aspire 5100 Notebook
NEED DRIVERS FOR ACER ASPIRE 5100
Hi there
You can get all the drivers for that model from acer support site>>>>
http://support.acer-euro.com/drivers/notebook/as_5100.html
Good luck and thanks for using Fixya!
Jan 15, 2009 | Acer Aspire 5100 Notebook
PROBLEM WITH ACRE ASPIRE 5100.... DOES NOT BOOT
try to boot into safe mode, to do this restart the pc and as it boots hit F8 repeatedly, this will bring a sub menu up and choose safe mode, when in safe mode perform a system restore and take it back a week or so
I hope this hepls and please don't forget to rate us
Dec 11, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Bios
Make sure you have all the latest updates found in the Acer site and Windows Update. Windows Update has the hardware update for the Realtek hardware in question. Also, make sure your BIOS has been updated. Make sure you are also running under a Verified XP OS. Aspire 5100 usually comes with Windows XP Media Edition with all the "bells and whistles" Acer has to offer. Unfortunately, most companies that sell "Refurbished" laptops, fail to include an installation disk. So, you'll have to create a Recovery disk via Acer Recovery Disk maker. Folks forget this process and end up with an expensive manila folder.
Ultimately, this is a common problem for a lot of Laptop/Notebook users, and it really just takes constant care and caution to make things work. Most problems arise when you stop caring.
Finally, do a Complete system Audit by using a very useful program called WinAudit. It will tell you EVERYTHING you need to know about your notebook/PC. It will also help your knowledge of what is running on your computer and how to fix them.
Also...
(Make sure you have Admin rights for this one.)
Check your Device Manager by holding the Windows button and pressing the Pause Break button (close to the DEL button on the upper right hand corner) Click the Hardware tab. Then the Device Manager button. When the window pops up, click View> Show Hidden Devices.
You will notice that a few devices with a "Caution" mark on them. These are the devices that end up causing problems with startup and system failure. If you feel adventurous, you could disable the devices with little or no problems. Unless you have a Parallel and Serial Port on your Aspire 5100, get rid of them for good.
But, it's not the ONLY problem. If you have no Device errors pop up, and the same problem occurs, then the best thing to do is to take it to a "Trusted Certified Professional."
Good Luck
Dec 09, 2007 | Acer Aspire 5100 Notebook
My Acer aspire 5100
If you are able, when the pc is booting up keep pressing F8, this will take you to safe mode and not allow the graphics driver to run. When in the safe mode options, select either Last known good configuration or start windows in safe mode. Last known good configuration should find the last good system settings, when it reboots. Start windows in safe mode allows you to go into windows using the administartor account, and then you should select system restore and restore back to the day before or just before you updated the graphics driver.
Aug 16, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
99 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
