Olympus FE-370 Digital Camera Logo
Posted on Dec 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I replace a cracked LCD Screen? Olympus FE-370
Anonymous
Level 2:
Scholar:
  • Expert 130 Answers
  • Posted on Dec 03, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
130
Questions
Helped
17953
Points
407
This requires technical skills plase attempt this only if you know about electronics as there are many of the delicate components attached with the LCD screen in a digital camera.Open the camera carefully and do not touch or bank anything against it's lens senser inside as it might even detoriate the quality of the photos you take with the camera after replacing the LCD screen.Carefully remove any loose remains of the screen broken now apply solder carefully to the strip wire connecting to the screen boken with a de-solder wik to remove the connections from the main motherboard.Take out the broken screen and clean the terminals of the main motherboard with some alcoholic spirit or petrol to remove all dust and dirt from the terminals accumulated on them now take the new screen and solder the ribbon like wire on the terminals by applying minimal solder on each terminal with the soldering iron remember not to apply excess of solder on any of the terminals as they might get shorted with each other and will damage the camera as well as the new LCD screen replaced when powered on.If in any case you see any terminal shorted with one another then remove the excess solder with the help of de-solder wik or a hot air gun .Replace the screen by soldering each terminal carefully and now replace the cover and your camera is ready to click photos .BUT STILL I WOULD RECOMMEND YOU THE REPLACING ACTIVITY ONLY IF YOU ARE A TRAINED PERSONAL IN THE FIELD OF SOLDERING MICRO-ELECTRONIC COMPONENTS.
Also that use a soldering iron of 25watt or less as the heat might damage the delicate components
4helpful
How do I delete all the pictures at once on my Olympus FE-370?
Go into the menu and find "format"...follow the on-screen instructions.
Olympus FE 370 Broken Screen
You need to remove the back of the camera by removing the screws that goaround the perimeter. Then gently pry open the back. Then gently pry the screen edge that is closest to the out side and work around till it loosens. Then you must peel back a clamp tiny bar that holds the wire cable on to release it. reverse to install.
Fell down while holding camera Olympus fe 370. got a dent next to the vewing screen, it lights up but it's blanc. whats the next step?
Looks like you just broke the LCD display. Find one on ebay and DIY replace it. It seems the cheaper way.
1helpful
2answers
My olympus fe 210 has the lcd screen broken, I would like to fix it by myself, how to replace it?
Hello Fabio,
You can find the replacement LCD screen for Olympus FE210 here:
http://www.pantallas.biz/epages/wwwpantallasbiz.sf/en_GB/?ObjectPath=/Shops/160419/Categories/Olympus
2answers
Olympus D560 Digital Camera LCD Screen
The LCD screen on my Olympus fe-230 camera is cracked and I am trying to find a replacement screen to install. Any ideas where I can find one? Is this something I can replace myself
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
