Question about Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony blinks 6 times wont turn on...is it worth fixing
  • 2 more comments
  • txwindstrm Jun 29, 2008
    I have the same problem with mine. I have unplugged it from 60 sec to 24 hours. That seem to work for about 3 times. Now all it does is flash 6 times. Does any one know what the 6 flashes indicates? Please let me know!! Regards, Txwindstrm
  • sobwon Dec 23, 2008
    This problem just started for me as well. I am not a service tech nor do I believe that I should try to open the TV. Any other suggestions?
  • Anonymous Jan 27, 2009
    damn same issue, it may be cold?
  • b-schweighof Apr 01, 2009
    has agreat picture still but once it gos off it takes me a few days to get it to go on again.
    i just turn down the sound or put in another vidio mode.Itried to get a battery back but only found one for $39.
    I would like to get it fixed for a reasonable price.
    Sony should fix it as it seems common for this model
    Any help would appreciated b-schweighofer@hotmail.com
Sony 60" KDS60A2000 - no power - 6 blins - It is main PCB problem (A-1205-146-A A1 Board)
Posted on Dec 02, 2011
    Scholar:
  • 170 Answers
Replace on the D board
IC6501
IC8002
C6510
C8027
C6532
C8037
Hope this fixes you, if not then alot of other might get theirs fixed. please leave your feedback!
this fix cam from sony tech just 5 minutes ago.
FIxes problems with tv not turning on when cold, very hard to turn on. or people that have to unplug and plug in again to get it to come on. I usually dont give info like this for free as I'm a head tech.
good luck
Posted on Dec 09, 2008
  • 1 more comment
  • Scott Henderson
    Scott Henderson Dec 23, 2008
    Replaced these parts after talkin to sony tech and it did not fix my problems. although when i called back tech said usaully this fixes the problems. I am now trouble shooting the power supply's.
    here is a schematic pdf that sony emailed to me yesterday.
    NOTE: they are not the best at making pdf files! maybe this will help alot of you out there like me.
    http://www.megaupload.com/?d=8JKVYTSG
    I think since after about 20 attempt starts the set does work. and if i unplug the crt and yokes. (do not unplug just yokes you will burn your tube.) the set will run forever durring this shutdown period. I may try dissabling the protection circuit using the schematic to see if it is faulty. if not at least i can check to see if all the run voltages are correct. I will report back if i get anymore. please report back if anyone else finds anything or simalar symptoms.
    lets get this problem nailed.
  • Scott Henderson
    ok dissabled HV protect and crt protect, and it did not help. dissabled q6522 OVP SW and set runs. believe this is the over current protect switch.
  • Scott Henderson
    Scott Henderson Apr 07, 2009
    unsoldering q6522 has fixed several sets for me. good luck with yours!
3 Suggested Answers
stihl_070509
  • 95 Answers
SOURCE: Sony KV-32.FS120 wont turn on and stand by flashes
5 blinks indicates that your system has detected fault on Chroma board (Chroma board is the only board connected at the rear part of CRT). Often there are loose connection on IC terminals. Re-soldering of ic terminals can fix your problem.
Posted on Oct 22, 2010
AJIN G
  • 6694 Answers
SOURCE: I have a Sony Trinitron
hi,
ur tv has problem with horizontal output stage. check the horizontal output transistor. if it found short replace the same and switch on the tv. if the same fault occur again, then the lot (line output transformer) may be faulty. also check for any dry soldering in the power supply stage and horizontal output sage.
ok
Posted on Jan 03, 2011
Hello, I have an issue with a SONY KLV-40BX400, the TV turns on, displays the sony logo and plays the power on sound then turns off and turns on a few times and then doesnt turn at all and
If it is PLASMA TV.....
brandon barnes mentions..there is usually nothing physically wrong with 6 blink tvs..you need to reset the TV using the original remote
Not sure if the fix mentioned below is appropriate for your TV Sony eSupport Electronics Drivers Software
Aug 03, 2016 | Sony Televison & Video
My sony trinitron kV ES 34M90 GIVES 6 ERROR BLINK CODES
Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206. To get more details, http://electronicshelponline.blogspot.com/
Nov 28, 2013 | Sony Televison & Video
Sony trinitron 36" has 7 red blinks wont turn on
I HAVE A SONY TRINITRON KV-36HS510. IM HAVING A PROBLEM,ITS NOT SHOWING A PIC, AND BLINKING 7 TIMES THEN PAUSE FOR A COUPLE OF SECONDS THEN IT WILL BLINK 7 MORE TIMES,I CAN HEAR AUDIO BUT CANNOT SEE PIC. COULD YOU PLEASE HELP ME OUT ,I'VE TRIED CUTTING THE TV OFF FOR ABOUT 6 HOURS AND CUTTING IT BACK ON,SAME RESULTS, THANKS
Jan 02, 2011 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony KV-32.FS120 wont turn on and stand by flashes 5 times. Is this any easy and inexpensive fix or not worth the time and money since tv is 6 years old ?
Oct 19, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Philips 42 wont turn on
I am having this same problem. I have "fixed" this problem twice by replacing 2 failed capacitors inside. The fix is pretty easy and the cost of the replacement parts is about $2.50. Unfortunately, the fix doesn't last. The first time, the TV worked again for about 6 months, but the 2nd time, when I replaced with higher grade capacitors, I only got another 2 weeks out of the TV. I think it's time to cut my losses and get a new set. Repair costs were estimated at $600. ...just not worth it.
Jan 25, 2010 | Philips Televison & Video
It wont turn on it blinks 7 times can i fix this
Hi there.
In sony tv`s the seven blinks code(sony error codes)usually indicates a high voltage shutdown(t.v has exceeded 33k volts). That is often caused by the power supply regulation and/or horizontal circuit fault.
Hope this help Merry Christmas
Dec 19, 2009 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Unit only blinks 6 times
The Sony blink code for six flashes is:
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
you will have to get this faulty components as mentioned above to be replaced.by any professional technician. the cost will be negligible and its worth getting it fixed. thanks. please do rate the solution.
Apr 03, 2009 | Sony KDS55A2000 55" HDTV
Set wont turn on, stand by lights blinks 9 times
Have the same thing happening with ours... we were told by a repairman that it needs a new D Board. He told us that if we could fix the TV for under $500 that it was worth it, if not (which of course, we can't when you add in labor cost) don't fix it. I like the TV but I can buy a brand new flat screen for that!
Good Luck
Mar 29, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Sony FD Trinitron KV-40XBR800 wont turn on
30 YR SERVICE TECH.
YOUR UNIT IS EXPERIENCING A POWER SUPPLY FAILURE.(INTERNALLY)
TAKE TO A SONY AUTHORIZED SERVICER.
Jan 12, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Stand by light blinks 6 times, wont power on
Here you find sony blinking codes
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
and the unit goes immediately into safety shutdown. Check power supply
regulation and horizontal circuits.
Aug 10, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony FD Trinitron WEGA KV-32HS500 32" TV Logo
2,195 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
