CARRIER COMFORT ZONE AIRCONDITIONING SYSTEM, HF 41 ON SCREEN
WE INSTALLED A 4 ZONE CARRIER COMFORT ZONE AIRCONDITIONING SYSTEM IN OUR WHEN WE BUILT IT IN 199E. DURING A RECENT THUNDERSTORM THE BLOWER CAME ON AND THE SCREEN ON THE CONTROLLER INDICATED AN "HF 41" ERROR CODE. THE HIGHEST NUMBER IN THE BOOK IS AN HR 33. WHAT'S THE PROBLEM? BONEY JO
james3751
  • 614 Answers
SOURCE: The Infinity Comfort Control code
Call your local Carrier dealer. They have code to get into system. Rusty Good system
Posted on Jun 04, 2009
  • 17 Answers
SOURCE: I get the error code E2 It only shows 2 zones on my 4 zone syst
I reset the circuit breaker to the panel and everything is good now.
Posted on Jun 25, 2009
  • 38 Answers
SOURCE: Carrier Comfort Zone 2 flashing E2
the e2 error on your thermostat is a problem with the return temp sensor on your system, the only thing you can really do is call a company and replace it, you can't bypass it or remove it cause the system wont run properly
Posted on Jun 30, 2009
james3751
  • 614 Answers
SOURCE: Carrier Comfort Zone 2 Master is flashing E5
Check float switch. E5 is loss of 24 volt power on some models.Russ
Posted on Jul 27, 2009
  • 22 Answers
SOURCE: Carrier Comfort Zone II Smart Control in one zone
sounds like your zone control tstat needs calabrated or maybe replaced,in owners manual there should be a section on calibration if not you may have to replace it
Posted on Sep 15, 2009
The Carrier comfort zone thermostst displays the
Go to panal and reset control. Small reset button on control board. Let me know if it clears.James
Oct 12, 2009 | Carrier 38CKC042 Air Conditioner
We have the same problem, was hit with lightning and came up E1
You didn't get a Carrier tech. Carrier technicians only work on commercial equipment. Residential applicaitions, installation and service of Carrier residential units are done by dealers. They are not carrier owned but get buy the product at discount get training and get to show our logo. You can't fix the boards, they have to be replaced. It sounds like you have a Gen II VVT system. You can get the part via Totaline stores or a distributor. You will need to know how to readdress the other controllers to operate correctly. Use WWW.Carrier.com.
Aug 03, 2009 | Carrier 38CKC060 Air Conditioner
Jul 27, 2009 | Carrier 38CKC060 Air Conditioner
Blank readings on Carrier Comfort 3 zone thermostat
The stat that works is called the main and the other two are called slave stats. The stats must be set to heat or cool the same as the main. If you want one room to cool and one to heat , sorry. Need to upgrade to auto changeover. Is this AC actally a Heat pump?
Jul 01, 2009 | Carrier 38CKC042 Air Conditioner
Jun 24, 2009 | Carrier 38CKC060 Air Conditioner
May 21, 2009 | Heating & Cooling
Failure in comfort zone one
There is a capacitor connected to the motor on the compressor. If it fails, the motor won't start and the safety thermal cutoff will stop voltage at the motor terminals. There are fuses inside the power interrupt box on the side of the outside unit. One of them may have blown
May 09, 2017 | Amana Comfort Zone 18M33PCEH Air...
Carrier Air Conditioning
Have the tech come back. the problem did not exsist before he pulled the board. He either left his jumper wire connected by misteak or he shorted the wires to get the fan come on so he could check the operation. Either way he created this mess and is responsible. Most service techs would return and fix his problem just out of pride in his work. If this guy will not return then contact the BBB and the licesing board for the state you live in they have an investigative unit just for guys like this. good luck
May 29, 2008 | Carrier 38BRC048 Air Conditioner
Heating & Cooling Logo
267 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
