Question about Candy DQW150 Front Load Washer / Dryer
Candy dqw 150 how to reset the dryer
I have had this problem before when the dryer does not heat up to dry the clothes,i called engineer out and he said it just needed resetting it took him 2 seconds to do the job!!!!...now problem is here again and i need to find out how to reset the thing!! any help would be great
  • jallijn Jul 28, 2008
    I have the same problem. Resetting helps temporarily, but after washing once the problem reoccurs and I have to reset again.
    Is there an other sollution for this problem? Maybe a filter?
    President:
  • 1,462 Answers
I'm guessing a bit but the part that was reset was probably a resetteble thermostat on top of the dryer air manifold. take top off machine and you will see stats mounted on top of the air duct. one or more will have a little buttonin the middle. press this button and you will hear a slight click and the dryer will then work.
however, if the problem is reoccuring, then there is probably a lint blockage in the air duct causing poor air flow
Posted on Jun 26, 2008
Hi I have candy gcc590nb condenser dryer after a min or 2 it stops working and the start button flashs at a constant flash the clothes do heat up and the you can feel warm moisture
Check your belts and see if they are broken. Your blower may not be running. With no blower there will be no air flow there for not drying.
Jan 27, 2017 | Candy Dryers
I have a candy dryer civ 100 don't heat and dry the clothes what is the problem
timer heating element , door lock ,many things can cause this .
Nov 08, 2015 | Candy Dryers
My washer/dryer isn't drying clothes
this is all i could find on the internet and that is the manual not sure if its going to be of any help to you but you could go to this link and download the manual and see if it does help you out.
i think its the first one on the page.
candy alise go4w464 washer dryer not drying clothes Google Search
Oct 31, 2017 | Candy Washing Machines
Hi I have a dryer (Speed Queen) and I took off the front panel and cleaned everything and even in back, When I turn it on, I see the flame, But it does not get hot enough inside to dry the clothes, Is...
Clothes not drying, but dryer runs & heats
1. Defective operating thermostat---test thermostat,, replace if defective
2. Fan or it's pulley loose on shaft--tighten set screw
3. Incorrect heat or timer setting--reset timer
4. Clothes too wet when placed in dryer--wring clothes before putting them in dryer
5. clogged lint screen or duct ( little air motion)---clean
Sep 21, 2011 | Speed Queen AGS68AWF Gas Dryers
CDB115
should be a reset switch on the back of the machine usually just a red button or small hole if not there is over heating protection on the heating element or elements if it has 2 heat settings ,but these cannot be reset have to be renewed
Oct 05, 2008 | Candy CNW156 Front Load Washer / Dryer
Cdc266 tumble dryer
hi you have to clean the inside of the machine I.E. remove the drum and on the back of the machine there are two heat sensors, the ceramic sensor is possibly faulty and needs replaceing
Aug 07, 2008 | Candy CDC266 Dryer
Candy CMD146 Washer/Dryer
Is the dryer electric or gas? If electric, the heating coil may have burnt out. If gas, check gas supply and then gas ignitor. Good luck.
Jan 28, 2008 | Dryers
Clothes dryer
washer dryer and dryer ony machines differ in a huge way. the big diff. is the drums on each are completly different sizes. the conventional dryer has the bigger, giving better air flow and tumble to clothes. the w/d has a smaller drum thus less air flow and less tumble between clothes. the best way to see this effect is remove half the clothes after a wash and then select a drying cycle. u will see that by giving the clothes more room to tumble free of each other rather than tumbling in a large ball will dry them. washer dryers are really only a marketing tool.
(ex main brand engineer)
Nov 12, 2007 | Candy DQW150 Front Load Washer / Dryer
Clothes dryer not getting hot enough to dry in a good time frame
I have the same issue with my DLG3788W dryer. It seem to have only one setting for heat, rather than multiple heat settings. What can I do or do I have to call someone to repair this.
Oct 03, 2007 | LG DLE0332 Gas Dryer
Candy DQW150 Front Load Washer / Dryer Logo
434 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
