Question about Hotpoint Ultima WF865 Front Load Washer
Hotpoint wf865
When i enter proggrammes test comes up every time
This relates to models, WF620-630-640-645-720-730-740-745-860. Also some WD models
It is in fact a Demo mode.
There have been 3 versions of Demo Mode used on these appliances.
Version 1(Production to- Date code 39 March 2005)
To Activate
1. From the Default screen of a programme, after switching the appliance on press both Start/Cancel and On/Off buttons together until d On appears in display.
2. Press the Start/Cancel button only and tESt appears in the screen (Temp & Spin symbols also appear)
To Deactivate
Press the Start/Cancel button until all the console LED's illuminate.
Press both Start/Cancel and On/Off buttons together until
d OFF appears.
The default screen returns and you can select a new programme.
Note:- The default screen information displayed on these models is that of the programme currently selected by the selector knob.
Version 2 ( during Date Code 39 March 2005- to Date Code 42 June 2005)
To Activate
1. Same method as version 1.
To Deactivate
1. Simply press the Cancel button and the appliance returns to default.
Version 3 (During Date Code 43 June 2005 - to date )
To Activate
1. Press On/Off and Start/Cancel together with the top left option button until d On appears.
To Deactivate
1. Press On/Off and Start/Cancel toghether with top left option button until d OF appears.
These variations could explain why some of us have to make several attempts to clear tESt.
Posted on Jul 28, 2008
  • xpatel Apr 27, 2011
    Your tip to deactivate is SPOT ON, thank you.
Press on off button till test comes up then press on off and start cancel button together for a few seconds
Posted on Jun 30, 2008
Hi my hotpoint wf865 is not letting any cold water into machine its flashing h20 have checked the hoose and water is okay there help!!!!!!!
H20 does indicate a problem with water suuply, if you are satisfied that water is present at the inlet valve, then I would suggest that the valve is faulty, or is not getting a power supply ot it.
You need to determine if the valve is getting power witha test meter.
Dec 12, 2010 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint washing machine - WF865 showing F-08 fault
F08: Heater control or NTC (Thermistor) temperature sensor problem.
Jan 23, 2010 | Hotpoint Ultima WF865 Front Load Washer
How do i fit a belt to hotpoint washing machine WF865
*********** unplug from mains************** top cover off ....rear cover off ....remove old belt belt ...place new belt on lower puly feed it on to larg pull turn at same time ************WATCH YOUR FINGERS ********THEY CAN GET CAUGHT EASY******* done .put covers back on ...
Dec 30, 2009 | Hotpoint Ultima WF865 Front Load Washer
Washing machine stuck in test mode hotpoint wf865
To get out of it you need to press start, the display should go daft. Press start again and the display should settle down. Now press the on/off button and the start button at the same time and hold them down for a few seconds until the display shows d-end or d-off.
Your machine should now work. hope this helps.
Nov 22, 2009 | Hotpoint Ultima WF865 Front Load Washer
Hi i have a hotpoint washer model wf865 it comes up on the display panel saying test and that is all it does can you help.
Unplug washer for ar least 1min and see if this reset the hardware in the computer. If not you will need a service provider.
Oct 27, 2009 | Hotpoint Ultima WF865 Front Load Washer
Test mode
press start once
then press start again now hold on/off and cancel together for a few secs should no say d/off or something should work now
Aug 22, 2009 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint wf865 washing machine
to take out of test mode you must turn it on while pressing the start/cancel and on buttons at the same time until dOFF appears.
Jan 18, 2009 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint WF865 Child Lock Button Stuck 'On'
you should be able to turn it off by holding it in for a while longer,5-10 seconds, unless the circuit board is at fault.
Jan 07, 2009 | Hotpoint Ultima WF865 Front Load Washer
Wf865 reset
Press "end of cycle" button for over 5 seconds, the child lock comes off. Press it again and the child lock comes on, this works for Hotpoints, you could try, no harm.
If it works, pl rate me.
Nov 06, 2007 | Hotpoint Ultima WF860 Front Load Washer
Model no. wf865
This in not a listed error code, it is probably as a result of a faulty control module.hen fitting a new board it needs to be set up and is not really a DIY job, this model comes with a five year parts warranty so it may be cheaper for you to call hotpoint. Regards Advisor
Aug 19, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF865 Front Load Washer Logo
197 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
