Question about Philips DIRECTV H20 DTV Receiver
Heat I received what appears to be an H20(reconditioned) receiver from Direct TV as a replacement for a standard definition receiver. This latest receiver generates a tremendous amount of heat; so much so that it's almost too hot to place my hand on the top of the receiver. Is this normal???
  • 1 more comment
  • rappaw386 Jun 26, 2008
    Thanks for the advice. I'll try to get something done just as soon as I can actually get through to someone at DTV.
    FYI: I've been trying for two days to get through to DTV for an unrelated(?) problem without any luck. Any additional advice?
    Thanks in advance.
    Thanks.
  • Anonymous Aug 05, 2008
    Same with my H20 Box
  • 44 Answers
These units run hot and always have even when "off" ( I have four of them and putting your hand on any of them is always uncomfortable). To tell if yours is abnormally hot, do the following:
On your remote:
1. Hit menu
2. Go to the bottom selection "Parental, Fav's & Setup"
3. Hit "System Setup" on the next page
4. "Info & Test" will be selected, press the "Select" button on your remote
5. On the right you will see "More System Info" move the yellow select bar to this and hit the remotes select button. "Please wait" will show up while it checks your internal settings and readings.
What to look for:
- About 9 lines down you will see internal temp. and a reading in 'F.
Mine have been as high as 138' F (With nothing on top to stop ventilation). If yours is much higher, I would go to Directv and ask for assistance. I have always had great success getting to them at 1-800-531-5000.
Suggested general solution:
Anyone familiar with electronics knows that heat is a component killer. Since these are lease receivers, I have to think that DIRECTV has done some amount of homework and find these high temperatures "acceptable" if not ideal. If I were you, I would get a lop-top cooling pad off of eBay or from Bestbuy or Walmart that has a USB connection and plug it into the back of the receiver. I have been running mine for over a year now and my max temp, even on hot days is 118' F. A full 20 degree drop.
I placed my cooling pad on top of the receiver so that it sucks air out of its vented top cover and blows it into the room. This works great and, since it is USB power compliant, it does not over-stress the USB port on the receiver. Just keep an eye on it as the fans will eventually fail. I simply check my temperature every once and awhile to make sure it is "cool".
Hope this helps and best of luck! -Dan
Posted on Jul 21, 2009
  • deschilz Aug 20, 2009
    Sorry for any confusion. Looks like the internal temperature read-out on the setup screen is available on the HR20-700's and not the H20's (at least the earlier H20's). The USB port is on both so either way, a USB powered cooling pad is a good idea.
    Sergeant:
  • 260 Answers
No. this is not normal. this type of problem can be dangerous to keep in your house. you should get the device replaced right away.
Posted on Jun 26, 2008
  • Ken Jones
    Ken Jones Jun 26, 2008
    sorry to hear about that. best of luck to you.
On the weekend my H20 receiver started with continues rebooting,until it got to the point that it stays on the boot with the lights of the 480i,720i,720p and 1080i they are blinking all the time first the...
I'm guessing you have the H20-600. They got recalled. More than likely, your receiver is bad.
If your installation was in the last 3 months, do your technician a favor and call him if he left his number or office number. Even though you have a faulty unit, a 'repeat service call' still counts against him and it could effect his work flow. Call them and they will do what they can to help you get a new unit without harming the technician's stats.
If your installation was not in the last 3 months, call DirecTV. This is pretty much a receiver issue (an issue like a bad connection or switch wouldn't cause this problem). You can probably try to get them to directly mail you a new box (you'll be able to ship your old one back for free) instead of forcing you to wait for a service call. If you have the H20-600, you can probably get the box for free but you'd definitely end up paying for the service call.
Mar 09, 2010 | Philips DIRECTV H20 DTV Receiver
H20-600 Overheating causing "Searching for Satelite" Code 771
I had a H20-600 that worked consistently until I unplugged it, then it would not power up unless the unit was warmed to its operating temp. (I placed it on an old iron radiator, warmed it up, it then powered up). The power supply on the unit had several failed, crowned capacitors (3300uf/10v). I pulled them, tested them (one was bad), and then replaced with good caps. Up the unit came. The PS in this unit is a switching unit and needs healthy caps to oscillate and create sub voltages. The standing heat in the unit makes the caps get hot, crown and leak. See any brown sputum on the top of a capacitor and it is on the road to failure.
Jul 31, 2009 | Philips DIRECTV H20 DTV Receiver
I have 15 bad direct tv reciver h20 h21-200 does not powerup
If you are not getting any power to the box, then the power supply may need to be changed.
Jul 10, 2009 | Samsung SIR-TS160 DirecTV DTV Receiver
My parents blocked my directv box and i dont know the code can
unfortunately only directv can reset the passcode. there is no way to override this.
Jan 29, 2009 | Philips DIRECTV H20 DTV Receiver
Direct Tv Receiver No sound Black Screen
unplug the power from the reciever for a few moments. plug it back in and let it load. once its finished turn to channel 201. Usually it the reciever is on an unavailable channel (channel with no programming) when it restarted it will go back to that unavailable channel hince the black screen and no sound.
Jan 01, 2009 | Philips DIRECTV H20 DTV Receiver
N2750W PROBLEMS WITH DIRECT TV
just press the "PIP" button on the remote it happened to me and i just thought that it looked familiar and i pressed it and it worked hope it helps :)
Nov 19, 2008 | ViewSonic N2750w 27 in. HD-Ready LCD...
H20 Reciver power up problems
same problem on two different h20 receivers - called directv and explained the situation each time. since these are leased receivers, new ones on the way.
Apr 19, 2008 | Philips DIRECTV H20 DTV Receiver
Direvtv h20 hi definition receiver
Dtv only lease receivers even if you buy it online, or retail stores
Oct 30, 2007 | Premier Mounts Universal Flat Panel Wall...
Philips DIRECTV H20 DTV Receiver Logo
293 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
