Question about NetGear WGR614/WG511 (wgr614nawg511nakit) Wireless
Wireless router hi i have recently bought a netgear wireless router i have set it up step by step earlier on today i was ok on the internet through my router but now im trying 2 connect to the internet i cant . Ive just phoned my internet provider there isnt a problem on there end because i can connect while putting the cable straight into my cvomputer but cant when i take cables out to go wireless can u please tell me why i cant connect thankyou x
  • kerryisboss Jun 28, 2008
    THANKS I HAVE ALREADY TRYED ALL THAT BUT THANKYOU FOR TRYING X
  • 137 Answers
First make sure wireless is turned ON or enabled on the computer, then use the View Available Networks to connect to the your SSID or network name. IF you can connect to router then you should be able to surf Internet.
Posted on Jun 26, 2008
  • nsindian
    nsindian Jun 30, 2008
    When you go wireless, what is the IP address for that adapter? When you connect via ethernet cable, what is the IP address for that adapter?
How to Install Netgear Router Using the Wireless Device
hi john.
To install your NETGEAR wireless router using your wireless device:
  1. Get the preset wireless settings of your NETGEAR router. It is written on the back or at the bottom of your device.
  2. On your wireless device, open the WiFi connection manager and find the SSID or WiFi network name of your NETGEAR router.
How do I install my NETGEAR router using a wireless device ...
https://kb.netgear.com/.../How-do-I-install-my-NETGEAR-router-using-a-wireless-devic...
How to Install Netgear Router Using the Wireless Device Google Search
Nov 06, 2017 | NetGear Computers & Internet
No internet connection
Check if you can , by pass the wizard and set the connection manually. Let me find more details for you
Thanks
proton
Jul 24, 2008 | NetGear RangeMax WPN824 Router
How to reset rangemax wireless-n 150 router?
Reset means that you will restore it to factory defaults which will delete all of the configuration settings of the router and will leave you not connecting to internet and wireless as well, but if you really want to reset it, just simply press the black button at the bottom of the N-150 router, press and hold it for at least 15 seconds. Once the lights on the router starts blinking, that means that it is successfully restored to factory defaults.
Dec 25, 2011 | NetGear Computers & Internet
How to instal
You'll wanna check out: ftp://downloads.netgear.com/files/WNR1000_SM_WW_23Jan09.pdf
Look for "installation"..
To help you set up your router and get on the Internet quickly, the Resource CD contains a Smart Wizard™ Installation Assistant. The Installation Assistant walks you through the steps required to connect your router, modem, and PC(s); configure your wireless settings; and enable wireless security for your network. When you have finished, you will be Internet ready!
You can set up your wireless router using one of two methods:
• Smart Wizard Setup: The Smart Wizard Installation Assistant setup is available on your Resource CD. See "Installing Your Router Using the Smart Wizard" on page 9 to use the Smart Wizard Installation Assistant.
- This is the easiest option. The wizard guides you through the setup process. It automates many of the steps and verifies that the steps have been successfully completed.
- Smart Wizard requires a PC running Microsoft Windows.
• Manual Setup: If you cannot or prefer not to use the Smart Wizard Installation Assistant, see "Manually Installing Your Router" on page 13. For example, if you are connecting to a Mac, are using a Linux operating system, or are technically knowledgeable, select this option. If you choose to use this option and install your router manually, for best results, install and set up your router in this order:
Failure to follow these guidelines can result in significant performance degradation or an inability to wirelessly connect to the Internet.
NETGEAR does not recommend or support adding a NETGEAR router behind another router, or replacing a gateway with a a NETGEAR router.
If you have a Macintosh or Linux system, you must use the manual installation method (see "Manually Installing Your Router" on page 13).Getting to Know Your Wireless Router 7
1. Install and connect your wireless router to your network (see "Connecting Your Wireless Router" on page 14).
2. Set up your wireless router for Internet access (see "Setting Up Your Router for Internet Access" on page 18).
3. Configure your wireless network and select wireless security settings to protect your wireless network (see "Configuring Your Wireless Network" on page 21)
Feb 04, 2011 | NetGear WNR1000 Router
The wireless on my new router is not working but the wired is.My wireless can connect to the signal but it stills says no internet access. it was working earlier today but not now. I have a Linksys WRT320N...
If you connect the computer to the router , it works.
That means the wired connection is OK.
Open the set up page of the router check the wireless settings of the router.
I think your network is secured and you are not typing the correct network key.
just open the router set up and check the wireless settings .
Make sure that the DHCP server on the router is enabled
Click Here for step by step solution
May 10, 2010 | Cisco WRT320N Wireless Kit
My Netgear WG111v3 cannot connect to internet
You need to do some wireless setting on router,
Please follow steps to fix your issue
1.Please changed network (SSID)name of router
2.Reinstall adapter driver
If you follow above steps defenately your issue would be resolved
Apr 26, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
New laptop can't find network
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Jan 29, 2010 | NetGear RangeMax WPN824 Wireless Router...
How to reset Netgear RangeMax NExT Wireless Router WNR834B
Do a hard reset (20sec hold reset button, unplug for 20 sec still pressing the reset button and another 20 sec to turn on the power while holding the reset button). That should reset to defaults.
Jul 04, 2009 | NetGear RangeMax NEXT WNR834B Wireless...
Securing my network
Hi there!
I have step by step guide here on how to secure your wireless netowrk. Just click this link.
I hope this one helps.
May 13, 2008 | NetGear WGT624 Wireless Router
NetGear WGR614/WG511 (wgr614nawg511nakit) Wireless Logo
147 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
