Question about iLO DVDR05 DVD Recorder
ILO dvd recorder
Disc drawer will not open
  • Anonymous Nov 23, 2008
    Same fix.
I had the same problem with mine. Unplug the unit. Remove the cover (I think 5 screws). Then unscrew the cover plate of the drive and remove it. It is a little hard. You might have pry up the front of unit slightly to remove the cover. Once you have it removed try to slide the drawer open about half way should be good. If you look towards the front you will see what looks like black rubber band. That is the belt that moves the gears to open the drawer. If it is broken find a replacement. If it's not broken remove it carefully and clean it. Also clean the V grooves the belt sits in. Then replace the belt. Replace the covers then test it. Give it a try..It worked for me.
Posted on Nov 28, 2008
Try tapping lightly on top of unit after hitting the eject button
Posted on Jun 26, 2008
Magnavox ZV457MG9 A DVD drawer won't open
one of the faults with the home dvd player it seems we have to open them to remove the stuck dvd .and more often than not we end up braekingthe danged thing anyway
Mar 15, 2015 | Magnavox Televison & Video
I cannot play a dvd movie or record a tv program in ilo dvdr05 recorder, what might be the problem?
1: Get a movie and some popcorn.
2: Make sure the DVD player and the tv are turned on.
3: Push the button on either the front of the player or on the remote to open the player door to load the disc.
4. Put the disc on the tray that pops out
5. Push the same button pushed previously to close the door
6. Enjoy the movie
Jan 19, 2015 | iLO DVDR05 DVD Recorder
My ILO DVD Recorder do not keep the Disk Inside, is like the lock mechanism is not working; how I Can fix this? I have a DVDR04 Ilo
If assume that it will take the disk in, and then after about 10 seconds the disk returns to the open posistion.
if this is the scenario, on these units there is a switch located in the front of the DVD drawer that usually goes bad. This switch tells the Ilo that the drawer is fully closed. You may want to check and replace that switch. I own two of these units and both of these switches went bad.
Oct 10, 2009 | iLO DVDR04
Disc drawer says BLOCKED and will not open. No disc is inserted
I had the same problem . I had to take the outer casing off and was able to open. to keep this from happining again I always leave a disc in the disc drawer it seems to solve the problem
Mar 07, 2009 | Philips DVDR3450H DVD Recorder/HDD...
My ilo recorder wont take any disc
If it won't play any disc including prerecorded movies, then try cleaning the lens.
Nov 02, 2008 | iLO DVDR05 DVD Recorder
Recording problem
I have had two of these recorders, Using only Sony + discs or rewriteables is my solution, I will not use any thing else. It may work 1-3 times on others brands then start throwing coasters.
As to renaming, on my model I pull up the tiltle menu then select Try using rewriteables for the other problem as well My model is a little older and lets me take disc out without finalizing then when inserting select title, hit edit on remote and select rename. Maybe if you can skip the finalizing (as with rewritables it will help
Apr 01, 2008 | iLO DVDR05 DVD Recorder
Ilo dvd player
Did you find an answer for this? I have the same issue.
Jan 05, 2008 | iLO DVDR05 DVD Recorder
Ilo dvd recorder
This could be a fault with the spindle motor that spins the disc.
I think you might try inspecting the brushes on this motor for wear or misalignment.
Oct 18, 2007 | iLO DVDR05 DVD Recorder
Gateway AR-230 DVD recorder
I read about some magnetic thing failing as the unit gets older. Mine does this sometimes and I gently tap top of unit as I hit the eject button. Works on mine so far.
Oct 09, 2007 | iLO DVDR05 DVD Recorder
Dvd recording
have you close the disc
Jul 26, 2007 | iLO DVD Recorder DVDR05
iLO DVDR05 DVD Recorder Logo
101 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
