I drop my iphone in the water n the screen is not working what should i do?
  • nazariov1 Jun 26, 2008
    thank u for u help
  • 250 Answers
Hello nazariov1,
I am sorry to hear about your iPhone. The most important thing you can do is disconnect the battery and do not reconnect it or attempt to power the phone up util you are certain it is completely dry inside and out.
One you are sure the phone and battery are completely dry, you can attach the battery and attempt to power the phone up and see if ti works. If it does not, then you will probably have to get service on the phone through the manufacturer or your carrier. Unfortunately water damage would probably not be covered by any warranty the unit might have, so you will probably have to pay for the repairs. Depending on the extent of the damage it may make better economic sense just to replace the unit with a new one.
Best Regards,
"Go Ahead. Use Us."
Posted on Jun 26, 2008
My iphone 4 drop in my dishwater with bleach will it dry out and work again
Dropping a switched on cell phone into bleached water will certainly damage the electronics in the cell phone.
You can remove the battery and dry it out, but most likely it is damaged beyond repair.
Mar 10, 2013 | Apple iPhone Smartphone
I dropped my ipod touch in water and it works now but you can't see the screen, the brightness has gone?
it may be water behind the screen lens , but try this link and see if it might help remove excess water that still might be in there
Sep 26, 2010 | Apple iPod touch
I dropped my phone and now the screen won't work.
Please try resetting the phone.
  1. Press and hold the Home button (big circle below the screen) and the Sleep/Wake button(on top of the iPhone) simultaneously.
  2. Continue holding both buttons (Ignore Slide to power off ) until the phone shuts off and begins to restart and apple logo appears.
If the screen is cracked, u can buy that online for around $50 and replace that.
Hope this helps.
Sep 15, 2010 | Apple iPhone Smartphone
I dropped my iPhone in water. What should I do?
useually unrepairable but take the back off then remove battery and sim then use a hair dryer to try and dry out the moisture sometimes it works depends on how much water damage is in the main board
Sep 01, 2010 | Apple iPhone (16 GB) Smartphone
IPhone Smartphone: dropped my iphone into water, it was still on then...
Do a hard reset (menu and power button together for 5sec). If that doesn't work your should take it to the apple store. If they won't help you, keep the iPHone in a warm spot near a radiator for up to a week. You can try to open the iPhone yourself to let the water evaporate faster and clean corrosion. There is an iPhone 4G Repair service that can dot it for you, but if you're a little tech savy you should use an iPhone 4G repair guide that teaches you how to open the phone yourself.
May 18, 2010 | Apple iPhone Smartphone
IPhone Smartphone: i dropped my apple 3g iphone in water after 2 hrs ...
Do a search for water damage iphone repair on craigslist in your area. There are usually several people with local shops that can fix this for you.
May 17, 2010 | Apple iPhone Smartphone
I have 3 grey lines on my screen. It started off as 1. What to do
If there's no external damage on the screen then it must be inside. According to some people that have shared the same experience, lines go smaller at warm to hot temperatures and may fade whereas if it were cold, lines grow big. Although, in most cases it will remain there unless you replace the screen or solve the problem. iPhones have a sensitive screen which generally isn't shock proof if you drop it with or without a case covering it. Prices to fix your iPhone vary but are really expensive.
Aug 21, 2009 | Apple iPhone 3G Black Smartphone
I dropped my iphone and now the unlock slide doesnt work
It looks like you need a new LCD/digitizer which you canreplace yourself. Here's a guide on how to disassemble an iPhone. Maybe a tech savy friend can do it for you. If you want to have somebody else do it for you there are third party iPhone Repair Services.
Mar 18, 2009 | BoxWave Corporation Apple iPhone 2G...
Non responsive touch screen on iphone
i guess ull jus have to replace the screen
Dec 08, 2008 | Apple iPhone Smartphone
If a hard reset (press menu and center button together for 5 sec) and software restore doesn't cure it , you have a broken digitizer of your iPhone screen assembly. There is an iphone repair guide website that shows you how to do the replacement yourself and a third party iphone repair company that can do it for you.
94 people viewed this question
