Question about Epson Office Equipment & Supplies
Need software for scanner perfection 660 model 6650
Need to install a scanner epson perfection 660 on my desktop searching for the software
  • Anonymous Mar 27, 2014
    windows 7
I want to know what is code 0024
Posted on Mar 10, 2009
Is there a driver for my Epson Perfection 1200U scanner which is compatible with Windows 10?
Its working perfectly with Epson 2400U drivers.
  • Download and install the Perfection 2400U drivers from Epson USA, version 3.04A http://www.epson.com/cgi-bin/Store/s...rm=OSF_W_10-64
  • Connect and turn on your scanner
  • Run Device Manager
  • The Perfection 1200U will be shown under under Other Devices
  • Select Update Driver
  • Choose 'Browse my computer for driver software"
  • Choose 'Let me pick from a list of device drivers on my computer'
  • UNCHECK the 'Show compatible hardware'
  • Click on 'Epson' in the Manufacturer box, and the scroll down through model until you find "Epson Perfection 2400', and choose that, and press Next
  • Ignore the 'Update Driver warning - choose 'Yes'; to continue to install.
  • The Perfection 2400 will now be shown in Device Manager. Note that the Perfection 1200 will still be shown under Devices & Printers
  • Run Epson Scan and test the scanner. You may need to log out and log in again for program to work
Nov 03, 2016 | Epson Perfection 1200U USB Flatbed Scanner
Epson perfection 660 driver for windows 7 64 bit
All software and drivers for the Epson Perfection 660 can be found at the following website:
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=0ccCGROWIYMPUWIRoWUNA3DVVqr3UZJtGF6m5aDXxE0U003D&tc=6
Simply select your operating system and download the necessary files.
Good luck! William
Mar 03, 2011 | Office Equipment & Supplies
Dear Friends, I lost my Epson perfection 660 model 6650 scanner CD. If you are available the CD, I would like you send me the CD. Best regards, Htet Aung
If you are running Windows XP and earlier versions of Microsoft Windows, then this should work.. (Click Here), open the link and click "Download Now" and follow the onscreen instructions. Alternatively you can also use this link (Click Here) or here. Let me know with more details if you have problem or if you need further help from me.
Good Luck.
Thanks for using FixYa.
Dec 20, 2010 | Office Equipment & Supplies
We need drivers to our Epson perfection 1250 model G820A scanner .
original drivers are always available on epson site and you can download th driver from there.
open the epson site/ select driver download option/put the model number of the scanner/ and do the free installation/
also alternately you can search the same in google.
May 09, 2010 | Epson Perfection 1250 Flatbed Scanner
Free software for scanner
you can download the software from epson for your scanner.
you can also go to websites like pcworld.com or shareware.com and search for scanning software.
Nov 29, 2009 | Epson Perfection 1250 Flatbed Scanner
My scanner epson perfection 660 model 6650, it can not work i need help you dwonlod drever & softwere
Hi here is a guide on how to setup the router, this is from the official netgear website.
Hope this helps
Muzzi_123
Nov 14, 2009 | Computers & Internet
Soft ware problems
Try this from "Tom's Hardware" worked for me!
1) RIGHT-CLICK on the MY COMPUTER icon and click on PROPERTIES.
2) Select the HARDWARE tab, then the DEVICE MANAGER button.
3) Remove the Epson Scanner from under IMAGING DEVICE and/or UNKNOWN and/or
OTHER DEVICES by RIGHT-CLICKING on it and clicking UNINSTALL.
4) Disconnect the USB cable and close all open windows.
5) Click on START, and CONTROL PANELS.
6) Double-click on ADD/REMOVE PROGRAMS. Highlight EPSON SCAN and click on
CHANGE/REMOVE.
7) Go to START, SEARCH, and ALL FILES AND FOLDERS. Select Advanced option
and ensure there is a checkmark next to SEARCH HIDDEN FILES and FOLDERS.
8)Search for files where all or part of the file named is OEM*.* and a word
or phrase in the file contains EPSON. Search location should be set to
C:\WINDOWS\INF or C:\WINNT\INF.
9) Delete all files that are found if this is your only Epson product. If
you have another Epson product, you will want to open each individual file
and determine which files pertain to your scanner, and then delete only
those.
10)Go to START, SEARCH, and ALL FILES AND FOLDERS. Search for files where
all or part of the file named twain.log . Search location should be set to
C:\. Please delete the twain.log file and repeat the process for
twain001.mtx, twunk001.mtx and twunk002.mtx. and epfb5 and escndv
Now we need to remove specific references to the product in the registry:
1. Click on START and then RUN.
2. In the Run window type in REGEDIT.
3. In the upper menu bar click on FILE, then EXPORT.
4. In the window that comes up, SAVE IN should be set to DESKTOP.
5. In the FILE NAME section at the bottom of the window type in REGBACKUP.
6. EXPORT RANGE should have a dot next to ALL.
7. Click on SAVE.
8. Look in the column on the left and Click on the "+" sign next to
HKEY_CURRENT_USER
9. Click on the "+" sign next to SOFTWARE
10. Click on the "+" sign next to Epson
11. Look for a folder name EPSON SCAN or epson twain . Right click on it
and Delete it (if you don't see it, then don't worry about it).
12. If you see a reference to your Epson product model, right click and
delete it.
13. Click on the "-" signs next to EPSON, SOFTWARE, HKEY_CURRENT_USER to
close up this branch.
14. Click on the "+" sign next to HKEY_LOCAL_MACHINE
15. Click on the "+" sign next to SOFTWARE
16. Click on the "+" sign next to Epson
17. Look for a folder name EPSON SCAN or epson twain , Right click on it
18. If you see a reference to your Epson product model, right click and
delete it.
19. Click on the "-" signs next to EPSON, SOFTWARE, HKEY_LOCAL_MACHINE to
DOWNLOAD
Please follow the steps below to download and install your scanner in XP:
1. Go to the website http://support.epson.com
2. Under the SCANNERS heading select PERFECTION SERIES and then your
scanner model.
3. Under the Drivers & Downloads section select Windows. Download the most
current version of the Scanner Driver for your Windows operating system to
your DESKTOP.
Reinstall
1) Double Click on the Epson1****.exe file that you downloaded to your
DESKTOP.
2) Click OK, Unzip, and then OK again.
3) The installer will copy the files to the system. Click on FINISH when
prompted.
4) Connect the USB cable to a different usb port on the computer. Windows
will tell you new hardware is found and complete the install.
5) If a message appears indicating THE SCANNER HAS NOT PASSED WINDOWS LOGO
TESTING, click CONTINUE ANYWAY. Then click FINISH.
6) Your scanner is now ready to use
Oct 04, 2008 | Epson Perfection 3170 Flatbed Scanner
Epson scanner perfection 1200u photo
The driver listed on the web for 2K is compatible with XP.
1) Go to the website http://support.epson.com
2) Under the SCANNERS heading select Epson Perfection Series and then your scanner model.
3) Under the Drivers & Downloads section select Windows. Download the most current driver for your Windows operating system.
4) Follow prompts through survey and license agreement. Choose to SAVE this file to your DESKTOP.
5) When the download is complete, double-click on the Epson icon on the desktop. This will automatically extract the files and begin the SETUP.
6) Follow the prompts to install the scanner, and click on FINISH when prompted.
7) At this point reconnect the scanner to the computer.
8) You will see an ADD NEW HARDWARE WIZARD. Make sure INSTALL THE SOFTWARE AUTOMATICALLY (Recommended) is checked and click NEXT.
9) If a message appears indicating THE SCANNER HAS NOT PASSED WINDOWS LOGO TESTING, click CONTINUE ANYWAY. Then click FINISH.
10) Your scanner is now installed. Restart your computer before testing.
Dec 03, 2007 | Epson Perfection 1200 Photo Flatbed...
654 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
