Question about HP PSC 1510 All-In-One InkJet Printer
Automatically prints Everytime I turn on my printer, it automatically prints a test page. How do I stop this?
  • 1 more comment
  • Anonymous Jun 29, 2008
    once you change a ink cartridge it wants you to align the scanner with a test print page. When I follow the steps it either tells me the test failed or the next time I turn it on it prints a test page again.
  • ggRacer Jul 04, 2008
    I have the same problem as does a friend of mine. Why doesn't HP send out a hot fix for this/
  • moyerbell Aug 24, 2008
    I have the same problem. I have been putting up with it for about 2 years. I am fed up with it. I even just bought 2 brand new cartridges because that is what I thought was needed to fix the problem. Guess what, that didn't solve it. The reason I tried this was because a hp support person told me that for the alignment to work I needed to get my new cartridges and install them at the same time. I can guarantee you that there is no other problem with the device and I have tried numerous things in vain to solve this problem.
Print the test page and place it into the scanner, remember to place the paper in the correct direction. Then press the start scan button on the printer. Let the scanner do the scan and if it is successful, the printer is ready for use. If it failed, then the orange led for check paper will flash slowly. If every thing is done in the correct sequence but get failed from time to time, then you may need to get the scanned image of the test page to see what the scanner is seeing.
Posted on Jul 12, 2008
HP Laserjet 1015 printer prints test page everytime frequently automatically. why the problem?
This printer will print one of these pages if the GO button is pressed for 5 or more seconds.
Check to make sure your GO button has not become stuck!
Jul 11, 2011 | HP LaserJet 1015 Printer
How do i switch of align page when installing a new cartridge as it waste paper printing a test page everytime you switch it on. This is for a HP 1300 series
http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=238320&taskId=110
Click on the 'Automatically check to see if your driver needs updating (MS Windows Only).' box in order to check for latest updates to your driver.
Unfortunately, I looked over the unexpected page output and it didn't list this problem as one of them.
Does it really print a test page every time you switch it on? Or does it only print a test page after installing a new cartridge?
Definitely, the alignment page should be printed everytime a new cartridge is installed due to variations in manufacturing of print cartridges will throw off the alignment everytime a new cartridge is installed.
I'm not sure about the test page, though.
Good luck on this modification of standard operating of hp printers.
Jan 17, 2011 | HP LaserJet 1300 Printer
Everytime I turn my HP PhotosmartC3180 on, it prints a test page.
I think probably it's a print alignment page, if you read the page it will probably give you instructions to place the page on to the scanner at the top and press a button for it to scan and automatically set the alignment. Do so and it should fix it :)
Aug 04, 2009 | HP PSC 1315 All-In-One InkJet Printer
HP psc 1310 printer autoprints a test page
the autoprint which you r telling is called allignment page which your printer is printing everytime.just when the printer prints that autoprint you take that autoprint and place the printed side of the paper on the scanner glass and press the scan button.the printer ON/RESUME light will blink for 1minute then automatically stop and then u will not get this autoprint till u replace any of the cartyridge from the printer.
Dec 15, 2008 | HP PSC 1315 All-In-One InkJet Printer
It automatically print a page everytime I start my hp psc 1315
Hi Siddarth
In HP PSC 1315 printer after replacing new Ink Cartridges the printer always prints Alignment test page every time you turn it ON.To resolve this problem you must complete the alignment process.
Steps
1.Turn the printer ON.
2.Once its ON, it will print the Alignment page. Place the page in the scanner bed correctly.
3.Then Press START SCAN button.
4.The power light will start blinking, wait until the power lights turns solid.
5.Now Alignment process is over.Discard the paper from scanner.
6.Turn the printer OFF and then ON, it will not print that page again.
Note:Please follow this steps every time when you replace the Cartridges.
Thanks
Rizwan
rizwan84tx@gmail.com
Dec 08, 2008 | HP PSC 1315 All-In-One InkJet Printer
Everytime I switch on the printer a test sheet is printed automatically
Which Printer you use?
Anyway....go to Start > Printer & Faxes > right click on your printer
and check off "Print Test page"
It will help you
Nov 27, 2008 | HP Office Equipment & Supplies
Hp photosmart c3100 series ne s'instal pas sur vista
Everytime I turn off the printer and turn it back on, automatically it start printing an test page; with lines, blocks, gray blocks to test the ink. How do I change the printer to stop the test page?
Thanks for your help!
Emily
May 20, 2008 | Office Equipment & Supplies
Printing Test Page
you probably need to align the print cartridges. you can usually do that through the advanced printer oprions
Mar 25, 2008 | HP PSC 1350v All-In-One InkJet Printer
Test Page Prints Everytime Printer Cuts On
this is happen when you install an new catridge or refill one printer is automatically adjust the catridge by alingment so you do one thing when you switch on printer and it will print something just read the instrction and follow them bcoz you need to setup the alingment thing . when the print is come out just place it in to the scanner and just press the scan button the printer will store the setting and next time not print the extra page bcoz the setup is completed.
bye
Nov 02, 2007 | HP Photosmart C3180 All-In-One InkJet...
HP PSC 1510 All-In-One InkJet Printer Logo
106 people viewed this question
Seeker5211
Seeker5211
