Hard drive defective. - Computers & Internet
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 95 Answers
Hi
Please give us more details.
Jyothish
Posted on Jun 26, 2008
C0640
Hard disk drive problem
The hard disk cannot be accessed
the main PWB and the connector on the
hard disk. Repair or replace if necessary.
Defective hard
disk.
Run U024 (HDD formatting) without turning
the power off to initialize the hard disk.
Replace the hard disk drive and check for
correct operation if the problem is still
detected after initialization.
Defective main
PWB.
Replace the main PWB and check for correct
operation
Apr 17, 2014 | Kyocera Mita Km 3035, 4035, 5035 Fs9120dn,...
It keeps saying operating systme not found
it appear because of a defective hard disk drive or a defective operating system or maybe a defective IDE cable the one who connects the hard disk drive through the main board. try to replace a new IDE cable. then if it still have the problem try to reformat the hard disk drive with a new operating system(windows xp etc..)if still the problem occurs try to replace the hard disk drive.. may this one helps you
Jul 25, 2011 | Texas Instruments Computers & Internet
Hard disk making funny noise and netbook does not recognise boot device after automatic windows update and restart.
You either have an error with your hard disk or with the Windows partition files.
Some HP Mini Netbooks have a hard drive self-test feature. In order to check for a hard drive problem, turn on your computer and press the "F10" key during startup. This will open the Setup Utility. Use the arrow keys to navigate to the "Diagnostics" menu, then highlight "Hard Disk Self Test". Let the test run fully. If it reports an error(s), then you have a damaged/defective hard drive, and you will need to replace it by either contacting HP through their support site, or by replacing the drive yourself with a new one.
If the Setup Utility cannot detect your hard drive at all, then you either have a defective hard drive /or/ a defective SATA controller (this is what connects your hard drive to the computer). Unless you can connect your hard drive to another computer, it is very hard to determine which is causing the problem. You should contact HP if you are under warranty, or check in at a local computer repair shop if you are not.
If there are no errors reported with your hard drive, then either your hard drive only fails some of the time (and you should be able to boot into Windows at the moment), or there is a problem with the partition (section) on your hard drive that handles booting up. You will need to reformat the hard drive and reinstall Windows in this case.
Mar 28, 2011 | HP Mini 1000 Netbook
Drivers wont mount. tried to mount them on a Star Tech drive reader. First thought that the power supplies went bad.
When you turn the drive on, does the indicator lamp flash once and then is dark? If so, that indicates a defective hard drive. When you mounted the drive in the Star Tech drive reader, did it spin up? If not, that would confirm a defective drive. If you need more help, please call HitachiGST Tech Support M-F 8AM to 6PM PST at 1.888.426.5214 and a technician will be happy to help you.
Jan 25, 2011 | G-Technology (913003-01) 500 GB FireWire...
Sc-860
Most likely problem is a failed hard drive. You can open the back cover and remove the hard drive. There are a couple of features , like stapling and maybe duplex that wont work. And it will print a little slower until the drive is replaced. You will simply have to run a format when replaced. But it will run quite well without the hard drive.
The screen will leave you a small message that the hard drive is removed, but it will function.
Here is the documentation.
Cable between HDC and HD loose or
defective
HD power connector loose or defective
HD defective
HDC defective
Aug 09, 2010 | Ricoh Aficio 1035 Copier
Do I need an electrical plug in to work this drive. Nothing happens when I plug in the usb cord.
the device is powered by the USB plug,so no there is no other power, if it doesn't work either the USB port is defective or the drive is defective, the last being more likely.
Aug 03, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
I have ST3160215A 160 gb but it showing 137.4 please help!!!
Assuming that the jumpers at your hard drive is in the
right position. Run Scandisk to correct defect of the hard drive. If there's no change after the running Scandisk, then, the portion after the 137.4 either used space or a defective one.
Oct 13, 2009 | Seagate Barracuda 7200.7 160 GB Hard Drive
I have two T-42 think pads with the same problem. They will not boot. Message says "cannot find operating system". I have the IBM recovery disks. When trying to run them get message saying...
It seems that the recovery disk u are using may be defective.Try to load os with another os cd.If every thing goes fine replace the recovery cd,otherwise it may be a defective motherboard.consult thinkpad service.
Jul 09, 2008 | Computers & Internet
Portable hard drive won't show on desktop
it could be defective cause you might have taken the stick off while it was loading or if not you can plug it again and try opening it through My computer/ Removable disk:
Jun 19, 2008 | Verbatim VER95327 USB Hard Drive
Maxtor OneTouch 200 won't power on.
Sounds like one of two possible problems: Either your power supply is defective from the factory and is incapable of supplying enough power to properly operate the drive, Or the drive has a short in it and is drawing excessive power beyond the capabilities of the power supply. The easiest way that i can think of to test which it would be is to acquire another supply that provided the same voltage and current as the one you have, with the same type plug on it, that's wired with the same polarity. Common 'wall warts' that you may have around the house should be capable of fitting this bill, and if not, you can pick one such supply up at a retail store such as radio shack. IF the 'new' supply fails to turn the drive on, Then the drive is defective. If it does turn the drive on, Then the supply is defective.
Nov 30, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
