Question about Brookstone Pure-Ion (506840) Air Purifier
No Power I have a Pure Ion air unit that I unplugged for the winter. It is ~ 2 years old. When I plug it into the wall outlet now it has no power. I have tried several outlets and taken the filters out & cleaned them with no results. Any ideas?
  • Anonymous Jul 30, 2008
    where are the fuses?
  • 41 Answers
If you are at all handy, there are two separate fuses on the power board in the bottom of the unit. Mine had a bd fuse and a bad wire. If you can't get it fixed, I'm looking for parts. Contact me before you throw it out.
Posted on Jul 15, 2008
  • wn4viv May 11, 2011
    I also have a "no power" problem in my 506840 unit. I found fuse F1 on the green pwb near where the 120 volt power line is connected, and it measures very low resistance. Where is the other fuse? Jim knjhanlon@msn.com
Let me know if you are selling the charcoal filter. I have a hole poked in my top one and would buy yours if you have it.
Email me at ryanpluta@yahoo.com
Posted on Nov 10, 2008
How do i clean my Brookstone Pure-Ion Uv Air Purifier
[PDF]Pure-Ion® Pro - Brookstone
www.brookstone.com/webassets/pdf/630285p_manual.pdf
BrookstonePure-Ion® Pro. Air .... Use this unit only for its intended use as described in thismanual . 4 . .... Position the unit so the cleaner air flows to your desired location .
Aug 30, 2015 | Brookstone Pure-Ion UV Air Purifier
My unit is 5 years old and will not power on. It is not the outlet or the cord, I fear it is the electronic board. Any suggestions to diagnose before i throw away?
Mine was the power supply. I was able to repair it though. Pleasd contact me before you throw it away. I need a touch screen. My daughter used it for a drum!! Kennykbe@hotmail.com
Jan 27, 2011 | Brookstone Pure-Ion (506840) Air Purifier
Cleaning tips for my Brookstone Pure Ion
I have Bridge Stone Ionic Air Cleaner and I cant figure out how to take it a part to clean the filter. It's a few years old, used very little and I don't have a manual. Can anyone help. thanks
Nov 06, 2009 | Brookstone Pure-Ion UV Air Purifier
Pure Ion will not turn on. We took out the filters to clean them. Wall outlet works for other items. Have tried other outlets.
It sounds like the main board is not getting power. The power supplies have capacitors inside that do overheat and burn out. You can test power coming from power supply leading to main board with a voltmeter. You can try to unplug for 8 hours, in meantime while unplugged, press and hold power button for 5 seconds, then wait 1/2 hour and plug back in to see if unit has reset itself
Oct 13, 2009 | Brookstone Pure-Ion UV Air Purifier
Brookstone Pure-ion Advanced
i am a low voltage tech my wife told me that our 506840 air cleaner stopped working so being a tech geek i had to know why it just stopped working.when plugged in i heard a click telling me that the main board was getting power.opened the back end where power cord goes to put my meter and voltage was going to the main power coil. but the main board was oxidized. when my wife was cleaning the filters and might not have had the filters completely dried the water was dripping down to main board.the unit to main power source is not design very well where water from cleaning the filters can drip down to main power board.solution i am working on is trying to get a new board when we bought this it was $499.00
Oct 15, 2008 | Brookstone Pure-Ion (506840) Air Purifier
make sure the filter is seated in the unit correctly there is a right and wrong way and unless the connection is made it won't start
Aug 23, 2008 | Brookstone Pure-Ion UV Air Purifier
Clean Filter Red light
I cleaned the filters as well earlier and the red filter light still blincked to clean the filters. Then I pushed the power button for about 10 seconds continously and then turned it on and the light turned off.
May 22, 2008 | Brookstone Pure-Ion UV Air Purifier
Brookstone pure ion filters
You need to reset it, unplug the unit and take out both filters. Then, plug it back and and simultaneously and firmly slam both filters into the back of it at the same time. Before putting both filters back inside the until, also vacuum out the insides in case there is hair/dust inside of it that has accumulated.
Also, make sure your filters are 100% dry before every putting them back inside the unit.
Mar 02, 2008 | Brookstone Pure-Ion UV Air Purifier
Pure ion uv light does not turn on
Where can I get a replacement ultraviolet germicidal lamp? I have been to Brookstone store and on line without help. My unit is a Pure Ion.
Thank you.
Dec 25, 2007 | Brookstone Pure-Ion UV Air Purifier
PURE Ion shuts off after a few moments
You need to shut it off, unplug it, and pull both the filters out at once and then plug it back in, and push both filters in at the same time, simultaneously. This will re-set it.
Also, if this continues to happen, you must vacuum the insides of the unit, aside from the filters, themselves, it can get all clogged up.
We live on a busy street and our house can get REALLY dusty, we have a older home with carpets and two cats - so our unit really has to work hard!
Oct 28, 2007 | Brookstone Pure-Ion UV Air Purifier
Brookstone Pure-Ion  (506840) Air Purifier Logo
325 people viewed this question
Top Brookstone Air Purifiers Experts
Are you a Brookstone Air Purifier Expert? Answer questions, earn points and help others
