Question about Garmin nuvi 350 GPS Receiver
Nuvi 360 Hi, I saw your fix for the nuvi 350, i;ve been looking for that info all day., thanks! I dropped my 360 from about 12 inches to the ground and the screen faded out about 50%, then a while later it slide from the seat to the floor on carpet and it faded out to nearly 98% white. any ideas on a fix? can you remember if there is any obvious screen connectors that may have come loose before i open her up?
The screen has two connectors, one for power, another for data, just try to reconnect again those little cables, and it should be fine. When I opened mine the first time, my screen comes up all white, and it was because one of those cables.
I have a video from the last time I open my Nuvi350, I will try to post it on this days, in order to give you some idea on how to do it.
By now, I wish you luck, and be patient.
Posted on Jun 27, 2008
Garmin 350 is there an internal fuse, I connected it to a 12 volt battery, but I think I crossed the wires, now it won't power on. Thanks
The Nuvi does not run off of +12V!!! It runs off of +5VDC. There is no internal fuse. I'm afraid you have fried your Nuvi,
- Jim
Jan 14, 2011 | Garmin Nuvi 350 Car GPS Receiver
Garmin GPS Says "GPS OFF"
You have to flip up the antenna on the back to turn the GPS on.
Feb 15, 2009 | Garmin nuvi 350 GPS Receiver
My garmin nuvi 350 displays "enabling Bluetooth" and will not move . What should I do
A Nuvi 350 does not have bluetooth capability. Do you mean Nuvi 360? If it is a 350, then the firmware is corrupted or was flashed with the wrong firmware.
- Jim
SHARCNET-USA
Jan 17, 2009 | Garmin Nuvi 350 Car GPS Receiver
I forget my pin for my gps garmin nuvi 350 please canhelp?
HI
AS LONG AS YOU CAN PROVE OWNERSHIP OF YOUR NUVI WE CAN ASSIST YOU WITH THIS PROBLEM
Hi. Please look us up on EBAY.CO.UK
MGA-TRADING
We offer the best value and quickest repair service around for the Garmin Nuvi
Unlocking the PIN on the 300 series Nuvis is usually straight forward and the unit can be turned around in a few days!
Regards
MGA-TRADING
Dec 10, 2008 | Garmin Nuvi 350 Car GPS Receiver
Garmin nuvi 350 battery replacement
I can't do it for you, but I have done it myself. See the instructions on my webpage at www.dacust.com/nuvi350/index.html. Pictures and everything, along with where I got my battery and the part number, etc. Warning, there are many opportunities to damage your unit doing this. Not for the novice.
-dan
Oct 04, 2008 | Garmin nuvi 350 GPS Receiver
Garmins Nuvi 350 - voice interactive lost
I have the same problem with my Nuvi 350. It's only about 2 months old and the sound went. I turned it on the other day to use it and the sound did not sound right, it sounded like the speaker was blown. I turned it off and turned it back on and that was it, the sound was gone. I did everything possible and can't get the sound to come back. I called Garmin and now I have to send it in for repair. I looked around the web and noticed that Garmins have big issues with the sound going on the units. I hope they fix that issue.
Jul 28, 2008 | Garmin nuvi 350 GPS Receiver
Nuvi 350 satellite reception problem
Having taken several Nuvi's apart, the flip up antenna has a 1/4" wide flat flex cable that runs from the flip up antenna assembly to the main board.
The flex cable carries the voltages required to power the antenna assembly and bring the signals back to the main board.
There is actually a printed circuit board in the flip up antenna assembly. It's possible that this is the receiver itself.
The flex cable runs through the round center hinge of the antenna assembly on the right (looking at the Nuvi from the rear) back to the main board.
There is also a magnet involved with the flip up antenna assembly that tells the main board whether the antenna is up or down. If the antenna is down, the Nuvi will NOT look for satellites.
A couple things can happen here that can make your Nuvi not find satellites: Assuming you have tried a hard & soft reset:
1. The antenna flex ribbon cable has become damaged.
2. The antenna flex ribbon cable has become detached from either end (it's held in with just a snap down flap).
3. The magetic switch isn't operating correctly and the main board thinks the antenna is down.
4. The front-end receiver has failed.
If your good at taking things apart (and the Nuvi is a little tricky to take apart), you might be able to verify some of the possibilities I mentioned above.
You might also try looking for a Nuvi for parts on eBay. Maybe you can find one that has a bad LCD screen and salvage the antenna from it.
- Jim
Jul 02, 2008 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 350; 360
The Nuvi 350 is the same for the most part no matter where you purchase it. The only things that can change on the unit are the pre-loaded maps (Europe if purchased there, US and Canada if purchased here) and the languages. The basic receiver is the same. You do have to be careful where you purchase it as theft is rampant, and purchasing from a retailer who is not authorized by Garmin will result in you not having the factory warranty.
Dec 30, 2007 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
109 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
