Question about Smith Corona Wordsmith 200 Typewriter
Smith Corona 240 DLE
The paper will not feed properly. After positioning a sheet in the slot, and turning on the machine, the paper begins feeding in a cocked angle to the vertical.
Can you help?
  • jocelynmcd20 Dec 28, 2008
    My problem is getting the keys to type and print. I have a ribbon, but the keys on the keyboard won't type.
    Scholar:
  • 183 Answers
Pull the paper release lever and look under the platen as well as you can, to see if there are any forien objects. check if the feed rollers are all in place. the slots in the paper pan under the platen should have rollers in them
Posted on Nov 29, 2008
Need manual for smith corona 240 dle typewriter
Will Repair Service has all Smith Corona manuals. You can find what you need there; www.willrepairservice.com.
Sep 12, 2014 | Office Equipment & Supplies
WHY SMITH CORONA 250 DLE DOES NOT SPACE BETWEEN LINES?
Usually there is an adjusting knob at the end of the roller where the paper goes down. It turns while hold the other end.
Sep 01, 2014 | Office Equipment & Supplies
Handle for a Smith C orona 350 DLE to turn paper holder bar
It is called a platen knob. Google smith corona dunkirk Ny they will be able to help you.
DickyO
Apr 30, 2012 | Smith Corona Typewriter - 350 DLE -...
Printer is saying manual feed insert paper. Will not print
To load paper or other media in the Manual Feed Slot (directly above the Paper Tray)
You can load envelopes and special print media one at a time into this slot. Use the manual feed slot to print or copy on labels, envelopes or thicker paper.
1. Slide the paper guides to fit the paper size.
2. Using both hands put one sheet of paper in the manual feed slot until you feel the front edge of the paper touch the paper feed roller. Let go of the paper when you feel the machine feed the paper in a short distance.
Note: When you put paper in the manual feed slot, please remember the following:
■ The side to be printed on must be face up.
■ Put the leading edge (top of the paper) in first and push it gently into the slot.
■ Make sure that the paper is straight and in the proper position on the manual feed slot. If it is not, the paper may not be fed properly, resulting in a skewed printout or a paper jam.
■ Do not put more than one sheet or envelope in the manual feed slot at a time or you may cause the machine to jam.
■ You can remove smaller sizes of printed paper from the output paper tray more easily if you lift the scanner cover using both hands as shown in the illustration.
You can still use the machine when the scanner cover is raised. You can return the scanner cover to its home position by pushing it down with both hands.
If you would like to disable Manual Feed Mode, check that the manual feed mode is not selected in the printer driver.
Here is a copy of the User's Manual for the Brother MFC-7820N.
Jul 07, 2010 | Brother MFC-7820N Laser Printer
I have a Canon MP470 that pulls 1/2 sheet paper and then jams
Paper feed roller
cleaning
When paper does not feed
properly.
To clean the paper feed
Machine button
Oct 07, 2009 | Canon PIXMA MP470 All-in-One Printer
Smith Corona 300 DLE--toggle from italics to normal type
To switch fonts on this typewriter, you need to change the letter wheel. Unfortunately, there is no practical way to change the letter wheel in the middle of a document.
Apr 10, 2009 | Smith Corona Office Equipment & Supplies
Remove stuck label
THIS IS COMMON FAULT WITH PEOPLE WHO USE LABELS ON TYPEWRITERS. U MUST NEVER TURN THEM BACKWARDS OR U WILL GET ONE STUCK IN MACHINE. THE ONLY WAY TO GET IT OUT IS TO REMOVE PLATEN AND CLEAN THE JAMMED LABEL FROM THE FEED. AND ON SMITH CORONA MACHINES THIS IS NOT EASY TO DO ONESELF.
Mar 18, 2009 | Smith Corona Wordsmith 200 Typewriter
Smith Corona 235 DLE doesn't advance
Does the platen move or does the paper not advance? Check the paper release lever to make sure the feed wheels are snapped in place. If the platen does not move something in the paper feed motor area.
Jul 28, 2008 | Smith Corona Wordsmith 200 Typewriter
Lock Button Stuck
This usually indicates no ribbon. Check to be sure the ribbon is properly installed or put a new ribbon in.
DickyO
May 24, 2008 | Office Equipment & Supplies
Smith Corona Wordsmith 200 Typewriter Logo
219 people viewed this question
Top Smith Corona Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Ron Dufek
Ron Dufek
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
