Question about Toshiba 55H70 55" Rear Projection Television
Replace tube I have removed the back pannel and can see the tube that doesn't light. But it looks like it would be more accessable from the screen side. So how do you remove the screen.also the blue went out came back for a short time and went out again.so I assume it's the tube. Thanks,John
  • jpgrizz Feb 02, 2013
    what I found when I checked the tube connection was a loose connector I spread the pims on the tube and reconnected it, after which the tv worked great. John
    President:
  • 4,402 Answers
I drought it's the tube if it comes and goes, sounds like a loose connection. http://serviceman.site88.net/index_files/MP3Players.htm
Posted on Jul 01, 2008
How to fix a GE Topload Washer leaking down the inside center of the machine back pannel?
check the tube that goes from near the bottom of the tub up to the level control switch
Jul 09, 2017 | Washing Machines
Jacuzzi Espree with side access pannels leaks.
you can use a scissor cutter or a utility knife and make a nice square cut in the hose. After replacing the nut, hopefully you can find one, you can get a pvc coupling, the hose is the same size as pvc pipe, and use pvc glue to reattach the 2 ends back together. Use Oatey Rain-N-Shine glue....it is in a light blue can and the actual color of the glue is blue.
Oct 21, 2009 | Jacuzzi - Bathtub - Alcove - Navona -...
HOTPOINT WASHER OVERFLOWS ON ALL CYCLES
This is most likely a damaged pipe going to the low pressure sensor. This sensor determines when to turn water off by the pressure built up in a tube. If there is a damaged pipe - it wil overflow.
Turn off and disconnect machine, then remove access pannel to inspect all small bore pipes for damage. Check pressure valve for correct operation.
If it leaks at times other than filling, and water level seems ok, then it could be a damaged top or bottom seal that needs identifying and replacing.
If it leaks constantly it could equally be a damaged rubber pipe between drum and pump.
You really need to remove an access pannel - and just observe operation without putting your fingers in thereto spot it.
Sep 08, 2009 | Hotpoint VBXR1090D Top Load Washer
Philips 42PFL5332D/37 Black screen with sound and remote works
You just said it - no backlight, if so there are only two things that can cause this, it is the lamps in the panel or it is the lamp power supply. These tv's are board replacement only, if it is in warranty i would get it to an authorized service center asap. If it is the lights in the pannel the pannel it's self will have to be replaced, the backlight cannot be replaced seperately. If it is out of warranty and it is NOT the lights in the panel the board ad labor will cost you a couple hundered dollars to fix. If it is the pannel the cost will be prohibitive to fix even if you were to change the pannel yourself.
Sep 01, 2009 | Televison & Video
We washed a small rug and we got an E-20 code. what should we do, its having problems draining!
Drain pump screen is clogged. If its makeing a bad grinding sound the pump will need to be replaced. Otherwise disasembly of the machine is required to access pump area to clean out screen. Dextrous people can probaly do this from the back or underneath unit. Its difficult and I don't recomend it to beginers or people who arn't handy. Easiest/prefered method: (This is the one I use.)
Method A units that have a bottom access panel. ie: front panel not one seamless peice.
-unplug unit
-lean back against wall for easy access.
-remove two #2 square screws form access panel.
-Loosen clamp holding hose to tub. (Big black one around 2" in diameter.)
-remove and clean screen.
-reassemble machine and test pump operation.
Method B units the have seamless front panel.
-unplug unit
-remove top. 3 screws @ back, slide top away from machine to remove.
-remove 2 screws holding console onto chasis.
-remove disp
-remove 3 screws @ and behind disp area.
-Remove console. ( tab may be holding to front panel @ middle bottom use putty knife to pry up.)
-remove 4 screws holding front pannel @ top to chasis.
-remove 2 screws holding frong pannel to chasis inside machine. Acess from top. (some models only.)
-remove bottom screws either 4 or 2 usally 4.
-remove two screws holding door lock to front panel
-remove spring from around bellow.
-remove bellow from front pannel
-remove front pannel. Tilts forward and lifts up off supports. (some models only.) or pannel ifs up and off from white tabs in side of chasis.
-unhook wires to door lock from front pannel. (plastic molex tab)
-may now access pump like in method A.
Pump Replacement
-access pump area
-remove drain hose to pump by looseing clamp and pulling off.
-remove hose to tub by losseing clamp and pulling off.
-remove power connection at back left of pump.
-unscrew two philips screws holding pump too base plate. (only one is really required.)
-replace pump
-clean pump screen or add one if not present.
-reconnect hoses.
-replug in power
-reassemble machine
-test pump operation
Jul 12, 2009 | Frigidaire GLTF2940ES Front Load Washer
How do i replace pass. outside mirror on a 04' nissan maxima
First you need to get you a new mirror, then once you have it remove the door pannel, so you can get access to the screws located behing the little tweeter located on the inner side of the mirror. To remove the door pannel you need a philip head screw driver with magnet preferable, or a socket size 10mm. remove the little plastic square on the door opener of the inside, plus remove very carefuly to not brake the clips gray shiny of the hand rest side and remove the two screws of the very in. once you remove the those two screws, insert something flat in behind the pannel to be able to lift it, try to pull out kind of gentle try not to lose the white push pins of the back of the pannel. now you have the view and access to the screws that hold the mirror and don't forget sometimes the new does not include the wheater strip going inside the mirror to prevent the water of going in, Just reuse it and screw it back and just do everything vise-verse. Good luck!!!
Mar 29, 2009 | 2004 Nissan Maxima
1998 toyota 4 runner,back hatch handle broken
removed back pannel and pulled cable to open the door.took about 1 hour.replaced break lights and put back together.handle still broken but I know how to fix it now.
Jan 14, 2009 | 1998 Toyota 4Runner
Green Screen
what you can do is take off the back pannel and there is a cord on the top of the board that looks like a computer board, there are many boards in the TV but the one I am talking about is twords the bottom where the video jacks plug in to the TV. Ok once you have located the pannel there is a cord on the top kinda tword the right side, it is many wires inside a black covering. What you need to do is just simply unplug it and plug it back in, do this as many times to try to get it to work. If that doesn;t work you can replace the cord and if that doesn't work then the screen is out and would cost WAY too much to fix, you could buy you a new name brand TV.
Dec 12, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
15.6 lcd wide moniter (low light)
It's LCD pannel problem
Remove the LCD pannel and checket flowrocent tubes at top of LCD Screen and Bottom of LCD Pannel. If U Find any burning area at end of F tube, please clean it and solder the flowercent tubes in same possion and connect as same.
Oct 03, 2008 | Acer AL2216WBD LCD Monitor
Aeg 88070im dishwasher
The machine must be opened and side pannels removed. Work on a table as all connections are visable once you have removed front bottom pannel and back bottom pannel. Remove the side pannels for easy access.
May 12, 2008 | AEG 23 in. Favorit 88070IM Built-in...
Toshiba 55H70 55" Rear Projection Television Logo
32 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
